Hank Posted Wednesday at 11:06 AM Report Posted Wednesday at 11:06 AM On 9/29/2025 at 10:45 PM, Utah20Gflyer said: I did my private in a Cherokee. It’s the Ford Fiesta of airplanes. 7 hours ago, dkkim73 said: Hmmm. Toyota Celica? No, the base Cherokee, even Archers, is just a Fiesta. The Celica has always had too much get up and go.
Hank Posted Wednesday at 11:10 AM Report Posted Wednesday at 11:10 AM 18 hours ago, Shadrach said: I have only flown formation with a C model. The difference in both climb and cruise surprised both of us. While it wasn't a formation flight, I took a friend to pick up his 75 F after AP work, a bit over and hour away. On the flight home, despite the 3-blade airbrake on my C, I kept his F in sight, and I was on downwind about the time he parked.
DXB Posted Wednesday at 11:39 AM Report Posted Wednesday at 11:39 AM A bit slow for a stock E. I take a strong principled stand against the folks here saying to put up with it - you didn't buy this thing to putt along at 143 - 148kts! You wanna be seen getting outrun by my well-modded C??!! How's that for a motivational pep talk? Cheapest speed mods are rigging it perfectly and waxing the wings. Make sure gear doors close fully. Timing advance in cruise from a Surefly will give you a clear benefit also for not too much money. The powerflow helped my C a good bit but may not do much for the E's engine/exhaust setup. The cowl closure looks nice but does nothing. Brake caliper rotation and flap gap seals are cheap mods that actually help a bit. Most other mods do very little. The 201 windshield is hard to find now and is a very expensive way to get a couple extra kts. Same with a 2 blade top prop. The windshield does make the cabin feel more spacious, improves visibility and perceptibly decreases prop noise. 1
AndreiC Posted Wednesday at 01:27 PM Author Report Posted Wednesday at 01:27 PM 1 hour ago, DXB said: The cowl closure looks nice but does nothing. Brake caliper rotation and flap gap seals are cheap mods that actually help a bit. Most other mods do very little. The 201 windshield is hard to find now and is a very expensive way to get a couple extra kts. Same with a 2 blade top prop. The windshield does make the cabin feel more spacious, improves visibility and perceptibly decreases prop noise. Thanks, Dev. I spoke to the folks at LASAR and decided to try to install the flap gap seals (at least) at my next annual. (At the moment they are trying to get things squared away with the FAA after their move to Oregon, and are not selling any of the kits; but they should be available in a month or so.) The other two kits they recommended were the dorsal fin vertical seal and the wing root fairing. Anyone have any experience if these two do anything to improve speed?
Pinecone Posted Wednesday at 02:22 PM Report Posted Wednesday at 02:22 PM 13 hours ago, Shadrach said: I guess I’ve never really considered that one might be able to set track records with a front wheel drive car. It seems fundamentally to be the wrong tool for the job. I’ve enjoyed lots of front drivers as street cars (Cooper S and Fiat Abart in particular) but I’ve never thought of the them as track cars… But then I don’t race, so what do I know? They set track records for THEIR CLASS. Not outright. LOVE my Fiat 500 Abarth. Hmmmm, 500 Abarth, E46 M3, E36 M3 LTW, Mooney M20K 252. Maybe a trend.
Paul Thomas Posted Wednesday at 02:33 PM Report Posted Wednesday at 02:33 PM 11 hours ago, AndreiC said: Maybe as the OP I will add that whoever guessed Porsche 914 has my vote. That is my fun car Here is a pic of it. Born same year and month as myself. (That is the Porsche for CB's, 1/4 of the price of a 911...) I wanted to buy one as my first car but once my mother heard Porsche, it was swiftly ruled out. Back then you could get a rust free 914/6 for very little money. My argument that it was just like a WW Beetle was ineffective.
