philiplane Posted January 23, 2023 Report Posted January 23, 2023 (edited) Bad news for anyone who got a reman drive coupling from Quality Aircraft Accessories from August 2018 to September 2021. Not only is the coupling bad, but you have to destroy the alternator it’s mounted to. Before further flight! https://www.qaa.com/wp-content/uploads/QAA-ASB_021-1.pdf Edited January 23, 2023 by philiplane 1
N201MKTurbo Posted January 23, 2023 Report Posted January 23, 2023 It would be better if they explain why you need to trash the alternator. It would be better if they said you need to replace the bearings in the alternator or something like that. Considering that there is no way to tell if the alternator was changed or not, there may be some compliance issues.
hypertech Posted January 25, 2023 Report Posted January 25, 2023 How did you become aware of this? Mine is in this range but not on the list (dodged the bullet unless the list of affected grows).
LANCECASPER Posted January 25, 2023 Report Posted January 25, 2023 I’ve said it before on here, but I wouldn’t let QAA supply parts for my lawn mower. I had a complete fiasco with them on a mag years ago and how they handled it was beyond ridiculous. My only recourse after trying every good faith remedy was American Express and they ended up backing me up. The incompetence and hassle is something I’d never want to go through again. 1 2
GeeBee Posted January 25, 2023 Report Posted January 25, 2023 The drive coupling is something I never buy rebuilt. I always replace with new. I really don't see how you can rebuild those things successfully. 1
Phil EF Posted January 25, 2023 Report Posted January 25, 2023 On 1/23/2023 at 12:20 PM, N201MKTurbo said: It would be better if they explain why you need to trash the alternator. It would be better if they said you need to replace the bearings in the alternator or something like that. Considering that there is no way to tell if the alternator was changed or not, there may be some compliance issues. The instructions say to render the threads on the rotor unusable. Maybe a call can clarify the issue. Especially since it’s not an AD.
N201MKTurbo Posted January 25, 2023 Report Posted January 25, 2023 1 hour ago, Phil EF said: The instructions say to render the threads on the rotor unusable. Maybe a call can clarify the issue. Especially since it’s not an AD. I read that. Why should I destroy a perfectly good alternator? What makes it bad? Why can't I just fix what is bad about it?
LANCECASPER Posted January 25, 2023 Report Posted January 25, 2023 4 minutes ago, N201MKTurbo said: Why should I destroy a perfectly good alternator? Because QAA is now a Hartzell owned company and it would be good for business. 1
jetdriven Posted January 25, 2023 Report Posted January 25, 2023 On 1/23/2023 at 12:05 PM, philiplane said: Bad news for anyone who got a reman drive coupling from Quality Aircraft Accessories from August 2018 to September 2021. Not only is the coupling bad, but you have to destroy the alternator it’s mounted to. Before further flight! https://www.qaa.com/wp-content/uploads/QAA-ASB_021-1.pdf I wonder why they sat on this for a year? to be sure the warranty on the parts in question has ran out? 1 1
N201MKTurbo Posted January 25, 2023 Report Posted January 25, 2023 So, what if I changed out the coupler and the alternator and sold the old alternator on EBay. (without smashing the threads) How would anybody know? What regulation did I violate?
philiplane Posted January 26, 2023 Author Report Posted January 26, 2023 7 hours ago, GeeBee said: The drive coupling is something I never buy rebuilt. I always replace with new. I really don't see how you can rebuild those things successfully. I'm wondering how they could screw up replacing the elastomer portion of the coupling. That's the only thing they replace. They re-use the gear and the main body. What could go wrong that could trash an alternator other than imbalance? Alternators do spin at 6000-8000 rpm at full power.
carusoam Posted January 26, 2023 Report Posted January 26, 2023 If they had a QC problem with the elastomer… What else did it ruin, when it failed? Somewhere out there… is the real answer… Best regards, -a-
