PT20J Posted January 13, 2023 Report Posted January 13, 2023 While you have the interior out, check all the gussets on the tubular structure. On mine, the factory missed spraying epoxy primer into the area behind the gussets and there was some light surface corrosion starting. Easy to clean up and brush on some 2k primer. 1
carusoam Posted January 13, 2023 Report Posted January 13, 2023 8 hours ago, ArtVandelay said: What’s up with all the yellow circuit breakers caps? Seems to me you lose the effectiveness of them highlighting critical breakers (usually just autopilot and trim)? Expect color coding for the next level of emergency… What to do when the alternator takes a hiatus… power shedding… Red for the things I need to kill immediately… AP and trim. PP guessing only… Having an E-bus would be really cool… sort of auto shedding. Best regards, -a-
TheBearFlies Posted January 13, 2023 Author Report Posted January 13, 2023 23 hours ago, ArtVandelay said: What’s up with all the yellow circuit breakers caps? Seems to me you lose the effectiveness of them highlighting critical breakers (usually just autopilot and trim)? When I purchased the plane, April 2022 I did not pay much attention to those initially. When it comes back, I'll review panel and emergency configurations.
Pinecone Posted January 14, 2023 Report Posted January 14, 2023 I would think Red for critical things, like trim and AP. Yellow for load shedding. 1
ArtVandelay Posted January 14, 2023 Report Posted January 14, 2023 I would think Red for critical things, like trim and AP. Yellow for load shedding.The electrical loads for modern avionics are so low I wouldn’t bother except:Lights which have switches.Autopilot/electric trim which is already marked. 1
TheBearFlies Posted January 20, 2023 Author Report Posted January 20, 2023 Decided to go ahead with a Guardian remote CO censor. It will sync and display on the G3x.
PT20J Posted January 20, 2023 Report Posted January 20, 2023 On 1/14/2023 at 7:39 AM, ArtVandelay said: The electrical loads for modern avionics are so low I wouldn’t bother except: Lights which have switches. Autopilot/electric trim which is already marked. With all the avionics on, my 28V system draws about 11 A. I have a 16 Ah battery.
ArtVandelay Posted January 20, 2023 Report Posted January 20, 2023 1 hour ago, PT20J said: With all the avionics on, my 28V system draws about 11 A. I have a 16 Ah battery. My 14V breakdown is: 10A for all lights 12.5A for all avionics excluding AP, not counting radio transmissions. I figure 2.5A for autopilot and servos. So 25 amps, with 33Ah battery, that’s 1 hour with everything on, 2 hours shutting off lights and autopilot. If I was crossing large distances without landing options it would be a concern. 1
TheBearFlies Posted February 1, 2023 Author Report Posted February 1, 2023 No pics this week. AP servos are in, engine sensors, CIES fuel Senders installed.
TheBearFlies Posted February 1, 2023 Author Report Posted February 1, 2023 On 1/5/2023 at 10:30 AM, TheBearFlies said: My understanding is the GDL50R is a remote ADSB transponder that will show Wx and traffic on the G3x. Stratus will remain for backup. Got clarification, GDL50R is a remote ADSB IN, my Stratus will be the ADSB OUT.
TheBearFlies Posted February 3, 2023 Author Report Posted February 3, 2023 Instillation of wire continuing. Layout of pilot panel (see picture) proceeding. Garmin Smart Glide switch will be above the G5. 1 1
TheBearFlies Posted February 13, 2023 Author Report Posted February 13, 2023 It’s been a while but here is the latest update. Panel design is underway. Radio stack, see picture. I fly large fast airplanes for a living and the FCP (flight control panel) is always on top, thus my decision to put the GFC500 first, below the Annunciator panel. Audio next due to the fact that when it’s below the GTN650 the knobs are too close. STARTUS at the bottom. Below will be remote Co and ELT. We lost 23.6 pound of weight just in wire!:) Every pound counts. 3
TheBearFlies Posted February 14, 2023 Author Report Posted February 14, 2023 On 2/13/2023 at 10:58 AM, Evan said: Looks great! Is there a reason you are going with the Stratus and not a Garmin transponder? Already have the Stratus, no reason to buy a Garmin. 1
Pinecone Posted February 15, 2023 Report Posted February 15, 2023 I think I would have put in a GTX-345 (possibly an R) and sold the Stratus. Just my thoughts. 1
TheBearFlies Posted February 20, 2023 Author Report Posted February 20, 2023 On 2/15/2023 at 7:29 AM, Pinecone said: I think I would have put in a GTX-345 (possibly an R) and sold the Stratus. Just my thoughts. At the start of the thread, I listed that a GDL50R ADSB in would be installed and the Stratus would be the ADSB out.
