HRM Posted December 23, 2019 Report Posted December 23, 2019 So, took my E (The Mistress) out a week ago and everything was good up until application of full power (for TO) and she stumbles and misses. This evening, with A&P/IA on board, we experience the same thing. First thought, fouled plugs. We do the high-power run-up under lean conditions. Second thought, mag timing, we do the dynamic mag check, no joy. So, what should we look at next? Injectors? Run-up (2000 RPM) goes fine. Everything collapses on full-power for TO. Quote
takair Posted December 23, 2019 Report Posted December 23, 2019 Is it momentary stumble or does it get better? Engine monitor? Can you see individual EGTs? Could be servo issue too... Quote
Pasturepilot Posted December 23, 2019 Report Posted December 23, 2019 (edited) How many hours on tour mags? My C model had similar issues a couple years before I bought her and we chased all sorts of leads: Carb rebuilt, replaced intake seals, all sorts of stuff. Carb heat helped. (But that’s not gonna help you a bit) it turns out, the 500 hour inspection was about 200 past due. Sent them out and not a hiccup since. Edited December 23, 2019 by Pasturepilot 1 Quote
HRM Posted December 23, 2019 Author Report Posted December 23, 2019 On 12/23/2019 at 3:18 AM, Pasturepilot said: How many hours on tour mags? Expand Sh*t. They were last rebuilt in 2000. Two decades. Damn. Quote
ragedracer1977 Posted December 23, 2019 Report Posted December 23, 2019 On 12/23/2019 at 3:26 AM, HRM said: Sh*t. They were last rebuilt in 2000. Two decades. Damn. Expand 2000 couldn’t possibly be 2 decades ago.... can it? 3 Quote
ArtVandelay Posted December 23, 2019 Report Posted December 23, 2019 On 12/23/2019 at 3:26 AM, HRM said: Sh*t. They were last rebuilt in 2000. Two decades. Damn. How long have you owned the plane?Might want to check the last time the landing gear motor was serviced while you’re at it.Tom Quote
HRM Posted December 23, 2019 Author Report Posted December 23, 2019 On 12/23/2019 at 12:50 PM, ArtVandelay said: Might want to check the last time the landing gear motor was serviced while you’re at it. Expand I checked. Believe it or not, the landing gear motor has NEVER been serviced! Must be made of nonexistium. 1 Quote
67 m20F chump Posted December 23, 2019 Report Posted December 23, 2019 Does the rpm rise when you pull to idle cut off? IE is the mixture too lean and when you add more air it stumbles. Quote
HRM Posted December 23, 2019 Author Report Posted December 23, 2019 On 12/23/2019 at 1:11 PM, 67 m20F chump said: Does the rpm rise when you pull to idle cut off? IE is the mixture too lean and when you add more air it stumbles. Expand We (my A&P was with me) checked that. All the dynamic (throttle in/out; mixture in/out; flow, etc.) checks were fine. Push it to full throttle and it stumbles. Here's the Savvy chart. FF follows MAP exactly. This was last week when I was solo. I need to get the data from yesterday and upload to compare. Quote
takair Posted December 23, 2019 Report Posted December 23, 2019 EGT 3(?) seems to have something going on. Note the sinusoid vs the others. That may be a valve? Borscope May help there. That said, not sure if that would cause what you describe. If you keep full power does it continue to stumble? Is it popping, violent, etc? Or is it a momentary loss of power that recovers? Could be as simple as an injector clogged or partially clogged. Quote
HRM Posted December 23, 2019 Author Report Posted December 23, 2019 On 12/23/2019 at 2:27 PM, takair said: EGT 3(?) seems to have something going on. Note the sinusoid vs the others. That may be a valve? Borscope May help there. That said, not sure if that would cause what you describe. If you keep full power does it continue to stumble? Is it popping, violent, etc? Or is it a momentary loss of power that recovers? Could be as simple as an injector clogged or partially clogged. Expand It's a sustained stumble, but not violent (like detonation). My first thought was injector and that's an easy check. I'll have yesterday's data up in Savvy later today, on the taxi back we ran it up, ran it down, MAP in, MAP out, etc. Should show something. Quote
