Hello Bravo pilots.  I have owned my Bravo since September of 2021 and have done a factory engine along with a complete Garmin panel.  However I am wondering what is the average speed that you get.  I feel that I should be getting better than 160 TAS at 70% at 6500.  I had taken it up to 17k and was getting 180 TAS with same power settings.  I usually fly with 23/30 settings ROP.  Could it be rigging or this all you get with a Bravo?  When filing a flight plan at 160kt I always end up getting better speeds than forecasted.
@IgorD At 70%, as calculated from a fuel flow of 13.2gph LOP, I see 142KIAS at 6K' and 136KIAS at 15K. Standard day true airspeeds are 155KTAS and 171KTAS respectively. For completeness of data for comparison to yours, I run 30"/2200RPM at 13.2gph. I'm almost always near full gross at takeoff with CG at 46" +/- 0.2" My engine has about 1100 hours on it.
EDIT: I have TKS as well.
What fuel flow are you running at 30"/2300RPM?
Running 17.5 GPH 1590 TIT.  I tried to run it LOP however TIT at that FF would be at 1650 and loss of speed would be almost 15KTS.
my benchmarks at 17,000 ft are 185 KT TAS 2250 RPM 30.5" 18.5 GPH 1580 TIT 380 hottest CHT typically on #4 cylinder, GAMI injectors, about 0.3 GPH spread, 900h on a factory reman, I have TKS which I think scrubs off 3-5 KT, typically take off at gross, any luggage goes as far aft as possible, I tried 90% power 24/34 for short periods to see what it does, flow goes to 21.5 GPH to keep temps in check, speed increases by about 11 KT, the fastest I have gone for short periods of time with that power setting is 205 KT in 21,000 ft, sealing the baffles really helped my temps, Tempest fine wire plugs appear to reduce TIT, more complete combustion in the cylinder, extrapolating all that to 25,000 ft the TKS Bravo will probably reach 215 KT TAS with throttle and prop firewalled, fuel flow will probably go to 23--24 GPH, the highest I have taken the Bravo is 23,000 ft, boost started dropping off from 34" passing 21,500 ft, passing 22,000 ft climb was getting anemic, something like 300 ft min, sweet spot for the Bravo is between 19,000 ft and 21,000 ft, everybody believes their own press, that in mind I think this is about as good as it gets in a piston single, anything that goes any faster costs at least three times as much to operate, the weak spot on the Bravo is the exhaust, it really pays to keep TIT below 1600, I check the exhaust for cracks religiously every 25h oil change, none found so far, keep fingers crossed!
If we are going somewhere far it does make sense to go to 15-17k however my local flights 200 or under I stay at 6-8k.  What do most Bravo drivers get for TAS under 10k?
Interesting I may need to see if it needs to be re-rigged.  It had a gear up landing by previous owner.  I was out on Sunday and saw 144 IAS which resulted in 160kt+- TAS at 6.5 and 7K.
Another thought I had after looking at other Bravos on Flight Aware ground speeds are not much different than mine.  I always run my engine at 70% based on G3X and it could be that TAS is being displayed inaccurately.  A bug that got stuck in the pitot tube preventing from getting proper IAS?  Next time I am out I will try to do a four way course to get GS and average them out.
This is what I have for settings. I usually cruise at 30” give or take. I keep my cylinder head temp around 340 and burn around 17 gph. 190kts is pretty common up in the teens TAS. Engine has 300 hours and plane has 1150 TT
While running your TIT at 1644 is under the POH max, running that TIT temperature you will go through cylinders and exhaust systems on the Bravo engine.
Normally we all think of the POH as the final authority but if you take into account all of the experience that Bravo owners on this forum have, in 36 years now since the M20M was introduced, the recommended setting for longevity on this engine is a max combined number of 53 (MP + RPM; Example 29MP + 2400RPM).
Also keeping the TIT below 1600 will prolong the exhaust valves, exhaust system and TIT probes. The POH was never revised from the original and it says 1750 max, but that's when in the early life of the M20M people were going through a set of cylinders every 200-300 hours. The early M20M owners fought the battle and eventually Lycoming devleoped the wet-head (Bravo) engine, which helped. However still even with the Bravo (wet-head) engine you'll still never hit TBO if you run POH numbers.
The other big thing with this engine is that the TIT probes really only last 200-300 hours - less if you run it hotter than 1600. When the probes fail the TIT reads low, compounding the problems. As an example someone runs it at 1650 indicated when in fact the TIT is really 1750 since the probe is bad. This will mean turbo overhaul, exhaust overhaul and cylinder replacements. Looking over the logs and seeing when the probe was last replaced is very important.
I've had three M20Ms and there are a lot of other people on here with a lot of M20M time as well and that's what we have learned so far.
