rpcc Posted August 29, 2022 Report Posted August 29, 2022 Just paid 500 for a change on my 991.2 so the prices you are quoting seem ok. 1
MikeOH Posted August 29, 2022 Report Posted August 29, 2022 23 minutes ago, rpcc said: Just paid 500 for a change on my 991.2 so the prices you are quoting seem ok. @rpcc $500 is INSANE! I've always done my own oil changes on my 996TT; $20 for filter from PelicanParts, and $65 for 10 qts of Mobil full synthetic. Honestly, one of the easier cars to change the oil. Filter is easily accessible on the TOP of the engine, drain plugs can be reached without even jacking the car! Just slide the drain pan under, reach in and undo the plugs. Of course, I'm a total CB owner... 1
larryb Posted August 29, 2022 Report Posted August 29, 2022 It’s faster and easier for me to do the oil change in my own hangar than fly to the shop and have them do it. Plus I really like to put eyes on everything under the cowl every 25 hours and make sure everything is ok. I almost always find something like chafing or a missing screw. On my last oil change I found something more serious, a cracked spinner backplate. Fortunately the crack was small and I was able to get it replaced before more damage happened. 2
Pinecone Posted August 29, 2022 Report Posted August 29, 2022 10 hours ago, MikeOH said: @rpcc $500 is INSANE! I've always done my own oil changes on my 996TT; $20 for filter from PelicanParts, and $65 for 10 qts of Mobil full synthetic. Honestly, one of the easier cars to change the oil. Filter is easily accessible on the TOP of the engine, drain plugs can be reached without even jacking the car! Just slide the drain pan under, reach in and undo the plugs. Of course, I'm a total CB owner... Agreed. That is NUTS. My M3 takes a "special oil" so $12 - $18 per quart, but only 6 needed. Oil filter is on top, easy to reach. So with a MityVac, it takes maybe 15 - 20 minutes to change the oil and filter. 1
Austintatious Posted August 29, 2022 Report Posted August 29, 2022 On 8/25/2022 at 3:16 PM, eman1200 said: for anyone who's brought their plane in to have an oil change done recently (obviously I haven't in a long time since I do my own, hence the question) what's the going rate these days? a local shop quoted me $500 lol. that's right, FIVE HUNDRED smackers. I have been quoted 550 by the only shop at my field.... I just do it myself and save myself $400.00 2
eman1200 Posted August 29, 2022 Author Report Posted August 29, 2022 I have been quoted 550 by the only shop at my field.... I just do it myself and save myself $400.00Of course, as I normally do as well but now I’m having trouble finding an oil filter and have a trip I’d like to take but need an oil change first. But that’s just too much of a delta to justify.
Pinecone Posted August 29, 2022 Report Posted August 29, 2022 What filter? Some people here have a spare or two they are willing to share.
eman1200 Posted August 29, 2022 Author Report Posted August 29, 2022 1 hour ago, Pinecone said: What filter? Some people here have a spare or two they are willing to share. Champion oil filter CH48110-1 Tempest AA48110-2 but I suspect most people are in the same boat.
eman1200 Posted August 29, 2022 Author Report Posted August 29, 2022 Already have a few offers, thanks guys!
eman1200 Posted August 30, 2022 Author Report Posted August 30, 2022 BREAKING NEWS: mooneyspace member is a local heroAugust 30th Concord, NC: A local man pulled a family of 12 orphaned children out of a burning house, saved 18 dogs and cats and cured Covid. Also he was able to surrender 2 unobtainium oil filters so that eman could get an oil change done on schedule. Not all heroes wear capes.
David Lloyd Posted August 30, 2022 Report Posted August 30, 2022 There were 18 dogs. The cats weren't counted.
eman1200 Posted August 30, 2022 Author Report Posted August 30, 2022 There were 18 dogs. The cats weren't counted.Yeah, cats don’t count!
Jcmtl Posted August 30, 2022 Report Posted August 30, 2022 At my field there is a mechanic that works out of his truck and drives over to the plane. I supply the oil and filter, he does it for $50. I dont even have to be there. He texts me when it’s done. 1
Bunti Posted August 30, 2022 Report Posted August 30, 2022 Years ago, I flew to the shop to get the oil changed. This was time consuming and expensive. In between, I have a local mechanic but I also learned how to do it on my own. As others said before, it is a good time to check everything under the cowling including using my UV-light to check for leaks. I cut the filter and I even fill out the paperwork for the lab and bring the sample to the mailbox. At annual time, my local mechanic changes the oil and the filter and removes and cleans the oil screen. He charges his hourly rate for all the work, including the oil change. I provide oil and filter. I believe it adds no more than an hour to the annual bill because he anyhow has to open and inspect everything. The draining takes place in parallel to other work.
RobertGary1 Posted August 30, 2022 Report Posted August 30, 2022 On 8/25/2022 at 5:14 PM, Rick Junkin said: Umm... yup, my mistake. The $120 was for oxygen servicing. Currently $240 plus oil and filter, with Blackstone analysis thrown in. I use Philips X/C with Camguard and a Tempest filter so about $350 all in unless I do it myself. Sorry for the mis-cue, a mind is a terrible thing. To waste. Cheers, Rick $120 is a great price for oxygen fill. About 1/2 what we pay. But now I get it done at the scuba shop for $25.
RobertGary1 Posted August 30, 2022 Report Posted August 30, 2022 3 minutes ago, Bunti said: Years ago, I flew to the shop to get the oil changed. This was time consuming and expensive. In between, I have a local mechanic but I also learned how to do it on my own. As others said before, it is a good time to check everything under the cowling including using my UV-light to check for leaks. I cut the filter and I even fill out the paperwork for the lab and bring the sample to the mailbox. At annual time, my local mechanic changes the oil and the filter and removes and cleans the oil screen. He charges his hourly rate for all the work, including the oil change. I provide oil and filter. I believe it adds no more than an hour to the annual bill because he anyhow has to open and inspect everything. The draining takes place in parallel to other work. I just leave the old filter sitting on the bench for the IA. -Robert
Pinecone Posted August 31, 2022 Report Posted August 31, 2022 13 hours ago, eman1200 said: Yeah, cats don’t count! More that it is impossible to count cats, as they move around and hide.
eman1200 Posted August 31, 2022 Author Report Posted August 31, 2022 More that it is impossible to count cats, as they move around and hide. exactly what I didn’t mean
kris_adams Posted August 31, 2022 Report Posted August 31, 2022 $300 for years and years. I don't think they are getting rich at that price either.
Guest Posted August 31, 2022 Report Posted August 31, 2022 23 hours ago, eman1200 said: Yeah, cats don’t count! My hangar cat Rod disagrees with you.
Derek Posted September 26, 2022 Report Posted September 26, 2022 Just had one done at my base for $396 for my 201 with Philips 20w50 Victory, filter, and labor. 1
