Aircraft Selections
21 members have voted
  1. 1. If funds were no factor, which aircraft would you pick?
    • Cessna Caravan 208B
      16
    • Piper PA-31 Navajo Cheiftan 350
      3
    • Cessna 402C
      2
  2. 2. Single Engine Turbine or Piston Twin
      17
    • Piper Navajo/Cessna 402
      4
  3. 3. Which Piston Twin if funds do not allow a turbine
    • Piper PA31 Navajo Chieften 350
      11
    • Cessna 402C
      9
    • Other large piston twin - name it below
      1
Now multiply them and square the product for the roundtrip reliability.  Answer:  66%.
Is that good enough for people with money and important appointments?
I agree with all that you wrote. This is a tough sell IMO. I only take issue with your reliability formula. I'm certain a higher than 66% dispatch rate can be achieved.
DaV8or,
Is the issue with the formula or the numbers?
Those were only notional numbers. And, of course, it assumes wx, mx, and crew are independent. If they're not, it could be worse.
Insert numbers that you think are more appropriate, but even at 95% wx, 95% mx, and 95% crew, you still get only a 74% chance of completing the roundtrip.
(.95*.95*.95)^2 = .735
FWIW, according to avbuyer.com, individual aircraft availability is around 85%, and the major airlines are around 95% dispatch reliability (i.e., 90% for a round trip), and that's with spare aircraft/crews, turbine equipment, and long MEL's.
The BN2 (islander) is going to be the most cost efficient , both in acquisition , and in maintenence , Even if the others are 60 + knots faster on a 80 mile trip the difference is nominal as the approach and climb out will eat up approx. 40% of the mission , The problem as I see it is the weather aspect , as far as I know there are no precision approaches , and because of the SFRA you will always be under radar control , I don't think it will be (reliable) enough to be Viable.....
