Does anyone have a trick to remove the sniffle valve w/o displacing the exhaust or dropping the lower cowl?
I’m on version 3.0 of a long right angle 7/16th wrench I welded up but it’s proving difficult to get it just right with having to take it home to make changes.
Next attempt I might try spinning a nut on the flare side to break torque on from the other end (rear of engine).
TIA
Billy
  • 1 month later...
On 2/27/2025 at 2:44 PM, GarrettL said:
Drop the exhaust and find someone with tiny hands. I cleaned mine at my last annual and it was pretty gunked up.
Yeah I ended up dropping the exhaust, and the lower cowl to replace with the new style Lycoming Valve. Now its easily removable if I need to clean the new one.
