RobertGary1 Posted October 7, 2015 Report Posted October 7, 2015 I still have the original Mooney clock in my panel. So I thought it might be fun to put a modern clock there. But $500 seems ridiculous. http://www.aircraftspruce.com/catalog/inpages/astrotech.php?clickkey=64547 -Robert Quote
Yetti Posted October 7, 2015 Report Posted October 7, 2015 For that money you should at least get a USB charging port. Quote
Piloto Posted October 7, 2015 Report Posted October 7, 2015 I had an LCD clock like that but it died on me. For less than $100 I replaced it with this one: http://www.aircraftspruce.com/catalog/inpages/mitchellClock.php It has built in lightning, great visibility and easy to set the time. José Quote
201er Posted October 7, 2015 Report Posted October 7, 2015 For that money you should at least get a USB charging port. And STC/TSO. Sorry folks, batteries not included: "This part has no FAA Approval." Quote
KSMooniac Posted October 7, 2015 Report Posted October 7, 2015 Mid Continent has a new clock with a USB charger in it for ~$500 if someone feels compelled to spend the big bucks. Quote
1964-M20E Posted October 7, 2015 Report Posted October 7, 2015 (edited) Davtron $162 have one in my plane works great. If you want to mount it in the yolk get the one without the battery backup. You will need a constant 12V source when master is off to maintain the time . If you are not interested in keeping the correct time then it becomes ad flight time recorder as well when you turn on the master or avionics SW depending on what bus you connect it to. http://www.aircraftspruce.com/catalog/inpages/davtron10-03334.php?clickkey=18998 Edited October 7, 2015 by 1964-M20E Quote
Danb Posted October 7, 2015 Report Posted October 7, 2015 Jose now that clock actually looks cool plus less $$$$ Quote
RobertGary1 Posted October 7, 2015 Author Report Posted October 7, 2015 I just bought a clock/voltmeter to mount on my motorcycle for $20. So $500 for a TSO'd clock will take a few weeks to digest. Technically if your installed clock isn't working though you don't have the required equipment for IFR. -Robert Quote
N201MKTurbo Posted October 7, 2015 Report Posted October 7, 2015 I won't tell if you don't. Wear a watch... Quote
jetdriven Posted October 8, 2015 Report Posted October 8, 2015 I lurked I lurked and scored a Davtron M803 for 125$. It came with the temp probe and everything. Keep a lookout they turn up. 2 Quote
KSMooniac Posted October 8, 2015 Report Posted October 8, 2015 I lurked I lurked and scored a Davtron M803 for 125$. It came with the temp probe and everything. Keep a lookout they turn up. Very true...I got a M655 years ago for $100 or so as well. It is a multi function OAT system, but no clock. I already had an M811b clock thanks to the previous owner. Davtron makes nice products. Sent from my VS985 4G using Tapatalk Quote
ujhan Posted October 8, 2015 Report Posted October 8, 2015 I installed the Mid Continent MD-93 during my panel upgrade in my M20J - it does have 2 x USB charging ports which is excellent, however when transiting a timezone with +9:30 GMT I found there was no way to set the local time & GMT time to represent their actual values. I went to the Mid Continent web site and contacted support to find out the reason (I also read the pilots guide in its entirety(!)) and they never responded. There is also no way to set it to start on GMT time on startup (it always defaults to local time). I believe for the cost, it should have been better engineered than that. Quote
ryoder Posted October 8, 2015 Report Posted October 8, 2015 This kid is making clocks. Ask him. Quote
PTK Posted October 8, 2015 Report Posted October 8, 2015 (edited) I always wanted my clock to simultaneously display GMT and local time. I think an aircraft panel clock should have this capability. I replaced my ailing oem one with a Davtron M802. It's a very nice piece with all the functions and of course a permanent display of both times that I really like. Edited October 8, 2015 by PTK Quote
201er Posted October 8, 2015 Report Posted October 8, 2015 I always wanted my clock to simultaneously display GMT and local time. I think an aircraft panel clock should have this capability. I replaced my ailing oem one with a Davtron M802. It's a very nice piece with all the functions and of course a permanent display of both times that I really like. ipad already does that. Need a ticking panel clock only to be legal Quote
PTK Posted October 8, 2015 Report Posted October 8, 2015 ipad already does that. Need a ticking panel clock only to be legal "...I think an aircraft panel clock should have this capability..." 1 Quote
aviatoreb Posted October 8, 2015 Report Posted October 8, 2015 http://www.walmart.com/ip/La-Crosse-Technology-Equity-Analog-Twin-Bell-Alarm-Clock/31428467 Quote
aviatoreb Posted October 8, 2015 Report Posted October 8, 2015 I heard a really cool story on NPR a year or two ago, about DC3's still in service in South America, and this one was running a passenger service across a notch in the Andes with two very tall mountains on either side of the route, so below the highest terrain. Often they would do this IFR with no ground NAV, no GPS, and almost no IFR instrumention. All they used (as standard service, not as emergency coping), was an attitude indicator, a whisky compass, and a clock, for timed turns in the clouds - remember tall mountains on either side. And it actually worked - usually - I guess except for sometimes it didn't.... Quote
201er Posted October 8, 2015 Report Posted October 8, 2015 "...I think an aircraft panel clock should have this capability..." If you want to spend on a clock what you can spend on entire ipad, then be my guest. Quote
PTK Posted October 8, 2015 Report Posted October 8, 2015 (edited) If you want to spend on a clock what you can spend on entire ipad, then be my guest. How much is that? A clock is required IFR equipment. An ipad is not. Even if it was, I can't put it in the clock spot in my panel and I can't even get a used one for as little as I paid for my brand new Davtron clock! Thank you for your permission and concern by the way! Edited October 8, 2015 by PTK Quote
RobertGary1 Posted October 8, 2015 Author Report Posted October 8, 2015 Yes, I was assuming TSO'd clocks that could legally replace the panel clock for IFR. -Robert Quote
romair Posted October 8, 2015 Report Posted October 8, 2015 Here is one that it's cheaper. That's what I have. I thought that moving to the digital display would make more sense. In retrospect, I should've left the old one in that was perfectly functional. I just never needed to use it so far... http://www.aircraftspruce.com/catalog/inpages/ei-chronometers.php Quote
RobertGary1 Posted October 8, 2015 Author Report Posted October 8, 2015 Here is one that it's cheaper. That's what I have. I thought that moving to the digital display would make more sense. In retrospect, I should've left the old one in that was perfectly functional. I just never needed to use it so far... http://www.aircraftspruce.com/catalog/inpages/ei-chronometers.php I like that. A very nice clock. And if I decide to do my ATP I'll look cool timing all those approaches. -Robert Quote
Jerry 5TJ Posted October 8, 2015 Report Posted October 8, 2015 I decided to upgrade my yoke clock which had been dead for a while. The replacement keeps good time to the millisecond, and has other features the old clock lacked (Terrain warnings, XM weather, GPS moving map) and it cost about $500. Quote
RobertGary1 Posted October 8, 2015 Author Report Posted October 8, 2015 I decided to upgrade my yoke clock which had been dead for a while. The replacement keeps good time to the millisecond, and has other features the old clock lacked (Terrain warnings, XM weather, GPS moving map) and it cost about $500. But you're not going to use it as an FAA certified clock per §91.205(d)6 on a checkride. -Robert Quote
