81X Posted January 23, 2022 Report Posted January 23, 2022 Hello! Does anyone know what the part is sticking out of the neck on the top side of the photo? It seems that when I turn the oxygen on and it’s cold out, there is an audible leak that you can temporarily stop if you get your fingers right on that thing sticking out. Started leaking after hydro unfortunately and it’s been back to the hydro place once for repair but still is problematic. Edit- part in question circled in red. Also, leak stops when tank is “shut off” Quote
N201MKTurbo Posted January 23, 2022 Report Posted January 23, 2022 I think it is a pressure relief valve. 1 Quote
kortopates Posted January 23, 2022 Report Posted January 23, 2022 I think it is a pressure relief valve.agreed, first stage of regulator needs to sent for OH, recommend C&L Aero in Redding CASent from my iPhone using Tapatalk 1 Quote
N201MKTurbo Posted January 23, 2022 Report Posted January 23, 2022 2 hours ago, kortopates said: agreed, first stage of regulator needs to sent for OH, recommend C&L Aero in Redding CA Sent from my iPhone using Tapatalk Being a CB, I would just look for a new relief valve. Quote
kortopates Posted January 23, 2022 Report Posted January 23, 2022 6 minutes ago, N201MKTurbo said: Being a CB, I would just look for a new relief valve. If you have the skills, (I know you do), C&L Aero will probably sell you one. They've sold me parts in the past as well. Quote
81X Posted January 23, 2022 Author Report Posted January 23, 2022 7 hours ago, kortopates said: If you have the skills, (I know you do), C&L Aero will probably sell you one. They've sold me parts in the past as well. Thanks, I’ve shipped the whole tank twice and am looking to avoid that again by just replacing the part this time if possible! Quote
N201MKTurbo Posted January 23, 2022 Report Posted January 23, 2022 (edited) What is your tank pressure? If it is near the max then the valve may be working properly and may close after the tank pressure goes down a bit. I would just use this tank of oxygen normally and check the valve periodically. After all you need to empty it to do any service on it anyway, you might as well use it. Edited January 23, 2022 by N201MKTurbo Quote
81X Posted January 24, 2022 Author Report Posted January 24, 2022 11 hours ago, N201MKTurbo said: What is your tank pressure? If it is near the max then the valve may be working properly and may close after the tank pressure goes down a bit. I would just use this tank of oxygen normally and check the valve periodically. After all you need to empty it to do any service on it anyway, you might as well use it. Good point, it’s almost full at 1400, but last time I ran it, it went from full to empty in a 1.5 hour flight. Kind of not thrilled to see that happen again. Quote
81X Posted February 2, 2022 Author Report Posted February 2, 2022 The LP relief valve pictures was indeed defective/worn out. Huge shout out to C&L aero https://www.c-l-aero.com/ who helped diagnose and source the part. I would highly recommend them for all of your oxygen needs, and I would go so far as to saying I would gladly pay the extra shipping to ship my tank and equipment across the country to work with them opposed to the miserable service I received from a larger company that mostly caters to the airline customers. Quote
kortopates Posted February 2, 2022 Report Posted February 2, 2022 1 hour ago, 81X said: The LP relief valve pictures was indeed defective/worn out. Huge shout out to C&L aero https://www.c-l-aero.com/ who helped diagnose and source the part. I would highly recommend them for all of your oxygen needs, and I would go so far as to saying I would gladly pay the extra shipping to ship my tank and equipment across the country to work with them opposed to the miserable service I received from a larger company that mostly caters to the airline customers. Great, how did you get it repaired? Did you have to send out the regulator to C&L or was it an easy fix for you to get done locally? Quote
81X Posted February 2, 2022 Author Report Posted February 2, 2022 1 hour ago, kortopates said: Great, how did you get it repaired? Did you have to send out the regulator to C&L or was it an easy fix for you to get done locally? Done locally. Maybe 10 minutes. Didn’t even have to remove the bottle or empty the bottle. 1 Quote
