thanks. i need to open that POH more often.
the stock gage needle rarely barely makes it to the low end of the green arc and rarely reaches the "F"
the engine monitor probes I have indicate in the 350 to 370F which is more like it.
Will a new probe help close the gap ?
makes sense but does the needle on your indeed goes over the"F" ?
i am wondering if my sensor is tired or if mt cluster gage needs to be calibrated
are you implying that the stock factory gauges are possibly inaccurate?  no way.
Mine does the same thing. The last time up it the needle was just past the 250 mark - right between the 250 and the beginning of the green arc and never got hotter. JPI showed 350. It's in the shop right now for the annual so I'm going to have it looked at.
