KSMooniac Posted January 14, 2010 Report Posted January 14, 2010 Brian, I'm just down the road from you in Wichita and would be happy to help/fly just about anytime. Another Mooney buddy here and I are even talking about a BBQ run to Paola (K81) very soon...possibly this weekend. Even if your ASI bench-checks OK, you could still have something amiss with the rest of the system. You might have to simply trace the pitot and static lines all the way thru the airframe and look for a problem.
flight2000 Posted January 14, 2010 Author Report Posted January 14, 2010 Would love to go and meet you guys, but my aircraft will be captive for about two more weeks. I'm excited to see the new panel instead of the old shotgun. I'll take you up on that offer once the dust settles after the paint shop does their thing in February. Brian
Piloto Posted January 14, 2010 Report Posted January 14, 2010 Quote: eaglebkh I'll have to say, though, in the picture the IAS appears to be very high in the yellow arc and I never see that at 3500' - maybe with everything firewalled.
Immelman Posted January 14, 2010 Report Posted January 14, 2010 I have a 66E +cowl closure, 1-pc belly (I don't believe the latter should add any speed) - a bunch of antennae, and my LMG hangs down just a hair into the slip stream, probably costing me speed THe speed tests I have done have been at higher altitude -- the first test @ 7500 was on a warm day and thus I think about 2000' above the optimal speed altitude Speed test 1: Pressure altitude 7500 OAT 17C MP 23.75 RPM 2500 Density altitude 9428 Headings Ground speed KT IAS mph IAS KTN 153 151 W 143 150 130.25S 142 150 130.25E 151 150 130.25 TAS (calculated on IAS) 149.7 TAS (calculated on gnd speed) 147 Solo weight, full fuelSmooth air (consistent IAS)Ram air onIndicated RPM = 2450 (tach reads 50 low)Mixture leaned to 100+ ROP --- Speed test 2: I was crossing the Sierra and had leaned TO peak and wondered what my economy was, so I did a 4-way speed test run and noted the numbers. This, I think, is where our airplanes do well in terms of efficiency Date 11/1/2009 Conditions: Pressure altitude 13111 OAT 0C MP 19 RPM 2500 Density altitude 14400 Fuel flow 7.5-7.8gph Headings Ground speed KT IAS mph IAS KTN 134 131 113.75W 123 S 147 E 152 TAS (calculated on IAS) 141.5 TAS (calculated on gnd speed) 139 Notes Solo weight + 30 lb, 14 gallons off of full fuel Smooth air (consistent IAS) Ram air on Indicated RPM = 2450 (tach reads 50 low) Mixture leaned to peak
Cruiser Posted January 14, 2010 Report Posted January 14, 2010 I might have misread something in your picture. My comments are based on the information you have there. I looks like you indeed were very straight and level at the time the picture was taken. AI and T&B are perfect. If your DG was set correctly you are on a heading of 100° and it looks like the CMG on the Garmin is 124° (hard to see) I can make out the 183 assuming that it is in kts. and the 160 kts on your inner ring of the ASI. Also your Alt shows 3500'. With that info using an E6B your wind speed and direction should have been from 11° @ 74kts. I would agree with others here ...... take a good look at the static system and the ASI. TomK
HRM Posted January 14, 2010 Report Posted January 14, 2010 Quote: flight2000 Question for my fellow E owners. Is my bird that much more different in the fact that I can routinely get 155 kts indicated at 3500 ft and 25 squared? I haven't had the opportunity to go higher yet because of the shorter trips I've been taking and the class B that sits over my airport. The ferry pilot that brought up my plane from Texas in December told me he was seeing 160 kts indicated at 7,000 ft (he's a 201 owner). The only mods I have on the plane are the 201 windshield and the lower cowl enclosure (unless you count the GAMIs that are installed as a mod as well). I'm only seeing fuel burn around 9-10 gph so I'm not burning the tanks up seeing these speeds. Thoughts? Thanks, Brian '67 E Model
eaglebkh Posted January 15, 2010 Report Posted January 15, 2010 Quote: HRM I am counting on the fact that the Mooney engineers allowed for at least 10% on Vne.
