PeteMc Posted April 17, 2024 Report Posted April 17, 2024 My trim switch stopped working for Up Trim on my trip home after the yokes were removed and cleaned up during the Interior work. I assumed it was a loose wire they'd fix when it went in for the Annual. Just heard back that they are saying the switch is bad and it is $2,162.17 for a new switch and $937.18 for a used one. I haven't started a search yet, but for anyone that has had to change their Trim Switch, do those prices seem real? BTW, this is the first time for me with this shop after moving. Next question, does anyone know of a source for the part? I'll start calling around, but never hurts to already have one option if anyone knows of any. Quote
wombat Posted April 17, 2024 Report Posted April 17, 2024 There is no need to spend that much money. The trim switch, assuming it's the one that looks like this: https://images.app.goo.gl/NPnsfxHLKxHeZdUTA Is actually made up of three switches underneath. Those internal switches can fail, and can be independently replaced. They are Honeywell 1SX74-T switches and can be purchased for about $35 each from mouser: https://www.mouser.com/ProductDetail/Honeywell/1SX74-T?qs=10P5Hhl%2BD796P7tntVKlzg%3D%3D&countryCode=US¤cyCode=USD If you look through my thread earlier this year about my autopilot issue (which was just me being too hasty) there are some detailed pictures of the wiring of the switches. You can order a replacement switch or two or three, install them, and that should fix your problem. I'm happy to chat more about this if you want. 2 Quote
mike_elliott Posted April 17, 2024 Report Posted April 17, 2024 I have a spare one I keep right next to a gold ingot and a vac switch 1 Quote
wombat Posted April 17, 2024 Report Posted April 17, 2024 On 4/17/2024 at 5:19 PM, mike_elliott said: I have a spare one I keep right next to a gold ingot and a vac switch Expand You don't have an intake boot? Your retirement investment strategy is sorely lacking.... 2 Quote
PeteMc Posted April 17, 2024 Author Report Posted April 17, 2024 On 4/17/2024 at 5:07 PM, wombat said: Those internal switches can fail, and can be independently replaced. Expand Thanks! I'll look closer at your earlier posts. Quote
mike_elliott Posted April 17, 2024 Report Posted April 17, 2024 On 4/17/2024 at 6:04 PM, wombat said: You don't have an intake boot? Your retirement investment strategy is sorely lacking.... Expand Funny as I had one of those but sent it away with the gent who bought my F. Perhaps a oil pressure sensor and a few turbo vband clamps will fill the obvious void Quote
0TreeLemur Posted April 18, 2024 Report Posted April 18, 2024 On 4/17/2024 at 5:07 PM, wombat said: They are Honeywell 1SX74-T Expand I got the following info- From Honeywell data sheet: Catalog Listing 21SX39-T (MS24547-1) Mil Spec.: MIL-PRF-8805 Max. Op. Temp: 82°C [180°F] Electrical data and UL Codes: 7 A Note: it says that Prefix 21SX is the same as a Prefix 1SX with MIL-approvals They are a single-pole, double throw switch. Normally, pins 1 and 3 are connected together and pin 2 is open. When depressed, pins 1 and 2 are connected and pin 3 is open. Quote
Fly Boomer Posted April 18, 2024 Report Posted April 18, 2024 On 4/18/2024 at 8:36 PM, 0TreeLemur said: I got the following info- From Honeywell data sheet: Catalog Listing 21SX39-T (MS24547-1) Mil Spec.: MIL-PRF-8805 Max. Op. Temp: 82°C [180°F] Electrical data and UL Codes: 7 A Note: it says that Prefix 21SX is the same as a Prefix 1SX with MIL-approvals Expand So if Prefix 21SX is the same as a Prefix 1SX with MIL-approvals, what is the difference between 74-T and 39-T? Quote
Ryan ORL Posted April 19, 2024 Report Posted April 19, 2024 Unfortunately those prices are very real. Back when I still had my KAP 150, my switch failed, and we weren't able to find (at the time) a shop that could fix my switch in a reasonable time frame. I paid around $1500 I think. I was told it was a special order item from Honeywell. I had the Bendix King (Honeywell) 200-2960-00 Pitch Trim Switch. When I ripped out the whole BK system for my GFC500, I ended up selling the switch on eBay for like $500. Quote
hypertech Posted April 19, 2024 Report Posted April 19, 2024 On 4/19/2024 at 1:33 PM, Ryan ORL said: Unfortunately those prices are very real. Back when I still had my KAP 150, my switch failed, and we weren't able to find (at the time) a shop that could fix my switch in a reasonable time frame. I paid around $1500 I think. I was told it was a special order item from Honeywell. I had the Bendix King (Honeywell) 200-2960-00 Pitch Trim Switch. When I ripped out the whole BK system for my GFC500, I ended up selling the switch on eBay for like $500. Expand Did you get the garmin style switch to fit the yoke? I bought one but the shop had trouble getting it to fit so stuck with the old BK switch. In my case it was a KFC-225 but I'm pretty sure its the same switch. Quote
