tmo Posted September 20, 2020 Report Posted September 20, 2020 (edited) I know there were a number of threads on screw kits, but I never saw a definite shopping list for a M20K. Does anyone have one? I attempted to write down all the various screws, washers, nuts and whatnots from an IPC I have, but my copy is not searchable, so I gave up pretty fast. Does anyone have a M20K IPC that would be a proper PDF, searchable, with proper text in it, not a bunch of scanned pages? Getting stuff shipped from the US piecemeal is becoming a pain and I'm at a point where I'll be happy to spend the extra $$$ on a bunch of screws I probably won't need just to have the ones I will need in a box near the plane when I need them. I realize that after 40 years some of the screws from the IPC might have changed in size (as in, oversize screws were installed at some point in time) so pointers / suggestions based on experience are also most welcome. Edited September 20, 2020 by tmo
Hank Posted September 20, 2020 Report Posted September 20, 2020 During annual, I always replace some inspection and belly panel screws. Take one of each old screw to where you buy aircraft screws and get 100 of each. If you order them unstead, figure out what they are and order 100 of each. The cost is pretty minimal that way, and you always have them on hand. I stock only three sizes--countersunk belly screws (the dimpled washers are pricey!), inspection panel screws and prop spinner screws.
EricJ Posted September 20, 2020 Report Posted September 20, 2020 Aircraft spruce has stainless kits for Mooneys. One of these kits was one of the first purchases I made for my airplane and it's been very, very useful to have around. https://www.aircraftspruce.com/catalog/hapages/exterwasherkit.php 1
Dreamlifter Posted September 20, 2020 Report Posted September 20, 2020 2 hours ago, EricJ said: Aircraft spruce has stainless kits for Mooneys. One of these kits was one of the first purchases I made for my airplane and it's been very, very useful to have around. https://www.aircraftspruce.com/catalog/hapages/exterwasherkit.php Not in stock for a 1976 M20C 1
PT20J Posted September 21, 2020 Report Posted September 21, 2020 Try https://www.planepartsinc.com/product-category/kits-stainless-aircraft-kits-hardware-assortment-kits/page/6/ 1
tmo Posted September 21, 2020 Author Report Posted September 21, 2020 Hank, it's not as easy this side of the pond last time I went to a screw shop I barely got one of a dozen to match. And I had to say they are for an old tractor. That's why I want to order a bunch from the US and have what I need on hand. Good call on the spinner ones, added to the list. Skip, Eric - thanks - I guess I'll follow your advice and start with a kit. With any luck, it will have what I need when I need it. The ask for a machine-readable version of a M20K IPC still stands, if anyone can provide.
Hank Posted September 21, 2020 Report Posted September 21, 2020 9 minutes ago, tmo said: Hank, it's not as easy this side of the pond last time I went to a screw shop I barely got one of a dozen to match. And I had to say they are for an old tractor. That's why I want to order a bunch from the US and have what I need on hand. Good call on the spinner ones, added to the list. Skip, Eric - thanks - I guess I'll follow your advice and start with a kit. With any luck, it will have what I need when I need it. The ask for a machine-readable version of a M20K IPC still stands, if anyone can provide. I live 35 Mooney minutes from Aircraft Spruce, so I took one of each with me and left with bags of 100. Your friendly local Mooney A&P would probably be happy to help you dig through the arcane aircraft screw terminology over a beer one evening . . . or lunch most any day. Then order them from Spruce. 1
tmo Posted September 21, 2020 Author Report Posted September 21, 2020 @PT20J @EricJ - do these kits contain tinnemans and washers, or just screws? If not, any recommendations on sizes of tinnemans I should add to the order? The washers I can handle.
EricJ Posted September 21, 2020 Report Posted September 21, 2020 1 hour ago, tmo said: @PT20J @EricJ - do these kits contain tinnemans and washers, or just screws? If not, any recommendations on sizes of tinnemans I should add to the order? The washers I can handle. Mine has screws and the countersunk washers, iirc, but no Tinnerman or other nut plates. 1
carusoam Posted September 21, 2020 Report Posted September 21, 2020 My C had mostly one size / style of tinnermans.... Clip style for the belly panel screws... except some tiny tinnermans used for the dog house... I have no knowledge if the M20K changed fastener styles for the M20K... So... Pull one out from the belly panels, and order a bunch... The springiness wears over time as does their ability to hold a screw in place... Best regards, -a- 1
PT20J Posted September 21, 2020 Report Posted September 21, 2020 5 hours ago, tmo said: @PT20J @EricJ - do these kits contain tinnemans and washers, or just screws? If not, any recommendations on sizes of tinnemans I should add to the order? The washers I can handle. No Tinnermans. I ordered #4, #6 and #8 Tinnermans separately. #4 used for some interior screws. The exterior screws at #6 and #8. But, I rarely have to replace a Tinnerman. Skip 1
Dreamlifter Posted October 12, 2020 Report Posted October 12, 2020 On 9/20/2020 at 9:16 PM, PT20J said: Try https://www.planepartsinc.com/product-category/kits-stainless-aircraft-kits-hardware-assortment-kits/page/6/ Got it, Thanks!!
