Mooneymite Posted August 18, 2016 Report Share Posted August 18, 2016 41 minutes ago, Smiles201 said: Report mentions cam lobe was worn. Reason for lack of full power? " The fuel manifold was removed during the examination of the engine and placed on a test bench and did not flow when tested up to 7 psi (normal test pressure is 4.5 psi). " Quote Link to comment Share on other sites More sharing options...
Andy95W Posted August 18, 2016 Report Share Posted August 18, 2016 A few other fuel related notes from the report: "The bottom of the movable portion of the body assembly was pushed by hand and some resistance was noted at first, but it then moved." " The fuel manifold was placed on the test bench and debris was noted coming from the ports during initial flow." "Test bench fluid was noted on the top side of the diaphragm (air side) and some slivers of material were also noted." "The movable portion of the body assembly was removed and contamination/debris was noted. " "Re-insertion of the movable portion of the body assembly into the body revealed slight binding." Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted August 21, 2016 Report Share Posted August 21, 2016 Perhaps an edm with FF would have shown warning signs leading up to this. If FF wasn't normal, it could have been quantified leading to a better pilot decision. 1 Quote Link to comment Share on other sites More sharing options...
