Bill_Pyles Posted April 25, 2012 Author Report Posted April 25, 2012 KSMooniac---lead is indeed a lubricant. Google "lead as lubricant in fuel" and you will find many references to the use of lead as a lubricating additive to fuel. Quote
PTK Posted April 25, 2012 Report Posted April 25, 2012 Quote: Bill_Pyles KSMooniac---lead is indeed a lubricant. Google "lead as lubricant in fuel" and you will find many references to the use of lead as a lubricating additive to fuel. Quote
RJBrown Posted April 25, 2012 Report Posted April 25, 2012 Quote: allsmiles In fact, TEL (Tetraethyl Lead) is added to avgas in order to increase the fuel's margins or resistance to detonation. Thereby enabling the advantageous use of high octane fuel which is required for high piston engine performance at altitude. Quote
KSMooniac Posted April 25, 2012 Report Posted April 25, 2012 Lead is most certainly not a lubricant...it is only a component to increase octane in our fuel. The APS crew has a good bit of data dispelling this myth in their course. Quote
RJBrown Posted April 25, 2012 Report Posted April 25, 2012 Quote: KSMooniac Lead is most certainly not a lubricant...it is only a component to increase octane in our fuel. The APS crew has a good bit of data dispelling this myth in their course. Quote
Bill_Pyles Posted April 25, 2012 Author Report Posted April 25, 2012 In any event, I am going to put a gallon of AVGAS (per Jose) in the empty sump for 15 minutes and then let it drain out and take whatever old oil and other crud might be lurking. I will then close the valve, install a new filter and fill the sump with 8 qts of new oil (Aeroshell W100) and be done with it. No alumimum will be corroded, no bearings will have a chance to rust in the Arizona heat and I will have a cleaner sump than I would have had. Any residual fuel will either evaporate or blend with the new oil and will be gone in no time. Quote
danb35 Posted April 25, 2012 Report Posted April 25, 2012 Sounds like you're convinced, and I don't see it doing any harm--but I'd use 7 quarts instead of 8, as you'll likely lose the 8th quart within a few hours anyway. Quote
jetdriven Posted April 26, 2012 Report Posted April 26, 2012 You can shake the plane to agitate the avgas, and stir up anything to be flushed out. I wouldn't worry Bill. Worst case, you waste 6$. It costs more to start up that Mooney after changing the oil to check for leaks. Quote
DaV8or Posted April 26, 2012 Report Posted April 26, 2012 Quote: RJBrown It is a very real question to collectors of 50+ year old cars. Quote
FlyingDude Posted March 20 Report Posted March 20 After 12 years... any further insights into this topic? Quote
shawnd Posted March 21 Report Posted March 21 9 hours ago, FlyingDude said: After 12 years... any further insights into this topic? A suggestion: after you have run the engine, let it sit for a day or two, or may be 5. Let the oil that is covering all the engine parts drip down and into the sump. Reason: if you have ever taken a look at your oil dipstick the day after or a few days after, you will notice the level in the sump always rises. Drain after a sufficient time passes. Similarly take out your oil filter or use the pierce trick to let the oil drain out from the accessory side as well for a few days. By the time you come back to drain from sump, the oil on filter side of the engine should have left the engine by now. I believe this maximizes one's opportunity to get all the "old" oil out. Quote
Utah20Gflyer Posted March 21 Report Posted March 21 I think it’s a waste of time. Get oil analysis to get objective information about the quality of oil at the time you change it. If it tests fine then continue on. If it doesn’t then shorten your oil change interval. The practice of trying to get every drop of oil out of the engine is based on emotion in my opinion rather than a logic. Engines that get ran a lot will last a long time. The engines that sit don’t last. That last bit of old oil just doesn’t matter. 2 Quote
ArtVandelay Posted March 21 Report Posted March 21 I run the engine (45 min flight ) with 1/2 quart of MMO before I do the oil change, helps clean all the internal parts, not just the crankcase. Thins the oil a little to help draining. Also, Mooneys squat with nose up, lowering the nose will help drain more of the oil out, I partially pull the plane out of the hangar to do this. Quote
shawnd Posted March 21 Report Posted March 21 6 hours ago, ArtVandelay said: I run the engine (45 min flight ) with 1/2 quart of MMO before I do the oil change, helps clean all the internal parts, not just the crankcase. Thins the oil a little to help draining. Also, Mooneys squat with nose up, lowering the nose will help drain more of the oil out, I partially pull the plane out of the hangar to do this. Curious if MMO affects oil analysis? Quote
