Fritz Kaiser Posted February 25, 2021 Report Posted February 25, 2021 Hi folks, today my O1 is out of the anual an the avionic shop starts the work for an upgrade: 2 x GI275 GTN 750Xi traffc avoidance from AIR avionics suction pump removal and ADS B transponder panel before: at Avionik Straubing 6
Seth Posted February 26, 2021 Report Posted February 26, 2021 Fantastic! I'm looking forward to seeing the after photos! I do see a GI275 in my future (maybe two!). -Seth
carusoam Posted February 26, 2021 Report Posted February 26, 2021 Good luck Fritz! See @Fly_M20Rs pics of his pair of 275s... Looks like a great powerful solution... Best regards, -a-
PilotX Posted April 8, 2021 Report Posted April 8, 2021 Suction pump has to stay in mine because I have the cheap speed brakes. Jealous. Just rand down the plumbing today to figure out where it goes and I guess we flip coin to see which vacuum pump goes. Do you spend the time to remove the hard one now, or later when you have to replace it?
carusoam Posted April 9, 2021 Report Posted April 9, 2021 7 hours ago, PilotX said: Suction pump has to stay in mine because I have the cheap speed brakes. Jealous. Just rand down the plumbing today to figure out where it goes and I guess we flip coin to see which vacuum pump goes. Do you spend the time to remove the hard one now, or later when you have to replace it? wait til you see the technicality that goes with that situation... I believe it is all documented around here somewhere... Best regards, -a-
Fritz Kaiser Posted April 9, 2021 Author Report Posted April 9, 2021 Hi folks, today I flew her home. Have a look! 6 1
KLRDMD Posted April 9, 2021 Report Posted April 9, 2021 On 2/25/2021 at 7:15 PM, Seth said: I do see a GI275 in my future (maybe two!). I am NOT a Garmin fan at all. But my current airplane came with dual 275s and I have to admit, they're pretty darned good. I don't care for the 650 that is in the panel of my airplane, Avidynes are far superior, in my opinion.
Oldguy Posted April 9, 2021 Report Posted April 9, 2021 22 hours ago, PilotX said: Suction pump has to stay in mine because I have the cheap speed brakes. Jealous. Just rand down the plumbing today to figure out where it goes and I guess we flip coin to see which vacuum pump goes. Do you spend the time to remove the hard one now, or later when you have to replace it? I am in the same boat, and the easy answer for me was the heavy one in the back came out. Added ~12 lbs. UL.
Mscheuer Posted April 9, 2021 Report Posted April 9, 2021 Thanks for keeping your PMA8000BT, that made my day Fritz! Beautiful panel and now there is an airshow to go to. We are on our way to Sun N Fun. If you are there next week, stop by and see us. Building D, right inside the hangar doors! 2
PilotX Posted April 9, 2021 Report Posted April 9, 2021 52 minutes ago, Oldguy said: I am in the same boat, and the easy answer for me was the heavy one in the back came out. Added ~12 lbs. UL. I have two, one above the other. I am going to take the harder to reach one out, which should make oil changes less messy. 1