TheAv8r Posted Wednesday at 02:49 PM Report Posted Wednesday at 02:49 PM The only speed mod I have on my E is the cowl enclosure (LASAR), it has the 1-piece windshield (not J) but that's it. I get the same as you LOP, around 142-145kts TAS @ 65% power at 7.5-8gph, but ROP I will get 152-155kts TAS at 75% power, 12gph to be 150deg ROP. Book figures are actually like 160kts if you can believe it, but nobody is getting those numbers out of a stock E haha. If you're getting 148, it is a tad slow for an E, I've owned 2 and both had no problem hitting low 150s at 75% power. I routinely fly mine LOP, the 10kt speed penalty is worth the 4gph saving... Up at higher altitudes (e.g. 9000) I see even better, this past weekend I flew to NC and at 9k, 65% power (WOT, around 20" MP, 2450 RPM) leaned to 8gph (20deg LOP) I was getting 145-148kts TAS.
AndreiC Posted Wednesday at 03:05 PM Author Report Posted Wednesday at 03:05 PM 13 minutes ago, TheAv8r said: The only speed mod I have on my E is the cowl enclosure (LASAR), it has the 1-piece windshield (not J) but that's it. I get the same as you LOP, around 142-145kts TAS @ 65% power at 7.5-8gph, but ROP I will get 152-155kts TAS at 75% power, 12gph to be 150deg ROP. Book figures are actually like 160kts if you can believe it, but nobody is getting those numbers out of a stock E haha. If you're getting 148, it is a tad slow for an E, I've owned 2 and both had no problem hitting low 150s at 75% power. I routinely fly mine LOP, the 10kt speed penalty is worth the 4gph saving... Up at higher altitudes (e.g. 9000) I see even better, this past weekend I flew to NC and at 9k, 65% power (WOT, around 20" MP, 2450 RPM) leaned to 8gph (20deg LOP) I was getting 145-148kts TAS. Well, it seems like there is about a 5 knot penalty on my plane for the 1970 model (with many exposed screw heads instead of flush rivets) and inefficient three blade prop. My best speed/fuel efficiency ratio for cruising seems to be 9.3 gph (peak EGT) at 8500 feet, 143 kts, 2500 rpm.
Hank Posted Wednesday at 03:13 PM Report Posted Wednesday at 03:13 PM 20 minutes ago, TheAv8r said: I routinely fly [my E] LOP, the 10kt speed penalty is worth the 4gph saving... Up at higher altitudes (e.g. 9000) I see even better, this past weekend I flew to NC and at 9k, 65% power (WOT, around 20" MP, 2450 RPM) leaned to 8gph (20deg LOP) I was getting 145-148kts TAS. That's very similar to the performance i get from my C at 9000 msl, WOT- / 2500 and leaned to peak or 25° Rich. No fuel flow installed, but i get ~8.4 gph from fuel pump to fuel pump. I do have the 201 windshield and guppy mouth closure, but also have a Hartzell 3-blade prop.
Shadrach Posted Wednesday at 03:43 PM Report Posted Wednesday at 03:43 PM 2 hours ago, Hank said: While it wasn't a formation flight, I took a friend to pick up his 75 F after AP work, a bit over and hour away. On the flight home, despite the 3-blade airbrake on my C, I kept his F in sight, and I was on downwind about the time he parked. It’s a single data point between two planes. Certainly not a comprehensive model vs model comparison. We were running supplies to NC together. He departed 2 mins ahead of me and despite being within 100lbs gross, I passed over him about 9nm from the airport as I climbed through 6500 on my way to 8500. He was as surprised as I was at the climb and speed differential. I will likely start flying that C model while my F is down for upgrades. I’ll get a better idea of the performance differences after a few long cross country trips.
TheAv8r Posted Wednesday at 06:04 PM Report Posted Wednesday at 06:04 PM 2 hours ago, AndreiC said: Well, it seems like there is about a 5 knot penalty on my plane for the 1970 model (with many exposed screw heads instead of flush rivets) and inefficient three blade prop. My best speed/fuel efficiency ratio for cruising seems to be 9.3 gph (peak EGT) at 8500 feet, 143 kts, 2500 rpm. Yeah, the 3-blade prop is going to come with a cruise penalty. I also have a SureFly and GAMI injectors on my plane so I can run it really smoothly LOP which will get me down to the 7.5gph range at the same speed.
