BigTex Posted December 18, 2013 Report Posted December 18, 2013 I considering treating myself to a new handheld Nav/Com transceiver for Christmas. I'm leaning towards an Icom IC-A24 but before pulling the trigger, I'd be interested in what everyone else thought would be a good choice?
N601RX Posted December 18, 2013 Report Posted December 18, 2013 I purchased the Yeasu FTA-720 during the Oshkosh sales this year. It's very well built with a mageniusm case instead of plastic. I think I started a thread about it when I purchased it. I did it start the thread, but here is the thread. Scroll down close to the bottom and you can see a picture. Very small, includes headset adaptor and excellent Li battery life. It's also waterproof and includes the fm radio band. http://mooneyspace.com/topic/10048-interesting-mystery/?hl=yaesu#entry115658
larryb Posted December 18, 2013 Report Posted December 18, 2013 I have the yasu spirit which looks similar to the Yaesu FTA-720. The icom is an older design and has an older ni-mh battery. Yasu is smaller and has a LiOn battery. I haven't used it much but seems to work well.
timpercarpio Posted December 18, 2013 Report Posted December 18, 2013 I got the one from Sporty's about eight years ago and have been happy with it.
201er Posted December 18, 2013 Report Posted December 18, 2013 Here's my advice. Since you're never gonna use the darned thing except in an emergency, don't get anything fancy. The most important thing in my mind is the ability to take AA batteries. I have a Vertex handheld that goes unused for a year at a time. Then when I want it, turns out the rechargeable battery is dead. I had this happen where from disuse it killed the battery and it would not recharge any more. So when I bought a new rechargeable battery for it, I also bought a AA adapter. Now I keep those 10+ year Lithium AAs in that pack and I always have some kind of spare AAs around. 4
Danb Posted December 18, 2013 Report Posted December 18, 2013 I have a sportys sp 400 which I'm happy with.
Hank Posted December 18, 2013 Report Posted December 18, 2013 I have Sportys radio in my flight bag with the headset adapter plugged in. The batteries are AA NiMH, with regular Duracells in a second pack so I can replace the whole thing and not fumble with individual batteries (try that in IMC!). So far, the only time I needed it, it was in the hangar while I was on an IFR training flight. Now it lives in the plane.
OR75 Posted December 18, 2013 Report Posted December 18, 2013 I have an Icom. The battery life is such that the radio is only useful in 2 instances - Listening to ATC on the ground (ATIS) while being plugged to the wall - emergency IF you have the right battery set with you. (I don't even know how long a fresh set battery of batteries will last since my radio have been reliable.
bdjohn4 Posted December 18, 2013 Report Posted December 18, 2013 Sportys SP-400 Hand-held NAV/COM. Just for fun, I've flown a simulated ILS and the damn thing is really accurate (GS/LOC). I have two AA battery packs (8 AAs/pack; same AA batteries that go into my lightspeed Sierras... so I have plenty AAs with me at all times... don't drop the packs... the little tabs are apt to break off). I also got the push-to-talk and GA plug adapter. Most importantly, I have a mount that can go on the windshield area steel roll cage down-tube in case I really need it for an ILS emergency. I sometimes have it set up and tracking on an ILS just in case I lose the ILS at a critical period (safety first). FYI: my mag compass is down on the panel now, so that is out of the way.
Mooneymite Posted December 18, 2013 Report Posted December 18, 2013 . Living in a fly-in community, my handheld gets a fair amount of use.....on the ground. On the occassion when I tried it from the Mooney cockpit, I was disappointed with the very limited transmission range. If you're serious about a hand-held for back-up comm in flight, consider an external antenna splitter. I don't have one, but I should! .
N601RX Posted December 18, 2013 Report Posted December 18, 2013 Agree, I've used mine much more on the ground than in the air. Be careful with the spitter, you can blow the reciever out in the radio that is not transmitting. A carefully placed bnc connector or coax switch will work better.
tony Posted December 19, 2013 Report Posted December 19, 2013 I have two BNC connectors in the cockpit, one goes to the radio, the other to the antenna. During normal ops I fly with a jumper installed. In the case of a power failure, I remove the jumper and connect the handle held to the external antenna. works... I have the ICOM A24
rainman Posted December 21, 2013 Report Posted December 21, 2013 +1 on the Sporty's, note that range is limited unless you have a connection in your panel and a cable from the radio to connect to the external antenna. I did use it once in an emergency while flying and it did the trick. Always keep it in my flight bag. I do like the look of the Yasu.
Oscar Avalle Posted December 21, 2013 Report Posted December 21, 2013 I have a Vertex and it works well to get the clearances and ATIS. 1
Marauder Posted December 21, 2013 Report Posted December 21, 2013 I have a Vertex and it works well to get the clearances and ATIS. +1 on the Vertex. I found a Chinese company that sells Vertex lithium battery packs cheap and loaded up on them.
