ZentRose Posted May 13, 2023 Report Posted May 13, 2023 Hi everyone. I am based out of Corona Airport and looking for a Mooney mechanic to do a pre buy on a plane (1964 M20E) that I am interested in. Any suggestions? I would also need transition training if I buy the plane. I spoke with Paul Kortopates already (he is based out of San Diego)... but wondering if there is any Mooney Specific instructor closer to me that you guys can recommend. Thank you
ilovecornfields Posted May 13, 2023 Report Posted May 13, 2023 1 hour ago, ZentRose said: Hi everyone. I am based out of Corona Airport and looking for a Mooney mechanic to do a pre buy on a plane (1964 M20E) that I am interested in. Any suggestions? I would also need transition training if I buy the plane. I spoke with Paul Kortopates already (he is based out of San Diego)... but wondering if there is any Mooney Specific instructor closer to me that you guys can recommend. Thank you You’re closer to @kortopatesthan I am, but that’s who I do my recurrent training with. Definitely worth the flight. Kurt at Expert Aircraft in French Valley (F70) might be able to help you with the prebuy. 1
Niko182 Posted May 13, 2023 Report Posted May 13, 2023 (edited) 1 hour ago, ZentRose said: Hi everyone. I am based out of Corona Airport and looking for a Mooney mechanic to do a pre buy on a plane (1964 M20E) that I am interested in. Any suggestions? I would also need transition training if I buy the plane. I spoke with Paul Kortopates already (he is based out of San Diego)... but wondering if there is any Mooney Specific instructor closer to me that you guys can recommend. Thank you Jay mason out of KSNA. He works out of pacific flight, but did help with my instrument when I started flying my mooney. He knows them very well. Edited May 13, 2023 by Niko182
ZentRose Posted May 13, 2023 Author Report Posted May 13, 2023 Thanks for your help guys @Niko182 @ilovecornfields. I appreciate it. Does anyone locally have a manual gear mooney M20E? I have never actually flown in one (only sat in them on the ground). I am wondering whether or not I should spend more for a later model Mooney or go forward with the pre-buy on this one.
DCarlton Posted May 14, 2023 Report Posted May 14, 2023 If you’re settled on a Mooney, there’s a few down at KCRQ. I could walk you around my 67F and tell you everything I’ve done to it or had to do to it the last 20 years. Mine has an electric gear but there are many diehard manual gear fans. I actually wanted a E then found my F. You used to be able to rent a J here but I haven’t seen it in a while.
ilovecornfields Posted May 14, 2023 Report Posted May 14, 2023 10 minutes ago, DCarlton said: If you’re settled on a Mooney, there’s a few down at KCRQ. I could walk you around my 67F and tell you everything I’ve done to it or had to do to it the last 20 years. Mine has an electric gear but there are many diehard manual gear fans. I actually wanted a E then found my F. You used to be able to rent a J here but I haven’t seen it in a while. Pinnacle used to have a J. Not sure if they still do.
DCarlton Posted May 14, 2023 Report Posted May 14, 2023 Just now, ilovecornfields said: Pinnacle used to have a J. Not sure if they still do. Yeah the green DD that gear upped at FBK. Haven’t seen it in a while but it may still be around.
kortopates Posted May 14, 2023 Report Posted May 14, 2023 Yeah the green DD that gear upped at FBK. Haven’t seen it in a while but it may still be around. 201DDIt’s still around, but privately owned at F70 now.Sent from my iPhone using Tapatalk 2
MrRodgers Posted May 14, 2023 Report Posted May 14, 2023 Hi, Not sure about who local to you to recommend for a Mooney-specific pre-buy inspection. If anyone has a resource in the So-Cal area that would be great to know. In regard to transition training I hear that Paul Kortopates is highly recommended. I have worked with Donald E Kaye (he flew down from Nor Cal) and Mike Jesch out of KFUL for my transition training. Both are really great to work with. 1
Niko182 Posted May 14, 2023 Report Posted May 14, 2023 13 hours ago, ZentRose said: Thanks for your help guys @Niko182 @ilovecornfields. I appreciate it. Does anyone locally have a manual gear mooney M20E? I have never actually flown in one (only sat in them on the ground). I am wondering whether or not I should spend more for a later model Mooney or go forward with the pre-buy on this one. Have you ever had any shoulder issues? I've flown a Manual bar C and the gear is quite easy to move but if you have mobility issues, or anything similar, I'd recommend the electric gear. The manual gear will be cheaper to own, and it is a bullet proof system. I believe its the only gear system that doesn't have an emergency backup. It is very reliable.
