Jeff_S Posted March 20, 2012 Report Share Posted March 20, 2012 I go by what's placarded on the plane itself: 30 in the mains, 49 in the nose. I can tell when the nosewheel needs air because the plane becomes significantly more difficult to pull out of the hangar. That's the one that's doing all the work. Quote Link to comment Share on other sites More sharing options...
tony Posted March 20, 2012 Report Share Posted March 20, 2012 my F manual says 30 on the mains and 49 for the nose gear Quote Link to comment Share on other sites More sharing options...
tony Posted March 20, 2012 Report Share Posted March 20, 2012 dup Quote Link to comment Share on other sites More sharing options...
nels Posted March 24, 2012 Report Share Posted March 24, 2012 I would think a lower air pressure in the main gear tires may help reduce gas tank leaks as it will reduce impact loads during landing. Mooney's don't have much suspension travel from what I've seen. Quote Link to comment Share on other sites More sharing options...
kellym Posted March 27, 2012 Report Share Posted March 27, 2012 Quote: nels I would think a lower air pressure in the main gear tires may help reduce gas tank leaks as it will reduce impact loads during landing. Mooney's don't have much suspension travel from what I've seen. Quote Link to comment Share on other sites More sharing options...
Gone Posted March 27, 2012 Report Share Posted March 27, 2012 Quote: kellym IMHO, an old wives tale. You use the tire pressures specified in the maintenance manual. For B-E models that will be 30psi for all three tires. For F&G models the nose tire is upped to a 6 ply and uses 49 lbs. If you are landing hard enough to have an effect on the tanks, you need some instruction. For you to do anything to the tank, you have to make the wing spar flex. Good luck with that. Quote Link to comment Share on other sites More sharing options...
rbridges Posted March 28, 2012 Report Share Posted March 28, 2012 Quote: Immelman Regarding nose gear pressure: The older Mooneys came with 4-ply tires. The inflation spec is 30psi. Sometime in the M20F they changed over to a 6-ply nosewheel tire. The spec'd inflation went up with that change (to somewhere in the mid 40s). So vintage mooney drivers, take a look at your nose tire: If you're running a 6 ply tire (which technically may not comply with the type certificate), you'll probably need a higher pressure to have the tire properly inflated. Quote Link to comment Share on other sites More sharing options...
nels Posted March 28, 2012 Report Share Posted March 28, 2012 Quote: kellym IMHO, an old wives tale. You use the tire pressures specified in the maintenance manual. For B-E models that will be 30psi for all three tires. For F&G models the nose tire is upped to a 6 ply and uses 49 lbs. If you are landing hard enough to have an effect on the tanks, you need some instruction. For you to do anything to the tank, you have to make the wing spar flex. Good luck with that. Quote Link to comment Share on other sites More sharing options...
outermarker Posted November 26, 2017 Report Share Posted November 26, 2017 With respect to 4-ply vs. 6-ply tires. Would the tire pressure increase just because most are now using a 6-ply tire? A 6-ply tire weighs more and the attitude should remain the same sitting on the ground, but I'd like a good reason for increasing the nose wheel pressure to 49 lbs. This is interesting, at least for me. Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted November 26, 2017 Report Share Posted November 26, 2017 I would stick with 30 all around. I ran 45 for a year and the center of the tire is bare and the edges have tread. Quote Link to comment Share on other sites More sharing options...
Hank Posted November 26, 2017 Report Share Posted November 26, 2017 1 hour ago, outermarker said: With respect to 4-ply vs. 6-ply tires. Would the tire pressure increase just because most are now using a 6-ply tire? A 6-ply tire weighs more and the attitude should remain the same sitting on the ground, but I'd like a good reason for increasing the nose wheel pressure to 49 lbs. This is interesting, at least for me. The engine is heavier, and the location of the wheel changed when the fuselage was stretched to make the F model. 2 Quote Link to comment Share on other sites More sharing options...