Immelman Posted January 15, 2010 Report Posted January 15, 2010 Regarding Vne...here is a little bit of extra information: I remember reading somewhere that control surface flutter phenomena are based on true, not indicated airspeed. At a certain true airspeed, flutter can start to occur and that would impose forces on the airframe which might ruin your day quickly. The take-home I got from this was that while Vne should always be respected, your margin of safety when descending from a high altitude at airspeeds close to Vne might be much less than when close to sea level density altitudes. With all this said -- one more speed experiment, in addiiton to the ones I posted above: Down low near sea level with everything wide open I can see somewhere between 180-185mph indicated, Vne=189. However, I regard this as pretty useless since its at close to 100% power, full rich, and thus close to 18gph! Fly safe!
scottfromiowa Posted February 4, 2010 Report Posted February 4, 2010 Has anyone read the MAPA article n the M20E by Kromer? I always fly at 25 squared and lean to 50 degrees rich of peak...I have NO cooling issues and fuel burn is fine...and as Jack says plane was designed for full throttle all the way to TBO and you get better cooling in the climb, so why sacrifice airspeed?
Guest Anonymous Posted February 4, 2010 Report Posted February 4, 2010 Quote: Cruiser I might have misread something in your picture. My comments are based on the information you have there. I looks like you indeed were very straight and level at the time the picture was taken. AI and T&B are perfect. If your DG was set correctly you are on a heading of 100° and it looks like the CMG on the Garmin is 124° (hard to see) I can make out the 183 assuming that it is in kts. and the 160 kts on your inner ring of the ASI. Also your Alt shows 3500'. With that info using an E6B your wind speed and direction should have been from 11° @ 74kts. I would agree with others here ...... take a good look at the static system and the ASI. TomK
flight2000 Posted February 4, 2010 Author Report Posted February 4, 2010 Static system is fine. They traced all of the lines while they had the interior apart and found no leaks or issues. All of the tubes are perfect and no crimps anywhere. The AI and ASI were sent out for rebuild and recalibration. The ASI was reading 7kts high, so the instrument shop redid the calibration. The AI was getting ready to fail from worn parts, so I had them overhaul it as well. Basically a brand new AI at 1/3 the cost of a new one. I should get her back next Friday finally. I'm looking forward to seeing the final product after several long weeks while getting the instrument panel facelift and new radios installed. Brian
airkraft Posted February 4, 2010 Report Posted February 4, 2010 HRM, Maybe I missed something, but ground speeds are completely irrelevant to this discussion. Your GPS and the tracking services only know speed over the ground; not indicated or true airspeed.
HRM Posted February 5, 2010 Report Posted February 5, 2010 Quote: airkraft HRM, Maybe I missed something, but ground speeds are completely irrelevant to this discussion. Your GPS and the tracking services only know speed over the ground; not indicated or true airspeed.
airkraft Posted February 6, 2010 Report Posted February 6, 2010 HRM, Uh, yes, as I agreed with Magnus earlier in this discussion, an average of the four cardinal ground speeds is one of the best ways to establish true airspeed.
HRM Posted February 6, 2010 Report Posted February 6, 2010 Quote: airkraft HRM, Uh, yes, as I agreed with Magnus earlier in this discussion, an average of the four cardinal ground speeds is one of the best ways to establish true airspeed.
airkraft Posted February 8, 2010 Report Posted February 8, 2010 HRM, I should have re-specified averaging GPS ( or radar) groundspeeds. This WILL provide a very accurate measure for true airspeed at the particular power setting and density altitude.
rob Posted February 8, 2010 Report Posted February 8, 2010 The 4 cardinal direction groundspeed average will not be as accurate as a little simple trig (the formulas are well published and easy to locate) on the same four course run. Do yourself a favor and do the real math.
Magnum Posted February 8, 2010 Report Posted February 8, 2010 Quote: rob The 4 cardinal direction groundspeed average will not be as accurate as a little simple trig (the formulas are well published and easy to locate) on the same four course run. Do yourself a favor and do the real math.