ilovecornfields Posted May 14, 2023 Report Posted May 14, 2023 9 hours ago, kortopates said: 201DD It’s still around, but privately owned at F70 now. Sent from my iPhone using Tapatalk George was my primary instructor in the early 90’s. When my son wanted his first lesson I tried to see if he was still available but he wasn’t taking new students so we flew with one of his instructors instead. I did get to catch up with him and he mentioned that he was trying to get rid of the Mooney because it was much more maintenance-intensive than the Cessnas. I guess he finally did.
kortopates Posted May 14, 2023 Report Posted May 14, 2023 (edited) 45 minutes ago, ilovecornfields said: George was my primary instructor in the early 90’s. When my son wanted his first lesson I tried to see if he was still available but he wasn’t taking new students so we flew with one of his instructors instead. I did get to catch up with him and he mentioned that he was trying to get rid of the Mooney because it was much more maintenance-intensive than the Cessnas. I guess he finally did. Honestly to the best of my knowledge, I think he has sold 201DD multiple times and its always ended back on their ramp! I remember the first I knew of was a young pilot that bought it in the early 2000's to do his instrument training. Within about 2 years it was back at Pinnacle. By my count, this is at least the third try to find it a new home. Don't know why, only that its a high time very early J model. Edited May 14, 2023 by kortopates 1
ZentRose Posted May 19, 2023 Author Report Posted May 19, 2023 I set up the pre-buy for today and organized a flight instructor to fly the plane over to the mechanic. The problem is we have been unable to get ahold of the owner to make sure it is insured. My current airplane is going to be sold next week. I will probably be renting for awhile. This is the plane if anyone knows the owner (I am budgeting for an engine overhaul): https://www.trade-a-plane.com/search?category_level1=Single+Engine+Piston&make=MOONEY&model=M20E&listing_id=2416232&s-type=aircraft
jaylw314 Posted May 19, 2023 Report Posted May 19, 2023 (edited) 16 minutes ago, ZentRose said: I set up the pre-buy for today and organized a flight instructor to fly the plane over to the mechanic. The problem is we have been unable to get ahold of the owner to make sure it is insured. My current airplane is going to be sold next week. I will probably be renting for awhile. This is the plane if anyone knows the owner (I am budgeting for an engine overhaul): https://www.trade-a-plane.com/search?category_level1=Single+Engine+Piston&make=MOONEY&model=M20E&listing_id=2416232&s-type=aircraft For future reference, there is 'Non-owned aircraft insurance' that you can buy, and that I assume your instructor has. That being said, it seems pretty risky for the buyer to be the one doing the transportation for pre-purchase inspection--if some damage or failure occurs to the plane, who's responsibility is it? It seems safer to ask the seller to transport it and reimburse him for fuel, time and any additional transportation costs that you agree on. That way, if somethin happens on the way there, you're only at risk for that amount instead of a demand to pay for an open-ended repair bill. Have you looked at GMax? They're in Texas, but they're the biggest Mooney broker and reseller, and most here see Jimmy Garrison as a stand up guy. I did buy from him several years ago, and he posts here every now and then. I noticed he has this M20E in inventory: https://www.gmaxamericanaircraft.com/inventory/?/listing/for-sale/219228295/1965-mooney-m20e-super-21-piston-single-aircraft?dlr=1&dscompanyid=6946&settingscrmid=614667 Edited May 19, 2023 by jaylw314
Skates97 Posted May 19, 2023 Report Posted May 19, 2023 DuBois there at CNO still has their M20B that has manual gear.