wombat Posted April 19, 2024 Report Posted April 19, 2024 I got the model number of the switch by looking at the model number printed on one that was installed in my plane. Quote
Ryan ORL Posted April 19, 2024 Report Posted April 19, 2024 On 4/19/2024 at 1:38 PM, hypertech said: Did you get the garmin style switch to fit the yoke? I bought one but the shop had trouble getting it to fit so stuck with the old BK switch. In my case it was a KFC-225 but I'm pretty sure its the same switch. Expand Yeah it seems to fit fine, although if they had any trouble with it, I don't know Quote
PT20J Posted April 19, 2024 Report Posted April 19, 2024 On 4/19/2024 at 2:44 PM, Ryan ORL said: Yeah it seems to fit fine, although if they had any trouble with it, I don't know Expand I believe that Garmin uses a Cygnet CA3112-G. I've seen pictures of it on a Beech yoke but not on a Mooney. Do you have a picture of the installation? Thanks. Quote
Ryan ORL Posted April 22, 2024 Report Posted April 22, 2024 On 4/19/2024 at 5:56 PM, PT20J said: I believe that Garmin uses a Cygnet CA3112-G. I've seen pictures of it on a Beech yoke but not on a Mooney. Do you have a picture of the installation? Thanks. Expand From my Googling, I think it is also a Cygnet CA3112-G. 1 Quote
moosebreath Posted April 27, 2024 Report Posted April 27, 2024 The King switch is a standard part available from Mouser. I bought two last time I replaced mine so I would have a spare. As noted they should be less than $50. Quote
hubcap Posted April 28, 2024 Report Posted April 28, 2024 Mine was replaced with the Garmin switch during my panel upgrade. If it is in the box with the rest of my assorted left-overs I will be glad to give it to somebone who needs it. I have the entire King 200 including servos. Quote
Bigdaddie Posted April 28, 2024 Report Posted April 28, 2024 On 4/28/2024 at 5:14 PM, hubcap said: Mine was replaced with the Garmin switch during my panel upgrade. If it is in the box with the rest of my assorted left-overs I will be glad to give it to somebone who needs it. I have the entire King 200 including servos. Expand I also have a complete KFC200 system (well it's at the avionics shop with the rest of the airplane). We installed a Cygnet electric trim switch with the avionics upgrade. Let me know if you can't find one. Quote
natdm Posted April 28, 2024 Report Posted April 28, 2024 On 4/28/2024 at 5:31 PM, Bigdaddie said: I also have a complete KFC200 system (well it's at the avionics shop with the rest of the airplane). We installed a Cygnet electric trim switch with the avionics upgrade. Let me know if you can't find one. Expand https://www.cygnet-aero.com/trim-switch-ca3112-g This guy? Says it’s specifically not a replacement for the one that uses the 3 switches, which I believe is what’s being called for here? Is there another one? Quote
PT20J Posted April 28, 2024 Report Posted April 28, 2024 On 4/28/2024 at 5:57 PM, natdm said: https://www.cygnet-aero.com/trim-switch-ca3112-g This guy? Says it’s specifically not a replacement for the one that uses the 3 switches, which I believe is what’s being called for here? Is there another one? Expand The Cygnet switch works with the GFC 500. The BK switch can also be used with the GFC 500 with some rewiring. The Cygnet switch will not work with a BK autopilot. 1 Quote
rickseeman Posted April 30, 2024 Report Posted April 30, 2024 I worshiped King for 30 years. Their stuff was so much better than anyone else's. 40 years ago there you were, KFC-200, KNS-80 flying Great Circle routes across the country. You thought you were a God flying the Space Shuttle. Then they failed to innovate, and let Garmin take over the world. Now they are just scum. Trying to hold up any stagecoach that comes through their area. 2 Quote
Bigdaddie Posted May 6, 2024 Report Posted May 6, 2024 On 4/28/2024 at 5:57 PM, natdm said: https://www.cygnet-aero.com/trim-switch-ca3112-g This guy? Says it’s specifically not a replacement for the one that uses the 3 switches, which I believe is what’s being called for here? Is there another one? Expand I'll have to look at it when I go to the avionics shop. I'd just replace the 3 micro switches and be done with it. 1 Quote