DC_Brasil Posted Wednesday at 06:10 PM Report Posted Wednesday at 06:10 PM I don't know how my plane compares to MS members here. I have a 1990 J with no special mods (other than avionics) and removal of speedbrakes. Flying at 10,000 feet I usually get: - 139 Kts TAS @ 2.200 RPM LOP 7.5 to 8.2 GPH - 155 Kts TAS @ 2.400 RPM ROP 9.5 to 10.2 GPH According to Savvy analysis of my data I'm right at the average of the fleet (similar make/model/year/engine).
Chessieretriever Posted 22 hours ago Report Posted 22 hours ago Well for whatever it is worth it I went to fly the M20C from my 93 year old friend who now prefers to fly dual... I was surprised at the speed that this little carbureted airplane is able to achieve (I fly an M20M). Does this seem normal? It does have all kind of speed mods including J windshield and fairings and gap seals etc. but still has the 180HP engine.
Paul Thomas Posted 20 hours ago Report Posted 20 hours ago 1 hour ago, Chessieretriever said: Well for whatever it is worth it I went to fly the M20C from my 93 year old friend who now prefers to fly dual... I was surprised at the speed that this little carbureted airplane is able to achieve (I fly an M20M). Does this seem normal? It does have all kind of speed mods including J windshield and fairings and gap seals etc. but still has the 180HP engine. 135KIAS at 10,500 is ~160KTAS... I'd like to see those speeds out of my J (and like the C you're flying, I don't have the lower gear doors).
Slick Nick Posted 20 hours ago Report Posted 20 hours ago 1 hour ago, Chessieretriever said: Well for whatever it is worth it I went to fly the M20C from my 93 year old friend who now prefers to fly dual... I was surprised at the speed that this little carbureted airplane is able to achieve (I fly an M20M). Does this seem normal? It does have all kind of speed mods including J windshield and fairings and gap seals etc. but still has the 180HP engine. Looks like that isn’t even at full throttle? Something doesn’t add up.
ArtVandelay Posted 20 hours ago Report Posted 20 hours ago Looks like that isn’t even at full throttle? Something doesn’t add up. You’re assuming the instrument is correct on a 60 year old plane.
Slick Nick Posted 20 hours ago Report Posted 20 hours ago Just now, ArtVandelay said: You’re assuming the instrument is correct. That’s exactly what I’m getting at. The numbers don’t add up.
Hank Posted 19 hours ago Report Posted 19 hours ago 26 minutes ago, Slick Nick said: Looks like that isn’t even at full throttle? Something doesn’t add up. 14 minutes ago, ArtVandelay said: You’re assuming the instrument is correct on a 60 year old plane. 12 minutes ago, Slick Nick said: That’s exactly what I’m getting at. The numbers don’t add up. He's showing just over 20" at 11,500; my C barely makes that at 10,000. And at 20"/2500 and 10,000 msl, I'm usually around 145-148 KTAS (indicating around 145 mph). 1
bonal Posted 19 hours ago Report Posted 19 hours ago (edited) This translates to approximately 147ktas which makes more sense. I honestly can’t tell you what the RPMS were but I normally cruise at 2400 even up high. I know that our little C models are amazing for the speed you get from 180hp but 160 knots does seem a bit questionable Edited 18 hours ago by bonal Duh
ArtVandelay Posted 11 hours ago Report Posted 11 hours ago He's showing just over 20" at 11,500; my C barely makes that at 10,000. And at 20"/2500 and 10,000 msl, I'm usually around 145-148 KTAS (indicating around 145 mph).For those of us that fly in the south where air is warm and humidity is high, our performance will not match our northern counterparts. I routinely see a 10 knot difference in TAS between flights in PA (where he is) and flights in FL. Our engines are not making rated HP in hot and moist air, if you want bragging rights, move to where it’s cold and dry.
