I decide to add a used GEM-602, yes it is not as nice as the new stuff but I only had the single stock units until now.
The question is how do you put one in a 3.5 inch hole?  I was thinking no problem, bought the adapter plate and then after drilling the hole for the push button in the adapter reality hit.  There is not enough room around the unit to put nuts on the back side of the 3.5 inch holes.
What have others done?
Tim (get that right?),
I have mine mounted in a 2.5" hole but the theory should be the same. The adapter plate will mount to the 3.5" hole using screws and nuts and the GEM mounts to the adpater plate using screws only. There shouldn't be any nuts involved with the GEM unit itself. The GEM should have threads to accept machine screws. Am I missing something?
Chris,
The size of the GEM unit interferes with the nuts for the adapter plate on the 3.125 holes (actually about 3.5 inch diameter for the holes).  The 602 (603 and 610 as well) is 3.6 inches across at the corners and there is no room for the nuts for the screws that hold the adapter plate in place. The 602 will mount on the plate with the screws as you said, but it blocks the holes at the larger diameter and leaves no room for a nut.  I have not come up with an elegant solution so far using the adapters and current holes.  I can drill holes 45 degrees off that would work but will require drilling in the panel as well.  I was hoping to use existing cutouts in the panel
Thanks,
Tim
Cris, thanks for the link. That does look like the perfect solution other than cost. I will call but I think I found the price on the webpage, only $90 for the adapter. I think I will try the sheet metal screws first.
