vorlon1 Posted December 28, 2022 Report Posted December 28, 2022 (edited) So I'm looking at the cable connections to the Concorde battery and they are attached via an M8x1.5x16mm COPPER bolt. They're showing their age (unknown) and I would like to replace them, but I can't find a source in the US. Anybody have an idea where I can get these without waiting for weeks? Edited January 5, 2023 by vorlon1 add detail to bolt specs Quote
N201MKTurbo Posted December 28, 2022 Report Posted December 28, 2022 You could ask me to send you one from an old battery in my hangar. Quote
vorlon1 Posted December 28, 2022 Author Report Posted December 28, 2022 On 12/28/2022 at 9:20 PM, N201MKTurbo said: You could ask me to send you one from an old battery in my hangar. Expand Yes please! Should I infer that new batteries should come with them? My battery is only 3.5 years old--and dead I'm afraid--but the bolt looks much older... Quote
N201MKTurbo Posted December 28, 2022 Report Posted December 28, 2022 On 12/28/2022 at 9:31 PM, vorlon1 said: Yes please! Should I infer that new batteries should come with them? My battery is only 3.5 years old--and dead I'm afraid--but the bolt looks much older... Expand Yes, batteries come with bolts. If you are buying a new battery, you don't need new bolts. Quote
mike_elliott Posted December 28, 2022 Report Posted December 28, 2022 Concorde will also send you some if you call them. I needed some extra length bolts for my battery minder harness which they gladly sent NC 1 Quote
vorlon1 Posted December 28, 2022 Author Report Posted December 28, 2022 PM sent. Still though, it would be good to have a source if anyone knows of one... Quote
A64Pilot Posted December 28, 2022 Report Posted December 28, 2022 It’s not copper but I forget what it is, They are readily available, I bought a bunch on my boat as I was building bus bars I think it’s silicon bronze or maybe beryllium copper? 1 Quote
vorlon1 Posted December 28, 2022 Author Report Posted December 28, 2022 Thanks Mike. Looks like you hit the send button before I did... 1 Quote
A64Pilot Posted December 28, 2022 Report Posted December 28, 2022 Terminals and bolts are silicone bronze https://legacy.concordebattery.com/flyerprint.php?id=149 Our General Aviation batteries are designed with terminals and hardware of silicon bronze alloy providing a corrosion free, low impedance connection. 1 Quote
vorlon1 Posted December 28, 2022 Author Report Posted December 28, 2022 Nice. Thanks. Still.... source for replacements other than concorde? Quote
A64Pilot Posted December 28, 2022 Report Posted December 28, 2022 On 12/28/2022 at 10:45 PM, vorlon1 said: Nice. Thanks. Still.... source for replacements other than concorde? Expand Hate to say just google, silicon bronze is common, often used in boats. Metric will be a little harder. 1 Quote
vorlon1 Posted December 29, 2022 Author Report Posted December 29, 2022 On 12/28/2022 at 11:17 PM, A64Pilot said: Hate to say just google, silicon bronze is common, often used in boats. Metric will be a little harder. Expand Yeah, I was looking for copper. I had looked at the Concorde site, but missed that call out. Thanks. Quote
Hank Posted December 29, 2022 Report Posted December 29, 2022 On 12/28/2022 at 9:55 PM, A64Pilot said: I think it’s silicon bronze or maybe beryllium copper? Expand Beryllium copper was phased out years ago, it's a carcinogen. Used to be used a lot in injection molding, now other copper alloys are used. Quote
N201MKTurbo Posted December 29, 2022 Report Posted December 29, 2022 On 12/29/2022 at 3:16 AM, Hank said: Beryllium copper was phased out years ago, it's a carcinogen. Used to be used a lot in injection molding, now other copper alloys are used. Expand I needed a piece for a project at work. You can still get it on EBay out of China. Luckily, I found an old relay in my junk box and was able to salvage a contact and gave it to the machine shop and they made the part I needed. I hope they didn’t get berylliosis. The part worked great. Quote
vorlon1 Posted January 5, 2023 Author Report Posted January 5, 2023 Follow up: After looking all over the interweb, I called Concorde, and they indicated that these are hard to find by design to discourage those with a "do-it-yourself' attitude. As indicated by Mike Elliot above, Concorde with send you some if you call them. 1 Quote
Guest Posted January 5, 2023 Report Posted January 5, 2023 On 1/5/2023 at 9:07 PM, vorlon1 said: Follow up: After looking all over the interweb, I called Concorde, and they indicated that these are hard to find by design to discourage those with a "do-it-yourself' attitude. As indicated by Mike Elliot above, Concorde with send you some if you call them. Expand I’ve got a cup of them from retired batteries if you need some. Quote
vorlon1 Posted January 5, 2023 Author Report Posted January 5, 2023 On 1/5/2023 at 11:50 PM, M20Doc said: I’ve got a cup of them from retired batteries if you need some. Expand Many thanks. Concorde is sending two. Quote
A64Pilot Posted January 6, 2023 Report Posted January 6, 2023 They are just standard 8mm silicon bronze bolts, no special thread etc. But for some reason 8mm silicon bronze bolts are hard to find, but I doubt that’s by Concorde’s design. 8MM is very close to 5/16” and is a standard battery terminal size. They use the same bolts on their non aviation Lifeline batteries. I believe I bought copper bars and 5/16” silicon bronze bolts to make bus bars from Georgia Copper and some copper strap for my High Freq radio ground, but I don’t think they have 8mm. Quote
jetdriven Posted January 6, 2023 Report Posted January 6, 2023 On 12/28/2022 at 10:05 PM, A64Pilot said: Terminals and bolts are silicone bronze https://legacy.concordebattery.com/flyerprint.php?id=149 Our General Aviation batteries are designed with terminals and hardware of silicon bronze alloy providing a corrosion free, low impedance connection. Expand The torque on these is 70 inch pounds and they strip out at 72 inch pounds. 2 1 Quote
