You might have qualified for nomination to the CB of the Month award had it not been for the fact you paid $0.01 for the bobby pin. A true CB would have went to a salon and asked if they had one laying around. ;)
Good tip. Sometimes you have to remove the pin because the wire broke off thus no wire to pull the pin. Insert the Bobbie pin and with a jeweler's screw driver push out the pin. If you have room behind the tray you can do this and reinstall the wired pin without removing the tray. If your hands don't fit in the tray attach the Bobbie pin and screwdriver with safety wire to two thin shafts and push the pin out. The tray is usually riveted to the panel frame.
José
