Here is my solution to hot starts, after a one hour stop. Worked perfectly at last weeks Florida Mooney fly-in. Cooled engine bay at least 35 degrees F. and eliminated any vapor lock. Solar panels keep the the fan turning, and sucking out hot air, even when cloudy. Think Pedro and I should market it? Maybe I'll bring it to MAPA and see what the group says.
Gary in SoFL
Well - This IS FlyDave and I'm wondering the same thing - I didn't post it.
You should log out of Mooneyspace.com and log back in with your own user id, then re-post here to verify your on the right ID.
  • 8 months later...
I have difficulty starting a warm engine some times after shut down.  The first start of the day is perfect and quick.  But if I shut down and then try to restart again later it gives a little trouble.  You mentioned vapor locked.  I aleays thought it was flooded.  How do you tell the difference between vapor locked and flooded??  Also you put solar panels and a fan where?  Thanks!
After that much time you won't be flooded unless your giving her fuel....which you shouldn't. If you've flooded it, you can either smell it with the pass door opened, and/or see some excess fuel on the tarmac.
Other options....Sky Tec high speed starter....rebuilding fuel servo and/or spider....adjusting timing.
I have had my J for about 2 months now and have racked up almost 50 hours.
My mechanic gave me a hot start procedure that has worked every time I've tried it:
  1. Mixture forward
  2. Prop forward
  3. Throttle forward
  4. Master on
  5. Boost pump ~1 second
  6. Mixture full lean
  7. Throttle set ~1000 RPM
  8. Engage starter
  9. In 5-7 blades it starts
  10. Gently ease the mixture in
I've had great success with this hot start technique.
This post DID come from FlyDave
That's a pretty cool fix! I got this procedure, slightly modified, from a MAPA log article. Never once had trouble with a hot start:
- Throttle cracked, for 1000 RPM
- Keep the mixture all the way in cut-off
- Boost pump on (this will not introduce any fuel because of the mixture but helps as the engine catches
- Crank and feed in the mixture after it catches
Works like a charm for me -- even through *eighteen* starts I did the weekend before last, each one a few minutes after the other, to do a compass swing.
A good way to know how much to "crack" the throttle is to leave at the idle position it is at on shut down (i.e., with the engine at idle, pull the mixture to idle cut-off and don't touch the throttle until after the engine is started again.)  That seems to be about the correct amount to crack the throttle.
Lee