Hank Posted November 26, 2017 Report Share Posted November 26, 2017 53 minutes ago, Raptor05121 said: I would stick with 30 all around. I ran 45 for a year and the center of the tire is bare and the edges have tread. Our Cs are supposed to have 30 psi all the way around. Look in your Owners Manual. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted November 27, 2017 Report Share Posted November 27, 2017 I run 30 as per the POH but curious cause I run what is recommend on the tire for everything else. Short story, old guy with an old Harley (1968) bitched that it handled bad, test ride confirmed it was like riding a slinky, bumped the psi up to what was stated on the tires and the issue went away. Personally I might switch to the tire manufacturers recommended psi and see if there is a difference Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 27, 2017 Report Share Posted November 27, 2017 The more pressure the easier it is to move in and out of the hangar! 1 Quote Link to comment Share on other sites More sharing options...
M20F Posted November 27, 2017 Report Share Posted November 27, 2017 I just ignore the operating limitations and fill mine with 100 PSI of NO2. Quote Link to comment Share on other sites More sharing options...
outermarker Posted November 27, 2017 Report Share Posted November 27, 2017 Unless I'm blind can someone tell me what page the tire pressure is listed in the '65E POH? My 1938 Luscombe POH which is only 8 pages, lists the tire pressure. Quote Link to comment Share on other sites More sharing options...
clh Posted November 27, 2017 Report Share Posted November 27, 2017 45 minutes ago, outermarker said: Unless I'm blind can someone tell me what page the tire pressure is listed in the '65E POH? My 1938 Luscombe POH which is only 8 pages, lists the tire pressure. The 65 manual it is on page 30. Quote Link to comment Share on other sites More sharing options...
Gone Posted November 27, 2017 Report Share Posted November 27, 2017 Outermarker: It is on page 30 of my POH attached: M20EPOH.pdf Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 27, 2017 Report Share Posted November 27, 2017 After the C was finished... You find the limitations(?) section of the POH has all the pertinent labels... My C had Labels regarding air pressure for the tires....inside on the gear doors. The Servicing section of the C’s most recent POH has a paragraph related to tire pressure... 30psi... As far as ply(s) go... its a technical term used by tire manufacturers to indicate strength. It may not actually be a count of layers as one would expect. When changing technical details when getting new tires... be sure to make sure they don't stick inside the airframe when retracted... Some dimensions may change when different specs change... PP thoughts and stuff I read about on MS, not a mechanic... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
outermarker Posted November 27, 2017 Report Share Posted November 27, 2017 Thanks Ned...I'll make an appointment to get my eyes checked. I'll write it down on the back of my POH. I have read this POH so many times and today I didn't see it when I wanted to check tire pressure. Thanks all for responding. Quote Link to comment Share on other sites More sharing options...
tony Posted November 27, 2017 Report Share Posted November 27, 2017 10 hours ago, N201MKTurbo said: The more pressure the easier it is to move in and out of the hangar! you got that right! and the older I get, the more important that is. Quote Link to comment Share on other sites More sharing options...
joekinnc Posted March 8, 2019 Report Share Posted March 8, 2019 On 9/6/2011 at 12:24 PM, Seth said: My former 1967 M20F POH also says 30 in mains and 49 in nose. I have to look up the 83 Missile. -Seth Can you share where you found this info - can't find it in the POH for my 67 M20F Quote Link to comment Share on other sites More sharing options...
skydvrboy Posted March 8, 2019 Report Share Posted March 8, 2019 @joekinnc Page 33 in the Landing Gear section. Quote Link to comment Share on other sites More sharing options...
skydvrboy Posted March 8, 2019 Report Share Posted March 8, 2019 On 11/26/2017 at 6:02 PM, RLCarter said: I run what is recommend on the tire for everything else. I know this is an old thread, but I had to comment on this as a guy who worked in the tire industry for 10 years. The rating on the sidewall of a tire is NOT a recommended tire pressure. It is the max pressure for which the tire is rated. The recommended tire pressure is based primarily on the weight/surface contact area that the tire must support. On vehicles, the recommended tire pressure can be found inside the driver's door either on the door itself or on the frame. For motorcycles, the recommended tire pressure is very close to the max rated tire pressure. 2 Quote Link to comment Share on other sites More sharing options...
Prior owner Posted March 8, 2019 Report Share Posted March 8, 2019 On 11/26/2017 at 7:37 PM, carusoam said: As far as ply(s) go... its a technical term used by tire manufacturers to indicate strength. It may not actually be a count of layers as one would expect. Absolutely correct. It is a “ply rating” 1 Quote Link to comment Share on other sites More sharing options...
