JimK Posted July 17 Report Posted July 17 Someone please correct me if I’m wrong but I think his thread confuses the 310hp STC with O3. They are not equivalent. You can add the STC to any Ovation but it is much more extensive to fully convert an older model to an O3. A O3 is a model that rolled out of the Kerrville factory with 310hp but it also has the O3 paint job with O3 badges, some interior improvements like the improved fwd cup holders etc and the GFC700 autopilot which is built into the G1000. The GFC700 autopilot alone is a huge difference. Much better than all the previous APs. 1
LANCECASPER Posted July 17 Report Posted July 17 13 minutes ago, JimK said: Someone please correct me if I’m wrong but I think his thread confuses the 310hp STC with O3. They are not equivalent. You can add the STC to any Ovation but it is much more extensive to fully convert an older model to an O3. A O3 is a model that rolled out of the Kerrville factory with 310hp but it also has the O3 paint job with O3 badges, some interior improvements like the improved fwd cup holders etc and the GFC700 autopilot which is built into the G1000. The GFC700 autopilot alone is a huge difference. Much better than all the previous APs. All Ovation 3s have 310hp and the G1000. Not all 310hp Ovations are Ovation 3s. Many are Ovations and Ovation 2s that have the 310hp STC.
NickG Posted July 18 Report Posted July 18 18 hours ago, LANCECASPER said: All Ovation 3s have 310hp and the G1000. Not all 310hp Ovations are Ovation 3s. Many are Ovations and Ovation 2s that have the 310hp STC. This is technically correct. Although most refer to their STC'd Ovations as "Ovations 3's" but I believe prior to Mooney acquiring the STC, it was a "Standing Ovation". My 1994 Ovation (STC'd) was listed for sale as an "Ovation 3". I had to explain to the broker that Mooney didn't make "Ovations 3's" is 1994.......
FlyingScot Posted July 18 Report Posted July 18 Ovation 2’s with the STC ought to be called Ovation 3++’s since they aren’t limited to the G1000. (12.1” Txi anyone?)
GeeBee Posted July 18 Report Posted July 18 1 hour ago, FlyingScot said: Ovation 2’s with the STC ought to be called Ovation 3++’s since they aren’t limited to the G1000. (12.1” Txi anyone?) Hmmm not quite. Ovation 2 GX is an Ovation 2 with the G1000. 1
FlyingScot Posted July 18 Report Posted July 18 But wasn’t the GX variant certified with the 1000? If so, it suffers the same avionics restriction as the 3. So my logic still stands! (Besides it was a joke!)
Schllc Posted July 18 Report Posted July 18 After putting the flightstream 210 in my g1000, there is no avionic upgrade that I covet. the system is incredible. 1
exM20K Posted July 18 Report Posted July 18 37 minutes ago, Schllc said: After putting the flightstream 210 in my g1000, there is no avionic upgrade that I covet. the system is incredible. What capabilities does the flightstream add that you find the most valuable? -dan
Schllc Posted July 18 Report Posted July 18 The transference of flight plans, and the automatic finding of transitions on the airways. atc never provides transitions for airways and you have to figure it out. not a big deal when they give you your planned route, but when your holding short and get an amendment, or four or five reroutes while leaving south Florida it’s a pia. the flight stream eliminates that. it is incredible, and the only think I really miss from the NXI.
Buckster Posted July 18 Report Posted July 18 I have the flight stream 510 and I appreciate the fact that at home I can file my flight plan from foreflight. I then bring the iPad to the plane and after starting it and turning on the electronics the iPad will transfer the Flight plan to my GTN 750 XI which shares it with the 650 XI. Wireless data transfer, flight plan transfer, data base concierge, entertainment control and phone integration as it works with garmin pilot and foreflight. Anything that helps while flying IFR is a plus.
Pinecone Posted July 20 Report Posted July 20 Be careful, I have had the route I was given to be different from the one FF had.
NickG Posted July 27 Report Posted July 27 On 7/17/2025 at 3:19 PM, LANCECASPER said: All Ovation 3s have 310hp and the G1000. Not all 310hp Ovations are Ovation 3s. Many are Ovations and Ovation 2s that have the 310hp STC. @LANCECASPERwhat was the first year that Mooney sold the "Ovation 3" ? 2005?
LANCECASPER Posted July 27 Report Posted July 27 2 minutes ago, NickG said: @LANCECASPERwhat was the first year that Mooney sold the "Ovation 3" ? 2005? 2007 https://www.flyingmag.com/pilot-reports-pistons-mooney-ovation3/ 1
