  On 8/4/2016 at 11:29 AM, bradp said:
There is a confusion / inconsistency in the marketing of the G5.  The STC has a download code/key that prints the STC letter to make the instal legal. In the BT forum a garmin rep (Trek I think) said that a garmrin dealer needs to use their login to download the code.  However, this is an A&P installable unit.  Chief and spruce are selling them.  So makes me wonder how your local A&P who's not a garmin dealer is supposed to print the STC?
Expand
It may be the difference between the experimental version which can be bought at Chief or Spruce and installed by anyone. The STC'd version does need to be installed by a G authorized dealer.
http://newsroom.garmin.com/press-release/featured-releases/garmin-introduces-g5-electronic-flight-instrument-certificated-aircr
  On 8/4/2016 at 2:57 AM, jetdriven said:
You can move the  gyro that drives the autopilot to the lower left spot and use the G5 of D10 in the center
Expand
but then you have to keep throwing 2.5 AMU's at repairing, how did PTK put it, "that fine switch watch" KI256 every 500 hours or so.
Expand
The G5 does not need to be installed by a Garmin authorized dealer. Here's what Trek from Garmin said on Beechtalk:
Hello Brad,
I did confirm yesterday that the G5 certified does not fall under our install guidelines and can be ordered online and the unit installed by your local A&P. however they will need to register the unit on the Fly.Garmin website in order to get the STC documentation for that install.
_________________
Trek A. Lawler
Supervisor, Garmin Aviation Field Service Engineering
Aviation Product Support
https://www.aircraftspruce.com/catalog/avpages/garmin-g5-cert.php
http://www.chiefaircraft.com/gmn-k10-00280-00.html
Expand
Perfect!!
  On 7/31/2016 at 5:19 AM, bradp said:
In that case I'd consider installing the experimental version instead of the STCd if it can be done as a minor mod.... Even if it couldn't be installed front and center like the STCd G5, at least you would get HSI and preselect functions.
Expand
What about the STC version for the AI up top front and center and then using a second one for an HSI and DG with heading bug to AP?
In my case I have the STEC 30 so I do not need the AI for the AP.
It must have a non G5 backup and  it cannot replace any required instrument so I don't see how you could do that reasonably.
We might be confusing different things. The STC'd G5 is a replacement for your attitude indicator. In the Certified Aircraft installation video they show the only attitude indicator removed and replaced with the G5. The marketing docs say its STC'd as a  "replacement" of you attitude indicator for certified aircraft.
-Robert
The G5 cannot be used wth instrument panels that have shock mounts.  I know my 77J does have them, which would make the installation ineligible for the STC, although all M20s are listed in the AML.  I am not aware of a pathway that would allow for removal of the shock mounts, as persistently droopy as they are.
-Brad.
I wonder when Garmin will have a attitude display using the FlightStream 210 AHRS.  There would be no shock mount restriction, it would be cheaper since it's only a display.  Add HSI function, SV and you have a complete solution in a nice little package.
-Brad.
Expand
I don't understand that restriction. Am I missing something easy.
OK...can I replace my attitude indicator in 85 M20J with KFC-150 (no flight director) with the certified G5 ?
I would definitely like to add an electric standby AI to my panel. I'm thinking this isn't only the best option, but probably the cheapest option as well.
Expand
Yes, that's what it's designed for.  But I'd do with it what I did when I installed the Castelberry AI a few years ago. Put it front and center the put the vacuum AI in the lower left hole.
Expand
As Byron states Turn and Bank or TC can be gotten rid of if you have an attitude indicator that drives your autopilot.
I'm going to keep my TC because it drives my factory autopilot. But I'll move the existing attitude indicator off to the right of the VOR heads and put the G5 front and center. Most of my flying is in G1000 aircraft so I'm becoming more used to airspeed/altitude tapes anyway. Plus as I get more 'mature' I"m less excited about a vacuum based attitude indicator backed up by a TC that flops back and forth (although I've done it in actual a few times when the attitude indicator did die).
-Robert
