Question for 252 owners and maintainers that have the vacuum speedbrake system.
What engine rpm do you need to get normal extension of the speedbrakes?
I have never paid attention before, but I recently noticed that my speedbrakes don’t deploy at idle power on the ground. Maybe that’s normal as the vacuum pump will be turning pretty slowly. They work fine in the air, which is normally the only place I activate them.
Just trying to determine if I have a vacuum leak or if all is normal. I have no vacuum instruments so the pump is only running the speedbrakes.
Thanks
Mine used to deploy on the ground or anytime the engine was running, even at idle. But they don't anymore. It has gotten to the point where they won't deploy on final with the engine at idle power either.
It could be a weak vacuum pump or leaky vacuum line. It could also be one of the boots on the speed brakes as well. I'm pretty sure my issue is with the vacuum system and not the speed brakes themselves. I have to get up to about 22" to get the vacuum gauge to wake up.
My vacuum brakes are being replace with electric brakes right now during the Encore conversion.
Thanks Paul. My servo in the belly is in excellent shape. Rubber is not stiff or brittle. So I am guessing I have a vacuum leak from my recent panel work. Finding it may be a challenge however.
If you have a backup vacuum system installed, you could try to extend the brakes at idle with the backup pump on to see if that changes anything. I check mine just before starting the run up so c. 1000rpm.
Check the conduits running in the wheal well for cracking, which adds quite a bit of resistance to extending the brakes. Grab it with your hand and see if it brittle. It doesn't last 35 years! The system only needs idle vacuum. The vacuum line is pretty strong plastic/nylon. Leak is unlikely if the cannister is in good shape.
Mine are slow to deploy and retract in the cold weather in my 231 so that could be a factor.  They may also need some maintenance to reduce that effect as it’s really annoying when they take their time to retract in flight.
At one point, I had a cracked vacuum line and they were really slow to deploy as well.
  • squeaky.stow changed the title to 252 Vacuum Speedbrakes question
Today my pilot side was slow to retract. I've read there suppose to be serviced. Anyone knows where to get the specifics on servicing them?
@J Bird that is surely one way to service them...
There is a discussion around here about the best way to clean and lube them...
Slow, is a typical dirty, lack of lubricant issue...
No longer attached to the drive... that is a worn out clutch syndrome...
I sent my for service when the clutches were worn... I hardly ever used them.  So I assume the prior owner must have liked them... :)
Mine get tested prior to flight. Not much activity after that...
One should not confuse service requirements of electric brakes with Vacuum brakes. They are entirely different. Precise does not service Vacuum brakes as any A&P can replace parts that is causing the issue. Vacuum brakes utilize a sealed bearing that Precise says not to lubricate since you can't get lubrication in past the seal, but by trying too one enables the bearing to attract more dirt.
  • The bearing is replaceable, but the brake has to be de-riveted to get at the bearing inside and then riveted back together.
  • The spring is replaceable that pulls the brake back down. Easiest fix but if the spring hasn't broken its probably okay.
  • The conduit and cable are replaceable when it becomes brittle and begins to crack. This will cause the brake to extend slowly and also hang while retracting -  making many think the vacuum is weak. The system doesn't need more than ordinary vacuum, including idle vacuum.
  • The cannister that pulls the cable when vacuum is applied used to be replaceable but not currently - Brittain was about to supply them when they went out of business.
  • Of course a vacuum leak from the pump to the cannister can be an issue, but there will probably be other symptoms of a vacuum leak as well.
  • The electrical relay parts, switches etc are replaceable but rarely cause a problem.
Bottom line is they are very simple system. But after 20+ years they may need some maintenance to replace some parts
We did a thorough inspection of all components during my annual this past week. From the vacuum canister to the brakes themselves everything was in remarkably good condition for a 35 year old airplane. No stiff cables or bellows or broken springs.
During my recent panel upgrade I had the last remaining components of the vacuum system behind the panel tidied up and redundant hoses removed, along with a ton of extra wiring from removed systems. There were a lot of extra hoses that were capped and left when all of the vacuum instruments were removed some years ago.
Since the speedbrakes were working well prior to this upgrade, my strong suspicion is that something got left open in the vacuum system behind the panel during this work.
I am hunting down an automotive smoke generator used for testing car vacuum systems for leaks. Hopefully that will help us pinpoint the leak. Should have an answer late next week.
