PilotX Posted March 23, 2021 Report Posted March 23, 2021 As I continue my foray into interior renovation, I have not found replacement plane plastics. Are the front plastics the same in the 1990K and M? Might go the AeroComfort interior (planning yoke and glare shield) in the future but initially prep/paint is the plan but if I break something I need to have a source to fix it. Found some u-channel and matching color screws through Jaeger. Also have some old wool-like covering on the kick panels, might try to recover in leather. Could be exciting if I can match it.
LANCECASPER Posted March 23, 2021 Report Posted March 23, 2021 2 hours ago, PilotX said: As I continue my foray into interior renovation, I have not found replacement plane plastics. Are the front plastics the same in the 1990K and M? Might go the AeroComfort interior (planning yoke and glare shield) in the future but initially prep/paint is the plan but if I break something I need to have a source to fix it. Found some u-channel and matching color screws through Jaeger. Also have some old wool-like covering on the kick panels, might try to recover in leather. Could be exciting if I can match it. I started to try and do that and when I saw what one panel looked like i decided to talked them to Hector at Aero Comfort. If possible, do it once and do it right, never look back.
PilotX Posted March 23, 2021 Author Report Posted March 23, 2021 2 hours ago, LANCECASPER said: I started to try and do that and when I saw what one panel looked like i decided to talked them to Hector at Aero Comfort. If possible, do it once and do it right, never look back. I didn't plan this out I just kept pulling panels so I will probably be stuck with just the yoke and glare shield a the moment. I found the matching ultra leather which will allow me to do the baggage compartment and kick panels. I will ask Hector if he can do the headliner when I get the other parts out. Should be able to fly with the headliner removed. I should have just left everything in place. No call from Avionics yet so I guess they figured everything out.
LANCECASPER Posted March 24, 2021 Report Posted March 24, 2021 Back in early 2016 I took everything out and gave it to Hector and then flew it to an avionics shop and let them do their thing w/o the interior. They were thrilled.
carusoam Posted March 24, 2021 Report Posted March 24, 2021 Hector’s interior shop is a magical place... full up with skill and craftsmen... and great ideas... Best regards, -a-
drstephensugiono Posted May 30, 2022 Report Posted May 30, 2022 Back in early 2016 I took everything out and gave it to Hector and then flew it to an avionics shop and let them do their thing w/o the interior. They were thrilled.My glare shield has cracks by the compass and unsightly. Did you do yours? Any pictures?Sent from my iPhone using Tapatalk
kortopates Posted May 30, 2022 Report Posted May 30, 2022 My glare shield has cracks by the compass and unsightly. Did you do yours? Any pictures?Sent from my iPhone using TapatalkHector will make it look like new, covered in faux black leather to match your future yokes. if you can search on here, there are lots of past pictures of his glareshield work. you’ll be very impressed and pleased.i mailed him mine and my seats. you can even more easily mail him plastic to repair and cover.Sent from my iPhone using Tapatalk 2
LANCECASPER Posted May 30, 2022 Report Posted May 30, 2022 1 hour ago, drstephensugiono said: My glare shield has cracks by the compass and unsightly. Did you do yours? Any pictures? https://www.dropbox.com/s/9wvemse0t9xcntp/N134JF panel March 2021.png?dl=0 Hector's team did it and does amazing work. 1
drstephensugiono Posted May 30, 2022 Report Posted May 30, 2022 https://www.dropbox.com/s/9wvemse0t9xcntp/N134JF panel March 2021.png?dl=0 Hector's team did it and does amazing work.Your dash set up and glare shield is absolutely gorgeous Sent from my iPhone using Tapatalk
LANCECASPER Posted May 30, 2022 Report Posted May 30, 2022 4 minutes ago, drstephensugiono said: Your dash set up and glare shield is absolutely gorgeous Thank you - here are the before pictures. https://www.dropbox.com/s/711nx827qazfbrr/IMG_0312.thumb.JPG.5bc9cd866d089840e307d0758795cd94.JPG?dl=0 https://www.dropbox.com/s/xh9o337503e21lb/IMG_0310.thumb.JPG.7424735ce6ebc48b44be4a189e5eff2f.JPG?dl=0 it's my pattern to get things just the want I want them before I sell them and start the process all over again . . lol
drstephensugiono Posted May 31, 2022 Report Posted May 31, 2022 Thank you - here are the before pictures. https://www.dropbox.com/s/711nx827qazfbrr/IMG_0312.thumb.JPG.5bc9cd866d089840e307d0758795cd94.JPG?dl=0 https://www.dropbox.com/s/xh9o337503e21lb/IMG_0310.thumb.JPG.7424735ce6ebc48b44be4a189e5eff2f.JPG?dl=0 it's my pattern to get things just the want I want them before I sell them and start the process all over again . . lolThat’s what my dash looks like now! What U spent on your avionics and upgrade?Sent from my iPhone using Tapatalk
LANCECASPER Posted May 31, 2022 Report Posted May 31, 2022 6 hours ago, drstephensugiono said: That’s what my dash looks like now! What U spent on your avionics and upgrade? I try not to think about that .. lol I was patient and bought some items used and did it in phases, which I do not recommend. It is better to plan it out carefully and just do it all at once, much less labor to not have to tear everything apart 2-3 times. But to answer your question, all included, I had about $70,000 into the panel upgrades. It would be considerably more now I believe. I started it back in late 2015 before a lot of the newer options were available.
