Same thing happened to me recently.  2 hours on a charger was enough to at least get it cranked (can't remember amperage).  The following flight was 3 hours, and it seems to be fine now.
In my experience, it depends on the length of time it was discharged. If a battery is completed run down and lsft that way for 2 weeks, it may be ruined. Over night seems not to be a problem. Don't ask me how long is too long.
Don
I agree with Don. Running a battery flat DOES take a bit life out of it. Allowing it to stay flat for an extended period of time will kill it.
Being left discharged is bad for the battery and can damage it as stated here.
Being discharged in freezing conditions can kill it immediately. When a lead acid battery is discharged the specifit gravity of the electrolyte drops and like water it can freeze. If the fluid freezes it can swell the case and crush the plates.