Bob - S50 Posted December 23, 2019 Report Posted December 23, 2019 I think that's #4 you are talking about. Quote
MikeOH Posted December 23, 2019 Report Posted December 23, 2019 On 12/23/2019 at 3:53 PM, Bob - S50 said: I think that's #4 you are talking about. Expand I think he's referring to the waviness BEFORE about the 0:09 minute mark in #3 Quote
ArtVandelay Posted December 23, 2019 Report Posted December 23, 2019 EGT #4 goes up when the rest go down, making the wave pattern, I would pull plugs (clean&gap) and check the FF, might as well borescope it at the same time.Tom Quote
takair Posted December 23, 2019 Report Posted December 23, 2019 Looking at this on phone. Waviness is #3 at the pre 9 min mark. I see the #4 now post 9 min. That could certainly hint at things. As suggested, check plugs and injectors there. Quote
Bob - S50 Posted December 23, 2019 Report Posted December 23, 2019 Could also be a mixture issue. If #4 is getting less fuel it will be operating closer to peak EGT. That could be the fuel distributor, the line to the injector, or the injector itself. I'd be tempted to swap the injectors between #4 and one of the others and see if the problem follows the injector or not. Quote
HRM Posted December 23, 2019 Author Report Posted December 23, 2019 Here's the data from our testing yesterday, something definitely wonky with #4. Its intake pipe is where the port for the Precise Flight SVS goes. Now I am wondering if it has gone leaky and is letting air into the manifold. Quote
ArtVandelay Posted December 23, 2019 Report Posted December 23, 2019 The 2 dips in EGT #4 is the cylinder not firing, it’s unlikely a spark problem, fuel or sticking valve? Standard disclaimer: I’m just a PP.... Tom Quote
carusoam Posted December 23, 2019 Report Posted December 23, 2019 Are those screen shots? Or is there a link to the actual data? It helps to be able to click on all the details and see other things... Usually a link shared to the savvy site does this... Data at the run-up is a great way to determine things about the mag health... Best regards, -a- Quote
HRM Posted December 24, 2019 Author Report Posted December 24, 2019 On 12/23/2019 at 11:20 PM, carusoam said: Or is there a link to the actual data? Expand Here you go—I just recently learned about sharing. 1 Quote
Marauder Posted December 24, 2019 Report Posted December 24, 2019 On 12/23/2019 at 10:57 PM, HRM said: Here's the data from our testing yesterday, something definitely wonky with #4. Its intake pipe is where the port for the Precise Flight SVS goes. Now I am wondering if it has gone leaky and is letting air into the manifold. You definitely have a dead #4 cylinder showing up. It’s possible that both spark plugs went offline at the same time but not likely. I had 2 spark plugs in the same cylinder firing intermittently but it looks like both of your’s went dark.You need to look at common factors (injectors, manifold, valves, etc.) to start eliminating things. Good luck, I know how frustrating these things can be.Sent from my iPad using Tapatalk Pro 1 Quote
Marauder Posted December 24, 2019 Report Posted December 24, 2019 Another thought. I subscribe to SavvyAnalysis and have the folks there look at stuff for me when I can’t sort it out. Another set of professional eyes can help.Sent from my iPad using Tapatalk Pro 2 1 Quote
ArtVandelay Posted December 24, 2019 Report Posted December 24, 2019 It’s interesting that FF jumps up when cylinder 4 stops firing, could you have leaking injector? Your fuel pressure drops as well: I would check #4 injector. Tom 1 Quote
HRM Posted December 24, 2019 Author Report Posted December 24, 2019 Thanks all (so far). The goal of this exercise is to drive what gets looked at next Quote
