redbaron1982 Posted January 27 Report Posted January 27 16 minutes ago, tankman said: Good question. When the landing gear is jacked up, your lifting at knee joint, this allows the gear to swing down. This removes the compression load on the pucs and allows them to expand as much as possible. This is the evaluation that is performed during the airframe annual inspection when the plane is raised on wing jacks. You can see the wheel swing down in the video. Thanks, https://www.youtube.com/shorts/UY_9IYvVkn4 Oh, now I see, the wheel fwd/aft movement is directly linked to the pucs, so reducing the load on the wheel make it move fwd and allows the pucs to expand. Thanks!
Max Clark Posted January 27 Report Posted January 27 1 hour ago, redbaron1982 said: Maybe a stupid question, but how this helps the pucs? The airplane weight is still on the pucs. If any, the only thing you are helping is the tire itself. I was trying to figure that out as well. Isn't the shock link connected to the same point that the jack is? Also can someone help me with what wear and tear/future expense these are saving us from?
EricJ Posted January 27 Report Posted January 27 29 minutes ago, Max Clark said: I was trying to figure that out as well. Isn't the shock link connected to the same point that the jack is? Not the same point but the same part. The jack might reduce the force on the pucks a bit since the lever arm is smaller. 29 minutes ago, Max Clark said: Also can someone help me with what wear and tear/future expense these are saving us from? Pucks seem to last for decades, so I have the same question. Puck aging seems to be more about sunlight and environmental exposure than whether they have weight on them. 2
IvanP Posted January 27 Report Posted January 27 25 minutes ago, Max Clark said: I was trying to figure that out as well. Isn't the shock link connected to the same point that the jack is? Also can someone help me with what wear and tear/future expense these are saving us from? I replaced my pucks in 2023 - parts were about $1,200 then if I recall. Today's pricing on Spruce is $1,980 for full set. Add labor as neeeded. I think it took me about 5 hours or so..
LANCECASPER Posted January 27 Report Posted January 27 5 hours ago, EricJ said: Not the same point but the same part. The jack might reduce the force on the pucks a bit since the lever arm is smaller. Pucks seem to last for decades, so I have the same question. Puck aging seems to be more about sunlight and environmental exposure than whether they have weight on them. Not on long bodies (especially with extended range tanks left nearly full) . I think Don Maxwell was mentioning that on heavy long bodies that they don't pass the test after about 6 years. 2
tankman Posted February 8 Report Posted February 8 Each year during the annual inspection, the plane is supposed to be jacked up off the floor. This takes the weight off of the disks/pucs. This allows the disks/pucs to to expand back to an uncompressed condition. The disks/pucs are inspected with an “on condition” criteria. They are inspected for any cracks, deterioration or bulging. The tire/wheel is lifted up and down to determine if there is any play/movement on the disk tower. If there is no movement, the disks/pucs have expanded indicating a satisfactory condition. If there is play, this indicates that the disks/pucs rubber has harden to a state that has very little resiliency. This is demonstrated by the height difference shown in the picture of the 2 stacks of disks/pucs. New disks/pucs are one inch high. The disks/pucs should be replaced at this point. 1
47U Posted February 8 Report Posted February 8 1 hour ago, tankman said: The disks/pucs are inspected with an “on condition” criteria. They are inspected for any cracks, deterioration or bulging. The tire/wheel is lifted up and down to determine if there is any play/movement on the disk tower. If there is no movement, the disks/pucs have expanded indicating a satisfactory condition. As many have posted previously, old on the left, new on the right. The vintage shock disc retainer bottom plate wasn’t flat. You can see the slight dome on the top disc, which was on the bottom of the stack on the airplane. I think they were last done in the mid-late ‘90s? I’ll have to look at the date code/logbook. Another change between the vintage shock disc retainer and new production… the new retainer allows the disks to stand taller because the bottom plate is lower, closer to the bottom mount. The overall height is virtually identical. It won’t take much compression to get the collar and bolt installed. I didn’t like the condition of the old retainers… and what would they look like in another 20 years? With less static compression, maybe the discs will last a little longer. (Mooney had them in stock… but oh, boy. Eye watering amu’s, more than 4 amu for the pair.)
kortopates Posted February 8 Report Posted February 8 13 minutes ago, 47U said: (Mooney had them in stock… but oh, boy. Eye watering amu’s, more than 4 amu for the pair.) Lasar has their own PMA version of these which were half the cost of the factory shock disk towers. Many fail to visually check inside the tubes at the bottom for corrosion. It only takes 1/10 of loss of the tubing thickness from rust to render them unairworthy. I squirt some ACF50 into the bottom to prevent rust from water getting in there; but LPS3 and many other things would work as well. 2
IvanP Posted February 8 Report Posted February 8 I just got a set of savers from Carl. Noticeable expansion of the discs when I lifted the plane. I use the cheap Harbor Freight 4 ton jacks - drilled holes in the bases and put small screws in to keep the jacks from sliding around. Overall, I lke the product. Takes only couple of minutes to lift the plane on them after flight.
tankman Posted February 13 Report Posted February 13 The ability of the puc to expand when the load is removed determines its useful life. The expense of replacing the disks/pucs is approximately$2,500 to $3,000. The pucs resiliency on a long body lasts about 5 years due to the weight of a long body. For short/mid bodies, the life is around 10-12 years.