wombat Posted March 21 Report Posted March 21 Regarding avgas in the oil..... Some 182s have a 'oil dilution' option, which pumps some avgas into the oil, thinning the oil to make it easier to start. If Cessna (I know, I know, they don't know the first thing about airplanes and engines) thinks avgas is OK to add to the crankcase occasionally, I suspect some avgas (even a lot!) isn't going to hurt during an oil change. But also, the contaminants are mostly spread evenly in the oil and developed evenly over time. Getting the last 1/2 quart is 6.25% if you refill to 8 quarts, 4.2% if you use 12. That is the same as changing the oil 1.875 (1.278 for a 12 QT sump) hours earlier if you change on a 30 hour schedule. I don't pay the slightest bit of attention to going 2 hours over my 30 hour interval. Let's see... Cost analysis time... 1 gallon of avgas = ~$7 1 oil change = 8 quarts at $7 + 1 filter @ $50, so let's say $100 total. If you change oil every 30 hours, oil changes cost you $3.33/Hr, and the reduced oil change interval going to 28 hour intervals would cost you $6.66, because that's 2 hours of flying you lose. If you add the avgas but keep your oil change interval, that costs you $7..... Basically the same. There is no way I'd track my flying budget that closely. 1 Quote
FlyingDude Posted March 21 Report Posted March 21 I think the purpose of this operation was not to shake or milk the final drops of oil out of the sump or the entire engine. I think the purpose is to loosen and flush out the sediments that accumulated on the bottom of the oil sump - if there are any. Does gunk really settle on the bottom of the sump? Does it really get flushed out with avgas? 1 Quote
ArtVandelay Posted March 21 Report Posted March 21 Curious if MMO affects oil analysis?Oil analysis looks for metals, MMO doesn’t have any I think, but avgas does and your lead content should be higher. 1 Quote
PT20J Posted March 22 Report Posted March 22 (edited) On 3/21/2024 at 6:33 AM, shawnd said: Curious if MMO affects oil analysis? MMO is Naptha, Stoddard Solvent, TCP (lead scavenger) , o-, p-Dichlorobenzene (carbon dissolver), red dye and wintergreen fragrance. I doubt it would show up on oil analysis. https://wiki.lbto.org/pub/Safety/ChemicalSafetySDS/Marvel_Mystery_Oil.pdf Edited March 22 by PT20J Fragrance is wintergreen not peppermint as originally stated. 1 Quote
philiplane Posted March 22 Report Posted March 22 In theory, flushing with avgas will remove more oil. But it will remove less particles, because avgas is much lighter than oil and does not have good hydraulic properties. Meaning, you will remove the most particulate matter by draining the oil when it's hot. If you flush with avgas after that, you will remove any remaining oil in the pan. Which is very little. But if there are particles in the pan, the avgas will not remove them. It's too light. 1 Quote
carusoam Posted March 22 Report Posted March 22 Dude! This was a favorite topic for José… He used avgas to wash the sludge out of the oil pan… Sludge is a mixture of 100LL additives and oil…. it has a tendency to pile up on the bottom…. the challenge being…. it is hard to tell how much of the gallon of gas actually drained back out…. any gas left behind in the oil, will evaporate as it gets hot… but it also affects the viscosity…. This is where most people decide that it is very challenging to get this right… it would be really cool to have clean looking oil for 50 hours…. Instead of it changing colors after the engine is first started… PP thoughts only, not a mechanic… Best regards, -a- Quote
FlyingDude Posted March 22 Report Posted March 22 Hey A, "Sludge" is the key word! Well, we're told to fly the plane every 2 weeks rather than just let it idle to keep the engine well lubed and so that the oil reaches high temperatures and the water content evaporates. Avgas evaporates way before water... But then there's the lead contamination into engine oil that leads to corrosion. I've read about it in many places but this is the top hit on my Google search' https://www.aopa.org/news-and-media/all-news/2017/february/24/why-change-the-oil "To make matters worse, avgas is heavily laced with the octane improver tetraethyl lead (TEL), which also does nasty things when it blows by the rings and gets into the crankcase." TEL evaporates a little before water so you'd think it'll get expelled through the breather - but will it? Or will it just sit there and contaminate all the oil? Maybe a good flush with UL94 would be the safe way to go... Take care Quote
PT20J Posted March 22 Report Posted March 22 Does either Continental or Lycoming recommend this? If you use AD oil and change it frequently, it keeps the gunk suspended (that’s why it turns black). Straight mineral oil will form sludge and Lycoming recommends not switching to AD oil if you’ve been running mineral oil for a long time because the detergents loosen the sludge and can cause it to clog oil passages. 2 Quote
Andy95W Posted March 22 Report Posted March 22 1 hour ago, PT20J said: Does either Continental or Lycoming recommend this? If you use AD oil and change it frequently, it keeps the gunk suspended (that’s why it turns black). I agree with Skip. This seems like a solution looking for a problem. 1 Quote
Will.iam Posted March 22 Report Posted March 22 Blackstone lab knows when you use or suspects when MMO is used as the viscosity of the oil is lower than what’s normal. That’s why tgere is a section on the form for listing additives and how much you put in so they can account for the lower viscosity value. Blackstone labs could also tell when i started running lean of peak ops as there was lower fuel contaminants and when i started running a dehumidifier they noted i had little to no water in my oil samples and asked me what i was doing differently to account for the change. 1 Quote
