ighazali Posted November 23 Report Posted November 23 Hey everyone not sure if this is concerning. My current oil consumption is about .13qt per hour so essentially 1 quart every 7.6 hrs. Today when looking through the cowl flap door where the breather tube and blowout valve is I saw some oil on an intake pipe. Any ideas if the O-ring may need to be replaced. Oil pressure and consumption seem to be okay. Oil analysis also came back stating a healthy engine.
N201MKTurbo Posted November 23 Report Posted November 23 Most likely running down from above. There is no oil behind the O-rings. 3
ighazali Posted November 23 Author Report Posted November 23 1 hour ago, N201MKTurbo said: Most likely running down from above. There is no oil behind the O-rings. Thanks! So nothing to be concerned? Also is the oil burn normal?
LANCECASPER Posted November 23 Report Posted November 23 7 hours ago, ighazali said: Hey everyone not sure if this is concerning. My current oil consumption is about .13qt per hour so essentially 1 quart every 7.6 hrs. Today when looking through the cowl flap door where the breather tube and blowout valve is I saw some oil on an intake pipe. Any ideas if the O-ring may need to be replaced. Oil pressure and consumption seem to be okay. Oil analysis also came back stating a healthy engine. When you say "new engine" is this a factory overhaul or re-man, an engine specialty shop overhaul or a field overhaul?
Aaviationist Posted November 23 Report Posted November 23 Also the fact that that it can’t be coming from the intake doesn’t mean “nothing to be concerned about” you need to find where it’s coming g from to make that determination. 1
skykrawler Posted November 23 Report Posted November 23 New engine? I guess those are Teflon hoses (replace on condition), otherwise they look kind of oldish. Sources of oil from 'up above' include the rocker box gaskets, rocker box drain B nut connections, intake manifold gaskets, push-rod tube seals, and even exhaust flanges. Engines that 'pool oil' in the cylinder at shutdown can leak it at the intake and exhaust stack connections. One mode of this is oil coming down the valve stems. The #2 intake runner is most susceptible to chewing it's gasket due to it's length. If it doesn't leak out the flange it will likely end up in the induction chamber where the four intake runner connect. The next time you flood the engine some oil will wash out the sniffle valve. But....what you're seeing is a relatively small amount of oil compared to a quart. IMHO. 1
N201MKTurbo Posted November 23 Report Posted November 23 6 hours ago, ighazali said: Thanks! So nothing to be concerned? Also is the oil burn normal? It doesn’t sound like you are going to run out of oil, but it should be fixed, if for no other reason, so your airplane doesn’t look too ghetto. 1
Flyler Posted November 23 Report Posted November 23 Lycoming says allowable oil consumption is up to about .65qt per hour for your motor. So you are far from that. 1
Ragsf15e Posted November 23 Report Posted November 23 So to “Carusum” (summarize), 1 qt in 7 hours is just fine but you should look into it because something isn’t right and it won’t get better by itself. It’s probably not urgent. 1 1
cliffy Posted November 23 Report Posted November 23 I hate oil leaks! I want my engine to rust away from the outside not be preserved in a bath of oil! :-) My guess is the rocker cover drain tubes hose couplings above. Just found my prop governor cap leaking on last trip so off it comes next week in annual. Antique airplanes take constant maintenance just like old Rolls Royces !! :-) Don't fall behind on the job. 1
ighazali Posted November 23 Author Report Posted November 23 6 hours ago, LANCECASPER said: When you say "new engine" is this a factory overhaul or re-man, an engine specialty shop overhaul or a field overhaul? It is factory overhaul was done back in 2023 only has about 100 hours on it 1
Jsno Posted November 23 Report Posted November 23 Your oil return line clamps probably need tightened. 3
ighazali Posted November 26 Author Report Posted November 26 Had a A&P check it out he said that I was missing a screw on the cylinder head cap which is the grey caps towards the top of the engine, however that cylinder was not the issue. He said the front cylinder cover cap had a bit of oil so it might be the gasket. However, he tighten the cylinder head cover cap and then told me to keep an eye on it. If it still leaks it may need new gaskets where the cap goes. Will keep you guys updated. 1