GeeBee Posted February 13 Report Posted February 13 Somehow, oleo struts are looking better and better.
Max Clark Posted February 13 Report Posted February 13 3 hours ago, GeeBee said: Somehow, oleo struts are looking better and better. I heard a rumor about this - is anyone actually working on pulling this off?
IvanP Posted February 13 Report Posted February 13 1 hour ago, Max Clark said: I heard a rumor about this - is anyone actually working on pulling this off? As appealing as oleostruts may be, it would lkely require major changes in the gear system and STC. The cost v. benefit analysis may not be favorable for such endeavor.. 2
Sabremech Posted February 14 Report Posted February 14 Having done plenty of shock disk changes, I don’t see how this would make a difference to shock disk longevity on the nose gear. They are under heavy compression all the time unlike the main gear. I could see this helping possibly extending the life of the mains but not sure by how much. Are they worth the investment on any other model than the long bodies? I’m not sure. David 2
LANCECASPER Posted February 14 Report Posted February 14 6 hours ago, Max Clark said: I heard a rumor about this - is anyone actually working on pulling this off? The factory was working on a gross weight increase that would have included struts. That project was put on hold about 5 years ago.
IvanP Posted February 14 Report Posted February 14 2 hours ago, Sabremech said: Having done plenty of shock disk changes, I don’t see how this would make a difference to shock disk longevity on the nose gear. They are under heavy compression all the time unlike the main gear. I could see this helping possibly extending the life of the mains but not sure by how much. Are they worth the investment on any other model than the long bodies? I’m not sure. David Yes, the nosegear discs are under higher cmpression than the mains. Still, lifting the plane reduces the weight on the discs which could arguably extend the longevity of the discs in teh nosegear as well. I have seen some Mooneys with very tired nose gear discs. Time will tell.
DonMuncy Posted February 15 Report Posted February 15 I think that it is pretty well agreed that the weight compressing the discs is a major factor in how long they last, as evidenced by the fact that the heavier late model planes require more frequent disc replacement. If that is true, keeping the weight off the discs, as these Puck Savers do, would almost certainly be helpful in extending the life of the discs. It would seem that the only questions would be how much their life is extended, and whether it is worth the extra time and effort necessary to put the Puck Savers in place each time you put the plane in the hangar. It seems that a lot of plane owners think they are going to be flying again in a few days, so they may reason that it isn't worth the x extra minutes it takes to hook up the Battery Minder, jack up three Puck Savers, put plugs in the air intakes, hook up the engine desiccator, etc. 1
DonMuncy Posted Monday at 09:31 PM Report Posted Monday at 09:31 PM Upon further reflection, it occurred to me that there appear to be only a few factors that should affect landing disc life. UV light should probably be one, but as a large number of us hangar our planes, I reason that UV light should not be a major contributor to their useful life. I also assume the mere aging probably has some effect. Has anyone had, or seen any real evidence of the aging factor? Have you stored pucks for an extended period of time, and done any analysis of how that affected their life? We have also seen extensive discussion about temperature. It would seem this is not a super contributor, or at least we can't do a lot to change the result. So we are back to compression of the discs. Since it seems likely that the time the weight of the plane is on the discs, is likely far less then 1% if the plane is on jacks or Puc-Savers when not the plane is not flying, it seems likely that the disc life should be GREATLY affected by the use of weight relieving methods. Unless someone can come up with a way to simulate long term disc compression and measure the effects, it would appear that keeping your plane on Puc-savers (or jacks; including a jack for the nose gear) should almost certainly be highly beneficial to longevity of the discs. Are there factors I am missing. Is my logic flawed?
Hank Posted Monday at 09:50 PM Report Posted Monday at 09:50 PM Age is a factor, as is weight on the pucks. The pucks are rubber, and volatiles migrate outsider time, leading to stiffer, less flexible pucks. Weight on the pucks will compress them over time, making it difficult for them to expand enough over time. Combining these two effects is what we see. Keeping weight off the pucks should extend their life, but there is still the age-hardening effect. No one right now knows how much each contributes to failing the test at annual, or to partial retraction like I experienced in my C. But temperature definitely effects this--mine started occasionally one winter, stopped over the summer and began in earnest the following winter. Replacing the pucks made all of my problems stop immediately. Stupid horn sounded off for over an hour on one flight, and I was 10-15 knots too slow, then at the top of descent when I pushed the yoke to descend, felt and heard a small thump, the horn stopped and the Gear Up light came on . . .
MikeOH Posted Monday at 10:34 PM Report Posted Monday at 10:34 PM 55 minutes ago, DonMuncy said: Are there factors I am missing. Is my logic flawed? Not at all. No doubt in my mind that taking the weight off the pucks is going to increase life. However, like most things, it's a trade-off. Speaking for short and mid- bodies the pucks have a pretty decent life, as it is. A decade or two, it seems. I'm admittedly a bit lazy, so the idea of jacking up the plane after every flight, and then removing before the next is just too much hassle for me. And, without really knowing how much longer the pucks will last make the financial payback calculation a bit difficult. I've replaced mine once, 8 years ago just after my purchase. They are still fine. I'll probably be looking at one more replacement before my flying days are done...I can live with that expense. 3
