soggyplanks Posted 19 hours ago Report Posted 19 hours ago I recently purchased a 1965, Mooney M20C. It has a lot of LASAR speed mods and the 200hp IO-360. Now the thing is all the 337 and STCs are there including in the AFM but I would like the AFM supplement and/or a modified checklist for the IO-360 if anyone has it. I know the procedure for cold and hot starts and obviously no carb heat but just want to go directly off the checklist to keep good pilot habits. Quote
Hank Posted 16 hours ago Report Posted 16 hours ago Look up the Owners Manual for a 1965 E here. The checklists should be what you need, the only difference that I'm aware of between C and E was the engine. Should be in the Downloads section. There may or may not be an AFM there, but the Manual is, I think. Quote
Oscar Avalle Posted 13 hours ago Report Posted 13 hours ago I have the same STC installed in my M20C. For all practical purposes it becomes a M20E. The AFM is included in the STC. If you don’t have send me an email and I can share it with you.Checklist I use a M20E checklist instead of the one I had previously.The starting procedure i use is the one for the M20E. Throttle slightly open, prop forward, mixture closed. Fuel pump on, once pressure is present, open mixture for 6 to 8 seconds. Close mixture turn off pump and crank. Once engine fires enrich mixture.OscarSent from my iPhone using Tapatalk Pro Quote