He’s probably flying that high power setting believing his engine monitor saying it’s only 65% power! Yet it’s over 80% depending on altitude.
one generally can’t use the %power displayed on their engine monitor till they calibrate it.
Several things catch my attention here.
First, your TIT is 1644 and your highest EGT is 1517. That's unlikely. The TIT is nominally 70-100Fº higher than the average of the EGTs, and yours is 126Fº higher than your highest EGT. This COULD be accurate depending on the placement of your EGT probes, but doesn't track with what I've seen in my airplane or in a couple of other Bravos.
Second, 17gph at 31.7/2380 is very close to the book values for peak TIT, and at that high of a power setting the CHTs should be in the neighborhood of 400º. Your hottest CHT shows as 349º, which also seems unlikely because your power setting is right in the middle of the "red box".
Third, as Paul pointed out, your EIS is indicating 65% HP which is definitely incorrect.
The generally accepted "safe" ROP power setting is ~18gph at 29/2400, which nominally yields a TIT in the mid to upper 1500s and CHTS in the high 300s. With that as a baseline, your indications appear suspect.
I'm sure you've spent some time looking at it but I'm including the POH power chart for reference within this thread so others can see what the book says. And we know that we don't want to fly these numbers.
Hot off the press from my Bravo this week:
All at 10k & +9°C Cowl Flaps closed. CHT will be #6, my hottest. I ran a few power settings and Peak, RoP & LoP. Note: not all Key 53’s are the same. 29”/24 was way hotter than 31”/22 key 53 for basically the same TAS.
29/24 Power 17.6gph 1595TIT 395CHT 169KTAS
29/24 Peak TIT 15.3 1720TIT 405CHT 166KTAS
29/24 LoP 13.2 1650TIT 375CHT 154KIAS
31/22 Power 17.9 1575TIT 387CHT 168KTAS
31/22 Peak 15.3 1675TIT 166KTAS
31/22 LoP 13.1 1615TIT 159KTAS
30/22 Power 17.2 1570TIT 390CHT 170KTAS
30/22 Peak 14.7 1689TIT 167KTAS
I’ve got about 220SFOH, factory injection (0.4) spread, Finewires and Dual SureFly’s courtesy of my Lycoming warranty and 3 failed Slick Mags in under 200 hours.  Fresh Paint as well. I’m not eligible for GAMI’s. It seems my CHT is what it is as Maxwell put new GeeBee baffles in for me and Brian Kendrick went through the cooling again when installing the SureFly’s.
Consider this my ringing endorsement of SureFly’s as I’m running 15-60 cooler CHT’s in climb, 5-10 cooler in cruise, and cold start in 2 blades.
For the long term, looks like I’ll have to run 30/22 power FF to get my best performance for the temps.
At FL180 -4°C and the rest as above:
31/22 Power was 18.2gph 1540TIT 398°CHT 187KTAS
30/22 Power is normally 173-175KTAS at this altitude
More on my next long trip next week
As a side note, Book numbers for 24/22 are not a problem, 27/22 us right at comfortable limits and as you can see from my numbers, above 27/22 Peak FF is not pretty.
Between Mike Busch’s articles, the APS class I’m working through and the GAMI operating recommendations, I’m pretty much tossing out the POH and leaning fuel flows in cruise until I hit around 1600TIT unless I bump up against 390CHT first for any given power setting. For takeoff that is WOT, 29.6gph, 1440TIT & in a 34/24 Climb 1440TIT works out to right at 26gph.
Unless headwinds really dictate it, I really don’t like to run under 10k. Only way to improve fuel economy with the turbo is to go higher as all we are at 8k is a J model burning a lot more gas. If it’s remotely feasible, I try to get to the upper teens for this reason. Now that I’ve got the kinks worked out on my engine, I’m gonna get an O2D2 and check out FL190-210. I get too much ice at 16-18k if it’s cloudy as I don’t have TKS.
I guess I am in the ball park.  My TAS is 180+- at those altitudes on 17-18 GPH at full gross.  Little better when light.  I was just looking at some of the other Bravos and they state that at that altitude should be at 200kt + with TKS.
A quick look at the Speed Power vs Altitude chart in the POH says to get 200KTAS it would take 34/2400 @ PeakTIT of 17.6 GPH to get near those speeds.  Really, you are looking at more like 20.5-21gph to do it, well more properly.
I didn't include it above, but I did run 34/2400 cruise for a 5-10 minutes after level off.  At 10k and +9c I was at a temp adjusted 20.8 FF for the Power FF on the chart, 1620TIT, 408CHT with the Cowl Flaps closed.  The TIT is the absolute limit it's been suggested I tolerate to keep the exhaust from failing over time, and the CHT is 9 degrees over my personal max.  POH calculates 187KTAS for that setting, I was getting 185KTAS at close to MTOW.  It will do it, but not interested in living at that power setting in cruise.