By the way Paul @kortopates , we also got those pesky voltage regulators adjusted down to 28.3V as per the manual. So I am no longer cooking my battery. Thanks for the advice on that isssue.
Problem solved. It was an old instrument vacuum hose behind the panel that had not been plugged. SBs pop right up at idle now.
  • 2 weeks later...
Call Don Maxwell-he may be able to rebuild the cartridge.  My vacuum operated brakes finally would not deploy.  Service tech siliconed the holes in the boots up,  lasted about 4 flights.  Rebuilt the cartridges and about 3 pounds or less will deploy the brakes.  Much cheaper than the electric, although I could deep six the vacuum pump if I had converted to the electric-my panel is all glass now.
On 1/21/2021 at 9:09 PM, J Bird said:
I have the electric speed brakes and from this link I guess the new ALC unit as my left brake is slowly going up and gets stuck to which it slams down and the right side sympathetically drops too. I thought this link would show how to lubricate but all this says is to remove both speed brakes and ALC and send them in for overhaul starting at 2amu’s. Does anybody know of a maintenance guide for where to lubricate areas and what type of lubricate to use? Mouse milk, 10w-40, grease?
Hi Paul, @gsxrpilot, do you have an estimate on what your vacuum to electric speed brake conversion will cost? Feel free to PM if you'd like. Issues seem to keep popping up with my vacuum system and I think it's time to bite the bullet during the next annual. My speed brakes are the last component still operated by vacuum.
Thanks,
Brett
Hi Brett, I think my speed brake conversion will come in around $3K all in. But this is a bit of a unicorn deal.
  • I was able to buy a second-hand set of electric speed brakes for about $2K.
  • A new set of speed brakes from Precise Flight are $6600.
  • The used speed brakes I found, are an earlier version of the Precise Flight speed brakes and fit into the wing much like the vacuum brakes I'm taking out.
  • The current version of brakes available from Precise, evidently takes a bit more modification to install. This means the labor costs would probably be higher.
I'd probably budget $10K for a full, brand new, electric speed brake conversion.
*It only took me 5 years of looking to come across the used set of brakes that I was able to acquire.
Great, thanks for the quick response, Paul. $10K is about what I've heard before which makes it a hard pill to swallow but I think it's time. Well done on finding your set of speed brakes and I hope you enjoy your Encore conversion when it's all done!
Thanks!
Brett
  • 1 year later...
Does anyone in this form have the install and user guide for the precise flight vacuum speedbreaks?  I have them installed in my aircraft which I believe may have been the first ever plane that precise flight installed them on as they were installed pre STC.   The paper work I have with them does not correspond with what is in the aircraft.   I'm not sure what activates yours but mine are simply activated by turning the throttle 1/4 of a turn counter clockwise, no activate button, no on/off button just a simple 1/4 to the left.   Lets just say this isn't ideal on final for a newer pilot like myself.   Any information anyone has would be appreciated.
Welcome aboard dpaget!
getting a surprise deployment of speed brakes would be unwelcomed….
The good news… PreciseFlight is alive and well…
Contact them with your request…
https://preciseflight.com/general-aviation/speedbrakes/
On 4/27/2022 at 1:49 PM, dpaget21 said:
Does anyone in this form have the install and user guide for the precise flight vacuum speedbrakes?  I have them installed in my aircraft which I believe may have been the first ever plane that precise flight installed them on as they were installed pre STC.   The paper work I have with them does not correspond with what is in the aircraft.   I'm not sure what activates yours but mine are simply activated by turning the throttle 1/4 of a turn counter clockwise, no activate button, no on/off button just a simple 1/4 to the left.   Lets just say this isn't ideal on final for a newer pilot like myself.   Any information anyone has would be appreciated.
Most everyone's speed brakes activate using a switch on the yoke, just like PTT switch, along with a light on the panel to show they're activated. You should be able to have your mechanic or shop modify your setup to do that. They don't need precise flight documentation to make that change.
Interesting setup you have, never heard of anything like that and not sure why a pilot would want them on the throttle. Makes me wonder if that was to allow easy activation on landing, but its just as easy with the yoke switch. I know a number of people whom like to use them on landing - but there is no need once you're good with speed control IMO..
  • 11 months later...
I spoke to an outfit in the midwest 2-3 years ago who was trying to re-manufacture the bellows for the original speed brakes.  Lost their contact information.  Anyone have that?  Many thanks.
