Rjfanjet Posted May 7, 2020 Report Posted May 7, 2020 Another new owner question. I have a cotter pin keeping the seats from rolling off the track at the aft end. The parts catalog doesn't show a fantastic picture. Are the pins the only requirement, or should there be something a little more substantial? Thanks 1968C Quote
ShuRugal Posted May 7, 2020 Report Posted May 7, 2020 Just the cotter pins, as far as I know. As long as they are the correct size, and your track and seat are not worn out, they're all that's needed. Quote
lamont337 Posted May 7, 2020 Report Posted May 7, 2020 Mine have a clevis pin secured by a cotter pin. Discussed in this thread: Quote
PT20J Posted May 8, 2020 Report Posted May 8, 2020 Cotter pins are AN380-5-3/ MS24665-418 Alternately, you can use 8-32 screws with nuts and bushings as on the later models. Skip 2 1 Quote
carusoam Posted May 8, 2020 Report Posted May 8, 2020 60’s M20C solution was the cotter pins... If the pins failed... the seat bumped the back seat before they fell off... In a longer plane a more substantial solution is desired... there is an extra 10” to slide back before the back seat becomes involved... PP thoughts only, not a mechanic... Best regards, -a- 1 Quote
tmo Posted May 8, 2020 Report Posted May 8, 2020 I believe I've seen mention of nonSTCed 2x4 pieces of wood strategically placed behind the seat rails as a fail-safe around here somewhere... 1 Quote
aviatoreb Posted May 8, 2020 Report Posted May 8, 2020 1 hour ago, tmo said: I believe I've seen mention of nonSTCed 2x4 pieces of wood strategically placed behind the seat rails as a fail-safe around here somewhere... That’s my idea I think - no stc needed. Quote
ArtVandelay Posted May 8, 2020 Report Posted May 8, 2020 My J has a clamp thingy on the rear, just screws on the front. Quote
M20F-1968 Posted May 8, 2020 Report Posted May 8, 2020 These Cessna seat stops can be made to work on the Mooney seat rails. https://www.aircraftspruce.com/catalog/pspages/saftstop.php The problem with them out of the box is that the opening (narrow most part of internal extrusion) is not wide enough. This can be fixed by milling the opening wider. You can use a straight endmill if you mount the part in a angled drill press vise and bolt it to the milling machine table. I can slide the part onto the Mooney seat rail and tighten it down. That is at the stage I am at now. Given there is not much room back there between the cotter pin stop and the rear of the seat, I am looking into how long I want them to be. If they are longer than needed, they will limit seat travel and make it hared to get in and out. I may be able to gain an inch or so if I drill a new hole for the cotter pin. Having a back-up to the seat pins makes sense. Still experimenting. John Breda Quote
M20F-1968 Posted May 8, 2020 Report Posted May 8, 2020 These Cessna seat stops can be made to work on the Mooney seat rails. https://www.aircraftspruce.com/catalog/pspages/saftstop.php The problem with them out of the box is that the opening (narrow most part of internal extrusion) is not wide enough. This can be fixed by milling the opening wider. You can use a straight endmill if you mount the part in a angled drill press vise and bolt it to the milling machine table. I can slide the part onto the Mooney seat rail and tighten it down. That is at the stage I am at now. Given there is not much room back there between the cotter pin stop and the rear of the seat, I am looking into how long I want them to be. If they are longer than needed, they will limit seat travel and make it hared to get in and out. I may be able to gain an inch or so if I drill a new hole for the cotter pin. Having a back-up to the seat pins makes sense. Still experimenting. John Breda 1 hour ago, RLCarter said: Too bad these won’t fit the rails They will fit with modification. See my post. John Breda Quote
RLCarter Posted May 8, 2020 Report Posted May 8, 2020 1 hour ago, M20F-1968 said: These Cessna seat stops can be made to work on the Mooney seat rails......... John Breda Will have to take a closer look seeing how I have 3 axis mill already Quote
Yetti Posted May 8, 2020 Report Posted May 8, 2020 (edited) 2 hours ago, M20F-1968 said: These Cessna seat stops can be made to work on the Mooney seat rails. https://www.aircraftspruce.com/catalog/pspages/saftstop.php The problem with them out of the box is that the opening (narrow most part of internal extrusion) is not wide enough. This can be fixed by milling the opening wider. You can use a straight endmill if you mount the part in a angled drill press vise and bolt it to the milling machine table. I can slide the part onto the Mooney seat rail and tighten it down. That is at the stage I am at now. Given there is not much room back there between the cotter pin stop and the rear of the seat, I am looking into how long I want them to be. If they are longer than needed, they will limit seat travel and make it hared to get in and out. I may be able to gain an inch or so if I drill a new hole for the cotter pin. Having a back-up to the seat pins makes sense. Still experimenting. John Breda So if you are going to break out the mill..... Why not just make your own from alum stock. Edited May 8, 2020 by Yetti 1 Quote
M20F-1968 Posted May 8, 2020 Report Posted May 8, 2020 2 hours ago, RLCarter said: Will have to take a closer look seeing how I have 3 axis mill already A 2 axis mill and a drill press vise that can be angled and has the tangs to bolt it down is sufficient. You can do it with about a 1/4" straight end mill. John Breda 1 Quote
M20F-1968 Posted May 8, 2020 Report Posted May 8, 2020 2 hours ago, Yetti said: So if you are going to break out the mill..... Why not just make your own from alum stock. The originals are extruded aluminum. It would cost you much more in time and labor to make them from solid aluminum. These parts are not expensive compared to what it would take to make them. John Breda Quote
EricJ Posted May 8, 2020 Report Posted May 8, 2020 9 hours ago, tmo said: I believe I've seen mention of nonSTCed 2x4 pieces of wood strategically placed behind the seat rails as a fail-safe around here somewhere... 8 hours ago, aviatoreb said: That’s my idea I think - no stc needed. The 2x4's need to come from a sawmill with PMA!! Quote
ShuRugal Posted May 8, 2020 Report Posted May 8, 2020 Are the mill and saw compliant with AC 43.13? 3 Quote