TheBearFlies Posted February 20, 2023 Author Report Posted February 20, 2023 Here are the latest Pics of the panel mock up. CB panel will be redone to match the rest. Choosing a color now.
ArtVandelay Posted February 20, 2023 Report Posted February 20, 2023 I added the AV20S as a tiebreaker in case the Garmin system went down, I think you have the room under the G5.
TheBearFlies Posted February 20, 2023 Author Report Posted February 20, 2023 After looking at the full panel mock up, the pilot G3x and G5 looked low. Those are moving up 1in and the glide sw will go below the G5. Pilot USB will move up slightly also. N number will go above the G5.
TheBearFlies Posted February 20, 2023 Author Report Posted February 20, 2023 52 minutes ago, ArtVandelay said: I added the AV20S as a tiebreaker in case the Garmin system went down, I think you have the room under the G5. The G5 is my backup.
PT20J Posted February 20, 2023 Report Posted February 20, 2023 3 hours ago, TheBearFlies said: The G5 is my backup. The problem is that not all failures are hard roll over and die failures. The GSU 25D and the G5 ADAHRS compare solutions continuously. If they differ, the G3X will annunciate a MISCOMPARE error, but it is up to the pilot to determine which is aberrant. The inexpensive AV-20-S gives you an immediate way to determine which Garmin instrument is having a bad day. 5
Steve0715 Posted February 26, 2023 Report Posted February 26, 2023 What is your total downtime for this upgrade? This is at AATG? I realize these upgrades can be complicated but I find the time frame to be incredibly long. Sarasota Avionics quoted me 3-4 months in their shop for an upgrade that did not include an autopilot. I can’t comprehend using that length of time in a business environment. I can’t find it now but didn’t I read on MS where someone had his upgrade finished in 100-120 hours! Congrats on the new panel, please keep on with the updates..and pictures!
ArtVandelay Posted February 26, 2023 Report Posted February 26, 2023 What is your total downtime for this upgrade? This is at AATG? I realize these upgrades can be complicated but I find the time frame to be incredibly long. Sarasota Avionics quoted me 3-4 months in their shop for an upgrade that did not include an autopilot. I can’t comprehend using that length of time in a business environment. I can’t find it now but didn’t I read on MS where someone had his upgrade finished in 100-120 hours! Mine took 100-120 hours but it’s not continuous, there’s some lull in the work, so ended up being 3-4 months. The panel was sent out to be painted, and then placarded, my JPI was sent out to be updated and then there’s the occasional AOG that takes priority, and then some odds and ends that had to be ordered.All that adds delays, not to mention a hurricane that closed the shop for a week, someone gets sick, someone had to go to training, etc
PT20J Posted February 26, 2023 Report Posted February 26, 2023 Mine took 12 weeks, continuous for GFC 500, G3X/EIS, G5, PMA450B, GTN 650Xi GNC 255, GTX 345, new panel fab, CiES, reweigh, plus a few little things like removing antennas and plugging holes. I did not have to wait for any Garmin equipment and I understand that a lot of shops are building in contingency time for that now that Garmin is frequently backlogged. One thing that gets overlooked is that there are some Garmin boxes that go behind the panel and mounting means has to be fabricated for them. I just talked to Greg Baker at Baker Avionics in Grants Pass, OR at a tradeshow yesterday. He's been doing a lot of Mooneys. Skip 1
TheBearFlies Posted March 1, 2023 Author Report Posted March 1, 2023 On 2/26/2023 at 10:08 AM, Steve0715 said: What is your total downtime for this upgrade? This is at AATG? I realize these upgrades can be complicated but I find the time frame to be incredibly long. Sarasota Avionics quoted me 3-4 months in their shop for an upgrade that did not include an autopilot. I can’t comprehend using that length of time in a business environment. I can’t find it now but didn’t I read on MS where someone had his upgrade finished in 100-120 hours! Congrats on the new panel, please keep on with the updates..and pictures! AATG originally said approximately 8-10 weeks. The original plan was for me to drop the plane off the first week of December 2022. Due to the harsh and early winter in Colorado, I was not able to get the plane to them until right before Christmas. Serious work did not begin on the plane until after the new year holiday. So far it has been 7-8 weeks.
TheBearFlies Posted March 8, 2023 Author Report Posted March 8, 2023 I've been quiet while I picked out the color for the panel. Looked at many colors from different powder coat providers. Not wanting to go with the typical flat black or gray and definitely not wanting feedback from the peanut gallery, I found the color. After talking with the tech's at Prismatic Powders, I was able to to pick my color and an option for a flat clear. AATG was able to show me both without the flat clear and with. Final decision was 3 step with the flat clear. Prismatic Powders: Dragons Blood step 1, Dragons Blood step 2, Phantom Clear Etching has started in white. 2