Ragsf15e Posted November 26 Report Posted November 26 9 minutes ago, ighazali said: Had a A&P check it out he said that I was missing a screw on the cylinder head cap which is the grey caps towards the top of the engine, however that cylinder was not the issue. He said the front cylinder cover cap had a bit of oil so it might be the gasket. However, he tighten the cylinder head cover cap and then told me to keep an eye on it. If it still leaks it may need new gaskets where the cap goes. Will keep you guys updated. Those square caps cover the rockers and are a common leak source. When you look closely at them, see if you can tell what kind of gasket is in there. There’s an older cork (or paper?) one and a newer silicone type (Ive seen orange). Both can leak if too loose or too tight, so that sucks. I have had better luck with the silicone ones. 1
Nico1 Posted November 26 Report Posted November 26 On 11/23/2025 at 3:55 PM, Jsno said: Your oil return line clamps probably need tightened. Check this. Follow oil return lines Under the cylinders, pita to reach. 2
ighazali Posted December 4 Author Report Posted December 4 On 11/25/2025 at 9:49 PM, Ragsf15e said: Those square caps cover the rockers and are a common leak source. When you look closely at them, see if you can tell what kind of gasket is in there. There’s an older cork (or paper?) one and a newer silicone type (Ive seen orange). Both can leak if too loose or too tight, so that sucks. I have had better luck with the silicone ones. It looks like a paper type I might just do new silicone does anyone have a part link?
ighazali Posted December 4 Author Report Posted December 4 This is the picture on the pilot side. The front silver tube has a few drops of oil right at the bottom of it.
ighazali Posted December 4 Author Report Posted December 4 On 11/25/2025 at 9:49 PM, Ragsf15e said: Those square caps cover the rockers and are a common leak source. When you look closely at them, see if you can tell what kind of gasket is in there. There’s an older cork (or paper?) one and a newer silicone type (Ive seen orange). Both can leak if too loose or too tight, so that sucks. I have had better luck with the silicone ones. Is this what you suggest for the IO-360-A1A. https://www.aircraftspruce.com/catalog/eppages/siliconecalvecover_08-01314.php
N201MKTurbo Posted December 4 Report Posted December 4 This is the one you need: https://www.aircraftspruce.com/catalog/eppages/siliconecalvecover_08-01316.php 1
PT20J Posted December 4 Report Posted December 4 27 minutes ago, N201MKTurbo said: This is the one you need: https://www.aircraftspruce.com/catalog/eppages/siliconecalvecover_08-01316.php @Gee Bee Aeroproducts makes some that have a reinforcing fabric layer sandwiched in between two layers of silicone so that they hold their shape better under pressure. I had a rocker cover leak and it turned out to be a pinhole defect in the cover itself. 1
N201MKTurbo Posted December 4 Report Posted December 4 14 minutes ago, PT20J said: @Gee Bee Aeroproducts makes some that have a reinforcing fabric layer sandwiched in between two layers of silicone so that they hold their shape better under pressure. I had a rocker cover leak and it turned out to be a pinhole defect in the cover itself. But I can’t get them from spruce. I’m spoiled, I can order them from Spruce and pick them up 1/2 hour later. 1
Yetti Posted December 4 Report Posted December 4 That oil is running down the engine block and collecting there. Most likely place is the Oil drain back tube clamps. 2 clamps over some rubber hose. If you have the thumb screw type, they can be tightened with a 1/2" or 7/16" 6 point socket since it will fit over the thumb part. A 1/4" drive set with some flexible joints will make getting to them possible. A flexible socket drive should work for hex style band clamps. 1
MikeOH Posted December 4 Report Posted December 4 Another 'vote' for the oil drain back tubes; specifically, the short rubber section between the 'hard line' and the case. Mine were hard, cracked and therefore not sealing.
Gee Bee Aeroproducts Posted Wednesday at 01:56 PM Report Posted Wednesday at 01:56 PM We stock Std2180 hose in Flurosilicone with two lined breeze clamps
