Max Clark Posted October 25, 2024 Report Posted October 25, 2024 I'm looking at changing my nav lights, recog, and strobes to LED while the plane is down for panel work. The question came up of what flash pattern I would want - and I have no idea, I've never thought about this as a choice, just what's already in the plane I was flying. I asked ChatGPT for info, but don't know what to do. What do you prefer? 1. Synchronized Strobes • Pros: • Looks cleaner and more uniform. • Can be less distracting to you as the pilot when looking at the wings. • Often preferred for night flying since it creates a predictable pattern for other pilots. • Cons: • Less attention-grabbing compared to wig-wag or random patterns. Best For: Night flying, where you want a more predictable visual signal for other pilots. 2. Wig-Wag (Alternating Flash) • Pros: • Increases visibility because alternating flashes attract attention. • Particularly useful in congested airspace and during daylight, making your aircraft more noticeable. • Cons: • Slightly more distracting to the pilot, especially if mounted on the wingtips. • Not as sleek or “clean” looking as synchronized strobes. Best For: Daytime flying or flying in high-traffic areas where you want to stand out more. 3. Random Flash Pattern • Pros: • Creates a unique light signature, making your aircraft more distinguishable. • Can enhance visibility and attract attention in both day and night operations. • Cons: • Some find random patterns chaotic or less professional. • May be harder to manage in some installations and could slightly affect the aircraft’s aesthetic appearance. Best For: If you want maximum attention from other aircraft, especially in environments where distinguishing your plane from others quickly is essential. Recommendation: • If your primary concern is visibility during the day, go for wig-wag since alternating flashes are more noticeable. • If you prioritize aesthetics and predictable signals, go for synchronized strobes, particularly if you fly more at night. • Random patterns are great if you’re looking for maximum visibility in both conditions but don’t mind a bit of randomness. Many pilots opt for wig-wag during the day and switch to synchronized strobes at night if their system supports both modes. This gives the best of both worlds. Quote
Pinecone Posted October 25, 2024 Report Posted October 25, 2024 Studies show that random is better. But I think synchronized looks better and that it what I did. I have the wingtip recog lights and they are set to wig wag with the landing light. Quote
Slick Nick Posted October 25, 2024 Report Posted October 25, 2024 My factory Whelen strobes flash three times between each break. Quote
Mooney in Oz Posted October 25, 2024 Report Posted October 25, 2024 I have synchronised LEDs, but it’s a personal choice. Back in the day, which wasn’t that long ago there was no choice. Quote
Max Clark Posted October 26, 2024 Author Report Posted October 26, 2024 1 hour ago, PT20J said: You are way overthinking this Yep but it’s a question I have to answer I guess I could just play parts roulette instead Quote
MB65E Posted October 26, 2024 Report Posted October 26, 2024 To the OP, was that the way that chat responds and it was a cut and paste? I have a co-worker that types like this. He’ll take an email and completely re-write it. Sounds like a lot of work to me but I bet he uses GPT now that I’ve seen the format. -Matt Quote
201er Posted October 26, 2024 Report Posted October 26, 2024 Mine is random. Right wing does the normal single synchronized strobe and the left does triples. But it’s not out of a carefully considered choice relying on the most advanced artificial technology, it’s out of being cheap and replacing only the one that was broken! 1 Quote
ArtVandelay Posted October 26, 2024 Report Posted October 26, 2024 I have 3 and they’re random…it a sparkling pattern. Quote
Max Clark Posted October 26, 2024 Author Report Posted October 26, 2024 42 minutes ago, MB65E said: To the OP, was that the way that chat responds and it was a cut and paste? I have a co-worker that types like this. He’ll take an email and completely re-write it. Sounds like a lot of work to me but I bet he uses GPT now that I’ve seen the format. -Matt Yes it was 1 Quote
Will.iam Posted October 27, 2024 Report Posted October 27, 2024 Mine is random because i was cheap and didn’t pay for an extra wire to install to synchronize the strobes. 1 Quote
PT20J Posted October 27, 2024 Report Posted October 27, 2024 See if you can get them to flash ... --- ... 3 Quote
donkaye Posted October 27, 2024 Report Posted October 27, 2024 My strobes have one choice; synchronized. My pulse lights alternate: left taxi/right recognition then right taxi/ left recognition. https://youtu.be/sw6ZScJkmmI 1 Quote
cliffy Posted October 27, 2024 Report Posted October 27, 2024 I like the double flash synchronized at night the best. Quote
gevertex Posted October 27, 2024 Report Posted October 27, 2024 Is there a cost difference? IIRC you need a sync wire for synchronized. Maybe for wigwag too? Quote
Pinecone Posted October 28, 2024 Report Posted October 28, 2024 Yes, you need a sync wire to make them do anything that requires them to be synched in some way. They have to have some way to tell each other what to do when. Quote
