joegoersch Posted February 27, 2020 Report Posted February 27, 2020 This is an El Al flight returning from China. Anyone know if there is a STC to put a mask on a Mooney ? Will the same straps work on a long and short body ? 1 1
aviatoreb Posted February 27, 2020 Report Posted February 27, 2020 1 hour ago, joegoersch said: This is an El Al flight returning from China. Anyone know if there is a STC to put a mask on a Mooney ? Will the same straps work on a long and short body ? That seems like it would be significantly more difficult with the technical complication of a propellor on the nose. 1 1 1
tmo Posted February 27, 2020 Report Posted February 27, 2020 You and your science, just getting in the way of the people! (or, perhaps it should be ) 2 1
rbridges Posted February 27, 2020 Report Posted February 27, 2020 I think Bruce's Custom Covers makes a coronavirus version. 3 1
aviatoreb Posted February 27, 2020 Report Posted February 27, 2020 59 minutes ago, tmo said: You and your science, just getting in the way of the people! (or, perhaps it should be ) I have an idea. Maybe a cover on the nose cone of the prop - and then a netting strung between the blades like a sail? It MIGHT reduce the thrust a bit and maybe interfere with cooling the engine, but at least it would full protect the airplane from any germs. 1 1 1
epsalant Posted February 27, 2020 Report Posted February 27, 2020 I have an idea. Maybe a cover on the nose cone of the prop - and then a netting strung between the blades like a sail? It MIGHT reduce the thrust a bit and maybe interfere with cooling the engine, but at least it would full protect the airplane from any germs. Wow! And it might keep air filter cleaner!Sent from my Pixel 3 XL using Tapatalk 1
steingar Posted February 27, 2020 Report Posted February 27, 2020 Obviously photoshop. Any self-respecting Israeli plane would have a yarmulke, not a mask. 1
rbridges Posted February 27, 2020 Report Posted February 27, 2020 3 hours ago, steingar said: Obviously photoshop. Any self-respecting Israeli plane would have a yarmulke, not a mask. Photoshop? You people and your conspiracy theories.
Htwjr Posted February 28, 2020 Report Posted February 28, 2020 Man with corona virus seeks woman with lime disease. 2 2