I'll get the numbers you suggest at 18k & a 31/2200 power setting for that FF.
HTH
HTH
To my best knowledge I was told to keep CHT's low 380's to keep the engine happy even if you have to crack the cowl flaps open a little.  Speed loss when they are half open is probably 1-2kts.  Gas is less expensive than cylinders or premature turbo overhaul.  Last time I was up at 17k TAS was 180kt at 17.7 GPH with hottest cylinder at 383 and TIT 1595.
I am planning to install fine wire plugs during next annual and have my injectors recalibrated by gammi.  Hopefully it will have a more complete burn and reduce TIT.    Engine is around 270 since factory reman and I am trying to last as long as possible without any major service.  Time delta on a 500nm flight and running it hard to get additional 10kt is 9 minutes.
There is much spirited debate about this topic. Look for @DVA’s post on Bravo engine management and join the fun.
Since the POH Cruise Tables are effectively useless above 27”/2200, many opinions on operating the TIO540-Bravo have developed here. What I posted above is by no means an absolute, but my experience with my 240 SFOH engine. @donkaye, MCFI does not ever run LoP, having had issues, with the exhaust I suspect, and will probably chime in here before long. You’ve already heard from @Rick Junkin who is probably the most successful at running LoP. For awhile, I was fat, dumb and happy thinking I was able to duplicate his numbers but he kept nagging at me that my TIT was too low despite a very well respected Mooney Shop telling me it was just fine. Well I had a different well respected Mooney mechanic tell me it was too low as well. Turns out my TIT Probe was 1 ohm too low and I was really running the 30/22 peak numbers (1690°TIT), and not the 1540 I believed. It’s why I try to post as much data for a power setting here as possible, it’s already saved me from abusing my “baby” engine.
After my research, I’m comfortable running CHT’s up to 400, the 380 offered here often is an actual Continental number, not a Lycoming number. My other mechanics recommendations range between 380-420° in higher power cruise, depending on the operating FF.  My personal limit is 399° in cruise and I prefer lower while keeping the Cowl Flaps closed to get that 1-2kts. Since I added the FineWires and SureFly mags, the climb heating problems I was having with a cylinder are now down to “sometimes” a problem in cruise. The actual weak link in the engine is the exhaust and that is the reason why the unofficial TIT limits are 1600-1620 depending on who you ask.
I’m sure I drive a few crazy here because I not only want to know how, but why people advocate what they do for our Bravo’s.
Many here run the Key # method, but note above, not all Key 53’s are equal, nor is the % power of Key 53 constant for all altitudes if you are considering running Key53 peak or lean, see the engine manual to confirm that.  I assume you have the ability to record data from your engine monitor. If not, I’d suggest getting one where you can and have it analyzed, by someone like Savvy.
Ref: https://www.lycoming.com/sites/default/files/file/2025-02/60297-23P%20-%20TIO-540%20Series%20-%20Parallel%20Valve%20Cyl.pdf
Moral here is read, research, and figure out which method works best FOR YOU! And understand why it works for you!!!!  The good thing about this group is that we are happy to share.
Invest in Savvy Engine support and take the APS Engine class, at least online.
We own a collection of high strung thoroughbreds, each with their own idiosyncrasies, on a good day we tame them.
This week, I limped to cheap gas at 24/22 peak TIT, only to run the next leg at 75% and 18gph to make up some time. I’m getting progressively more comfortable with need based settings vs one size fits all.  There is much versatility available as you get comfortable with the options.
Yes, I’m probably going to run mine a bit harder than you intend, but I’m also boroscoping every other oil change, or more and so far my only problems have been bad mag and wrong probe induced. How I run it also varies on the day’s mission.
HTH, and don’t hesitate to reach out with or post questions.
Yikes. Do you know how this was tested? And if you're using an EDM, is it your main gauge or do you still have the factory gauge and what did that show? My factory gauge shows about 20dF higher than what I see on the EDM830.
When I bought mine, it had an Insight 602 on the right side of the panel and still used the OEM TIT gauge on the left/center panel. The Max it ever read was about 1560-1580 when I was manually logging. I upgraded to a G2 to get data monitoring, then switched to a G4 on the left side when I upgraded to an ESI500 as my standby AI as the OEM Airspeed was freed up. As the old engine log went with the old engine, I have no idea when the 7 ohm probe was installed. Just glad @Rick Junkin kept casting doubt on it’s accuracy so that when Kendrick also brought it up, it was fixed. I assume it was the wrong probe before the G2 was installed and perpetuated when the OEM was disconnected as the G4 installed.
@Jetpilot86 Kudos for the empirical data compilation, thanks for sharing.
