On my 63C, I have a avionics cooling vent (front left)... Can it be opened and closed? Is it needed when I have an avionics cooling fan? It lets the cold air inside during winter...also not sure when flying in rain if water is getting inside. Keep it for back-up cooling or plug it? Do all mooneys have this or did it go away?
Thanks
My 65 C had a vent from the passenger side scoop.  It routed air to a 'distribution' air box made of Royalite (I think that was the material) forward of the avionics area.  It did not do much to cool anything.  Yes, some water did come in via that vent when flying in rain, though not much.    During a total avionics upgrade in 2013 I scrapped all of that old "cooling" system and put in an avionics fan that pulls air from the cabin.
My 64 E has one. There is a small flapper in the small line right above the scoop. It can be seen from the outside and can be closed with a small handle on the inside. Not the easiest to get to with the interior panel, but if you know where it is it's not bad. I think it helps keep the overall stack cool in summer, but is not required if you have a fan. I close it in the winter.
My 65C was as Jerry described. The royaltie was broken down pretty bad and cold air would flow in the winter. Find the source of the cooling hose....
Fans would be an upgrade to this system. Even modernish radios produce a fair amount of heat...
Having a system that could modulated the amount of air would be nice??? And direct to the target instead of on the people.
Seeking professional advice would probably be a good idea at an instrument shop in your neighborhood.
The new stuff will not tolerate moisture.  Most install manuals now say to use a fan and not connect to ram air.  Here is a Garmin 340 that belongs to a friend of mine.  Its about 4 years old.  They are not even conformal coating the boards.  Garmin refused to even attempt to repair it because of the corrosion.(Which I agree with)
post-7624-0-19908600-1389036470_thumb.jp
