Glen Davis Posted July 25, 2022 Report Posted July 25, 2022 My friend had the nose wheel tire on his K model go flat this evening upon landing. Fortunately he was able to make it off the runway so the airport did not have to be closed down. I asked him if it caused a prop strike. He said no and that is because (and here is my question) to be certified a plane has to have 9 inches of proper clearance even if the nose wheel is flat and the strut is completely compressed”. Well I actually did not measure it but I don’t think I have 9 inches of prop clearance in my J model even when everything is in perfect condition. Any truth to this certification requirement? And as a follow-up question, what type of suspension system does the nose wheel on a J model or a K model have? Is it a piston or rubber donuts or some thing else? Sent from my iPhone using Tapatalk Quote
Mooney in Oz Posted July 25, 2022 Report Posted July 25, 2022 49 minutes ago, Glen Davis said: what type of suspension system does the nose wheel on a J model or a K model have? Is it a piston or rubber donuts or something else. All M20’s have rubber donuts. Quote
PT20J Posted July 25, 2022 Report Posted July 25, 2022 Almost, not quite. Here’s the reference in CAR 3 which is the basis of certification for the M20 series. 12 3 Quote
PeteMc Posted July 25, 2022 Report Posted July 25, 2022 10 hours ago, PT20J said: Here’s the reference in CAR 3 So out of curiosity... Is the 9" clearance on a tail wheel aircraft while the tail wheel is touching the ground? (e.g. parked or slow taxi) Or while in the takeoff roll when the tail is elevated. And if it is 9" when the TW is down, does it then have a 7" clearance on the takeoff roll? (Some day I gotta get around to that endorsement...) Quote
A64Pilot Posted July 25, 2022 Report Posted July 25, 2022 31 minutes ago, PeteMc said: So out of curiosity... Is the 9" clearance on a tail wheel aircraft while the tail wheel is touching the ground? (e.g. parked or slow taxi) Or while in the takeoff roll when the tail is elevated. And if it is 9" when the TW is down, does it then have a 7" clearance on the takeoff roll? (Some day I gotta get around to that endorsement...) Level takeoff or taxi, whichever is most critical. I don’t believe 7 inches plays into anything on a conventional gear airplane. Quote
PT20J Posted July 25, 2022 Report Posted July 25, 2022 59 minutes ago, PeteMc said: So out of curiosity... Is the 9" clearance on a tail wheel aircraft while the tail wheel is touching the ground? (e.g. parked or slow taxi) Or while in the takeoff roll when the tail is elevated. And if it is 9" when the TW is down, does it then have a 7" clearance on the takeoff roll? (Some day I gotta get around to that endorsement...) Just read it again…slowly 1 1 Quote
PeteMc Posted July 25, 2022 Report Posted July 25, 2022 3 hours ago, PT20J said: Just read it again…slowly Duh! Thanks. 1 Quote
carusoam Posted July 26, 2022 Report Posted July 26, 2022 Glenn, The nose gear is tall enough to protect the engine from a prop strike under most conditions…. For all Mooneys… But, with a missing tire… the blades will be closer to the ground than usual…. Where Mooneys have had prop strikes…. Holes in the ground. Pot holes in the pavement, or washed out soil taxiing off the pavement…. The hole required to cause a prop strike just got a few inches smaller, as the tire deflates…. MS experiences only, not mine… Best regards, -a- 1 Quote
Glen Davis Posted July 26, 2022 Author Report Posted July 26, 2022 Thanks, all. I thing it's a good idea to measure the distance from the tip on the prop to the ground to see if the donuts in the nosegear are up to snuff. Quote
Fly Boomer Posted July 26, 2022 Report Posted July 26, 2022 On 7/24/2022 at 11:38 PM, PT20J said: Here’s the reference in CAR 3 I read 7 inches with air in the tire and "positive clearance" when flat. Quote
A64Pilot Posted July 26, 2022 Report Posted July 26, 2022 11 minutes ago, Fly Boomer said: I read 7 inches with air in the tire and "positive clearance" when flat. And the critical gear (nose wheel here of course) fully compressed But we have all heard or seen prop strikes on level hard surface runways, without flats, so it can be done. Quote
Hank Posted July 26, 2022 Report Posted July 26, 2022 5 minutes ago, A64Pilot said: And the critical gear (nose wheel here of course) fully compressed Our rubber pucks don't compress much. Unless you hit the runway with a whopping descent rate . . . . Quote
OR75 Posted July 26, 2022 Report Posted July 26, 2022 Anyone still have the shock absorber on the nose wheel ? Quote
carusoam Posted July 27, 2022 Report Posted July 27, 2022 7 hours ago, OR75 said: Anyone still have the shock absorber on the nose wheel ? Hard to find on any MSer planes… Many reasons to remove… No reasons to keep… All documented around here somewhere… Best regards, -a- Quote
OR75 Posted July 27, 2022 Report Posted July 27, 2022 12 hours ago, carusoam said: Hard to find on any MSer planes… Many reasons to remove… No reasons to keep… All documented around here somewhere… Best regards, -a- What would be the reasons to remove ? apart from a few lbs saving I still have it installed Quote
jaylw314 Posted July 27, 2022 Report Posted July 27, 2022 21 hours ago, Hank said: Our rubber pucks don't compress much. Unless you hit the runway with a whopping descent rate . . . . Have you SEEN some of my landings?? 1 Quote
A64Pilot Posted July 28, 2022 Report Posted July 28, 2022 7 hours ago, OR75 said: What would be the reasons to remove ? apart from a few lbs saving I still have it installed There are times when I’d like to have one, specifically sometimes I get into bumps that get the nose pogoing up and down, not dangerous, but annoying. Slow down quickly and it stops, I’m talking walking speed not fast taxi. A shock would dampen this resonant movement Quote
BobbyH Posted July 28, 2022 Report Posted July 28, 2022 On 7/26/2022 at 1:58 PM, OR75 said: Anyone still have the shock absorber on the nose wheel ? It was my understanding that "shock absorber" is actually a shimmy damper. If you look at the picture the rubber disks are still there. Quote
carusoam Posted July 28, 2022 Report Posted July 28, 2022 11 hours ago, OR75 said: What would be the reasons to remove ? apart from a few lbs saving I still have it installed This thing is technically the shimmy damper…. A bolt on device for a problem we don’t have… Proper set-up of the nose gear keeps the shimmy out… If it doesn’t, there are wear items that get replaced… Taking the parts off is a maintenance procedure… The savings… must be a whole LB UL. The device is soooo old. It probably doesn’t provide any shimmy absorption… like a 50 year old shock absorber… PP thoughts only… -a- Quote
OR75 Posted July 28, 2022 Report Posted July 28, 2022 maybe remove it and see if there is a difference . put it back if if i don't like how it feels Quote
alextstone Posted July 28, 2022 Report Posted July 28, 2022 3 minutes ago, OR75 said: maybe remove it and see if there is a difference . put it back if if i don't like how it feels I did that first part with a spouse once who refused to fly with me....there was a difference, in a good way 1 Quote
Fly Boomer Posted July 28, 2022 Report Posted July 28, 2022 17 hours ago, BobbyH said: If you look at the picture the rubber disks are still there. And the disks are going to limit travel with or without the other gizmo. Quote
Pinecone Posted July 29, 2022 Report Posted July 29, 2022 Shock absorbers are not typically for travel limit, but they an do wo. They are to dampen motion. So that the nose does not continue to bounce up and down after hitting a bump. Quote
Rjfanjet Posted July 29, 2022 Report Posted July 29, 2022 When I replaced my engine mounts, got to the magic 9" clearance. Before was 7. Quote
