Jakes Simmons Posted September 3, 2020 Report Share Posted September 3, 2020 I tried a search earlier but mainly found threads discussing the Velcro style added PTT or an emergency mic button. I’ve got a 76 Ranger with PTT buttons on both yokes but they are the same tiny, little, red, wimpy, and sharp ones I seem to have been plagued with over multiple light aircraft. I want a real rounded button! Parts store searches only brought up the same fragile stuff. Has anyone here managed a source for a big ‘ol comfy mic button or momentary switch like the big iron has? Appreciate the wisdom in advance. Getting the GNC 355 and 106b combo installed early October, would enjoy having a new manly button to go with. Quote Link to comment Share on other sites More sharing options...
ShuRugal Posted September 3, 2020 Report Share Posted September 3, 2020 Cut the thumbstick off a PlayStation or Xbox controller and glue it on top? Quote Link to comment Share on other sites More sharing options...
Hank Posted September 3, 2020 Report Share Posted September 3, 2020 This is the little girly button in a manly mounting in my C. Quote Link to comment Share on other sites More sharing options...
carusoam Posted September 3, 2020 Report Share Posted September 3, 2020 There is a thread around here where everyone posted what button they are using... Some are just swapping out the plastic cap on a standard button... Others have gone to the electronic parts supplier catalogs... Mechanics are pretty good about sourcing proper parts if the legal issues are a concern... The PTT buttton gets mentioned so many times... some skill with the search function helps... https://mooneyspace.com/search/?q=PTT button&updated_after=any&sortby=relevancy&search_and_or=and PP thoughts only not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Dream to fly Posted September 3, 2020 Report Share Posted September 3, 2020 There is an electronic store that has some good quality switches but they are not approved by the FAA to turn the flow of electrons on and off. MPJA.comSent from my E6910 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Greg Ellis Posted September 3, 2020 Report Share Posted September 3, 2020 I have something like this. My 63 C model did not have PTT built into the yoke. This is hardwired into the comm system and velcroed around the yoke both on the pilot and co-pilot side. It has worked well for me for 14 years or so. Quote Link to comment Share on other sites More sharing options...
M20F-1968 Posted September 5, 2020 Report Share Posted September 5, 2020 ALCO TPC13CO SPST-N/O 125VAC 1A Momentary Mini Push Switch This may sound counterintuitive based on the description of what you want however you might consider this switch. Generally in a Mooney there is not much room to put the PTT switch. That is true for me with my Ovation yokes and multiple switches on the pilot side. I bought several switches and looked them over with my mechanic (very experienced). Some had tactile feedback, and this ALCO switch did not. This is the one he recommended and given his experience I went with it. He is very experience with Mooneys and his assessment was correct: 1. The switch is very small and overall size, however there is sufficient thread length to mounted just about anywhere 2. The button moves very easily so that all you need to really do is touch it and makes connection 3. It is responsive and given its ease of motion does not cause finger fatigue 4. It can be mounted on the yoke directly under your left index finger or anywhere else it is needed 5. He to told me he has been mounting Alco switches for years and they just continue to work without problems 6. 10 of them can be bought on eBay for $12.95 for the lot 10: https://www.ebay.com/itm/ALCO-TPC13CO-SPST-N-O-125VAC-1A-Momentary-Mini-Push-Switch-New-QTY-10/163516664522?hash=item26125a4aca:g:mUQAAOSw5F9fGhkK 7. I have been using it now for over a year and am very happy with the result 8. The switch works so seamlessly, all you need to do is place your finger over the spot where the switch is, no fatigue, no switch indentation in your fingertip, and no pain Quote Link to comment Share on other sites More sharing options...
Jakes Simmons Posted September 6, 2020 Author Report Share Posted September 6, 2020 I appreciate the info on the ALCO switch, that looks about the best option so far. My PTT buttons are internal on both yokes. Earlier today I saw what I REALLY wanted at MicroCenter. They had multi colored buttons for use in building an arcade cabinet, remember those big ones you could smash on all day long, day after day, quarter after quarter? Unfortunately the mounting hole is bigger than the whole side of my yoke but so cool... Quote Link to comment Share on other sites More sharing options...
Hank Posted September 6, 2020 Report Share Posted September 6, 2020 7 minutes ago, Jakes Simmons said: I appreciate the info on the ALCO switch, that looks about the best option so far. My PTT buttons are internal on both yokes. Earlier today I saw what I REALLY wanted at MicroCenter. They had multi colored buttons for use in building an arcade cabinet, remember those big ones you could smash on all day long, day after day, quarter after quarter? Unfortunately the mounting hole is bigger than the whole side of my yoke but so cool... Ask 'em if they have any smaller buttons . . . . And point at the big ones you prefer. Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted September 6, 2020 Report Share Posted September 6, 2020 2 hours ago, Jakes Simmons said: I appreciate the info on the ALCO switch, that looks about the best option so far. My PTT buttons are internal on both yokes. Earlier today I saw what I REALLY wanted at MicroCenter. They had multi colored buttons for use in building an arcade cabinet, remember those big ones you could smash on all day long, day after day, quarter after quarter? Unfortunately the mounting hole is bigger than the whole side of my yoke but so cool... Am I dating my age when I think of the flipper buttons on a pinball machine? Quote Link to comment Share on other sites More sharing options...
cliffy Posted September 7, 2020 Report Share Posted September 7, 2020 Any Mil Spec rated switch is legal to use in a certified airplane. It doesn't need separate FAA approval or PMA Even 'Space Qualified" switches are legal. $$$$$$$ Start looking in electronic supplier catalogs. Quote Link to comment Share on other sites More sharing options...
Yetti Posted September 7, 2020 Report Share Posted September 7, 2020 Consider that your switches may have lost the top cap. It's easy to do. Quote Link to comment Share on other sites More sharing options...
Jakes Simmons Posted September 7, 2020 Author Report Share Posted September 7, 2020 That’s a good one. Quote Link to comment Share on other sites More sharing options...