ZentRose Posted May 19, 2023 Author Report Posted May 19, 2023 30 minutes ago, jaylw314 said: For future reference, there is 'Non-owned aircraft insurance' that you can buy, and that I assume your instructor has. That being said, it seems pretty risky for the buyer to be the one doing the transportation for pre-purchase inspection--if some damage or failure occurs to the plane, who's responsibility is it? It seems safer to ask the seller to transport it and reimburse him for fuel, time and any additional transportation costs that you agree on. That way, if somethin happens on the way there, you're only at risk for that amount instead of a demand to pay for an open-ended repair bill. Have you looked at GMax? They're in Texas, but they're the biggest Mooney broker and reseller, and most here see Jimmy Garrison as a stand up guy. I did buy from him several years ago, and he posts here every now and then. I noticed he has this M20E in inventory: https://www.gmaxamericanaircraft.com/inventory/?/listing/for-sale/219228295/1965-mooney-m20e-super-21-piston-single-aircraft?dlr=1&dscompanyid=6946&settingscrmid=614667 I agree. I am probably going to pass on this plane. They are pushing me to bring my mechanic to the field. This gives me a bad feeling. In the process of selling my own plane, I have been very accommodating with potential buyers. I did look at that plane and requested the logs via email. I will follow up with Jimmy. Thanks for your help! 1
ZentRose Posted May 19, 2023 Author Report Posted May 19, 2023 35 minutes ago, Skates97 said: DuBois there at CNO still has their M20B that has manual gear. Awesome, Thank you.
Ron McBride Posted May 19, 2023 Report Posted May 19, 2023 Mariposa airport in Ca I believe has a manual gear f, for rent. KMPI. Try 559 974-1169. KMPI is ne of Fresno. Near Yosemite.
chriscalandro Posted May 20, 2023 Report Posted May 20, 2023 (edited) foothill- I asked them if they could do a weight and balance and ifr cert on my airplane. They said sure, any time next week (today is Friday) when I asked if they could come 5 miles down the road to my hangar at KPOC they said they were booked months out. last year I also had to buy a nose gear tube from them. It was 40% more than anywhere else. all this to say, these people, despite being an MSC suck, and that is NOT an 85k airplane. Edited May 20, 2023 by chriscalandro
ZentRose Posted June 11, 2023 Author Report Posted June 11, 2023 On 5/19/2023 at 5:58 PM, chriscalandro said: foothill- I asked them if they could do a weight and balance and ifr cert on my airplane. They said sure, any time next week (today is Friday) when I asked if they could come 5 miles down the road to my hangar at KPOC they said they were booked months out. last year I also had to buy a nose gear tube from them. It was 40% more than anywhere else. all this to say, these people, despite being an MSC suck, and that is NOT an 85k airplane. Yeah the agreed starting point was $70k on the one at Foothill after I reviewed the logs. The one at GMAX is similar (not worth asking price since the engine is run out) but I don't think they will negotiate much.
ZentRose Posted July 4, 2023 Author Report Posted July 4, 2023 I decided to increase my budget toward an M20F or M20J and ended up buying this plane. The Rajay is a nice bonus: https://indyairsales.com/current-inventory/aircraft/1968-mooney-m20f-n3486n/ 1
Fly Boomer Posted July 4, 2023 Report Posted July 4, 2023 8 minutes ago, ZentRose said: I decided to increase my budget toward an M20F or M20J and ended up buying this plane. The Rajay is a nice bonus: https://indyairsales.com/current-inventory/aircraft/1968-mooney-m20f-n3486n/ Congratulations! Extremely nice panel.
ZentRose Posted July 6, 2023 Author Report Posted July 6, 2023 On 7/4/2023 at 4:45 PM, Fly Boomer said: Congratulations! Extremely nice panel. Thank you!
quietpilot Posted August 8, 2023 Report Posted August 8, 2023 On 5/19/2023 at 9:32 AM, ZentRose said: I set up the pre-buy for today and organized a flight instructor to fly the plane over to the mechanic. The problem is we have been unable to get ahold of the owner to make sure it is insured. My current airplane is going to be sold next week. I will probably be renting for awhile. This is the plane if anyone knows the owner (I am budgeting for an engine overhaul): https://www.trade-a-plane.com/search?category_level1=Single+Engine+Piston&make=MOONEY&model=M20E&listing_id=2416232&s-type=aircraft May I ask who you found to do the pre-buy? I'm trying to schedule a PPI for a 74 M20F that is currently at Foothill at Cable Airport.
Mpsmith92883 Posted November 19, 2024 Report Posted November 19, 2024 Hello, Just wanted to bring this thread back? I’m going to be brining a M20C to KAJO and am looking for pre buy / mechanic / instructor for sign off. Did someone find someone local ? Old school manual gear super excited.
