Jberg411 Posted October 22, 2019 Report Share Posted October 22, 2019 Can an old Mooney holdup to grass strip? Specifically the M20C? If not, what older Mooney might have been designed to take this regular abuse from a new pilot? Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted October 22, 2019 Report Share Posted October 22, 2019 (edited) 2 minutes ago, Jberg411 said: Can an old Mooney holdup to grass strip? Specifically the M20C? If not, what older Mooney might have been designed to take this regular abuse from a new pilot? If the grass is nice and smooth like asphalt you can land anything on it. Once the gopher holes start getting deep you're going to hit the prop. I'd say of the fields I used to go in with the Aeronca maybe 25% would have been ok for a Mooney. And even then only when they were dry. Not after a rain. -Robert Edited October 22, 2019 by RobertGary1 1 Quote Link to comment Share on other sites More sharing options...
smwash02 Posted October 22, 2019 Report Share Posted October 22, 2019 Landed mine on grass frequently. Make sure your biscuits are good or there's a potential for fuel leaks they say. I'm inclined to agree. Quote Link to comment Share on other sites More sharing options...
Guitarmaster Posted October 22, 2019 Report Share Posted October 22, 2019 I would say, occasionally. If it's your home field, a different airframe might be in order.Sent from my Pixel 2 XL using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
skydvrboy Posted October 22, 2019 Report Share Posted October 22, 2019 I think the C model is the best suited Mooney for grass strip landings. I have taken my F in to several grass strips without any issue. If you really want to see what a C can do on grass, checkout these videos. https://www.youtube.com/user/piperpainter/videos WARNING: Do not try strips like you see in those videos as a new pilot! 1 Quote Link to comment Share on other sites More sharing options...
Oldmooney Posted October 22, 2019 Report Share Posted October 22, 2019 I'm based on what's listed as a 2600ft grass strip. I've stepped it off, and it's not that long at all. I know my paces cant be 200 off. Got my private there in my 65C. Rain isn't a problem for ours, as it is crowned pretty well. Extreme dry summers on the Arkansas/Texas border tend to make it a little bouncy. I'm only at 400hrs, but have over 300 takeoff and landings there. I feel most comfortable there as opposed to big runways that make me nervous. Agree with RobertGary, as long as it's a fairly smooth one. Shouldn't have a problem. I cross the threshold/barbed wire fence at 80mph with just me and never have to touch the brakes to turn off 3/4 of the way down. Not an expert,Only my PPL point of viewSent from my SM-G955U1 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Hank Posted October 22, 2019 Report Share Posted October 22, 2019 Grass is no problem for a C. I visit them in mine, and know C owners based on grass. As long as it's half decent, you'll be fine. 1 Quote Link to comment Share on other sites More sharing options...
47U Posted October 22, 2019 Report Share Posted October 22, 2019 My '63C was based on a 1/2 mile grass strip in the northern mid-west for 35 years. It wasn't any worse for the wear, other than my first annual I spent a lot of time cleaning the black dirt out from the bottom of the floor plan when I took the belly panels off. The flight control and landing gear rod ends were also extremely dirty, but that's just a lack of attention to detail from the mechanics who maintained the aircraft (in my opinion). There were generally a few weeks in the spring when the strip was too soft to use from the frost going out and there were smoother strips around, but it wasn't any worse for the wear. The tractor with the snow blower used to leave some tread marks in the snow that would chatter when rolling across them, but it's a solidly built airplane. Really, using the aircraft during the winter with ice and snow on the runway was rougher than the summertime grass. There were some fuel sealant patch jobs done over the years, but nothing out of the ordinary. I'd walk the strip before using it to evaluate its suitability, but a reasonably maintained grass strip shouldn't present any major issues. Tom 1 Quote Link to comment Share on other sites More sharing options...
Jberg411 Posted October 22, 2019 Author Report Share Posted October 22, 2019 You guys rock thank you very much. Great advice. Extremely valuable and appreciated. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted October 23, 2019 Report Share Posted October 23, 2019 9" between the prop tip and a engine rebuild. I had mine on a grass strip within the last 4 weeks. Quote Link to comment Share on other sites More sharing options...
RogueOne Posted October 23, 2019 Report Share Posted October 23, 2019 Some of the smoothest landings I have had have been on grass. As long as the field is not a P.O.S. Mooney is fine. Quote Link to comment Share on other sites More sharing options...
Htwjr Posted October 23, 2019 Report Share Posted October 23, 2019 My 67C has been based on a grass strip for the past 6 years that I have owned it with no problems. I think the grass is more forgiving than asphalt. The only issue is that the tires will probably dry rot before you wear them out on grass. 1 Quote Link to comment Share on other sites More sharing options...
steingar Posted October 23, 2019 Report Share Posted October 23, 2019 I landed a 2500 ft grass strip in Michigan's Uper Penninsula a couple months ago. The trees there forgot to stop growing at 50 feet, by the way. The FAA should do something aobuu that. All I can say is if a ham-fisted pilot like me can do it, anyone can. Just watch for holes and wet spots. Hit those and you can have a bad day. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted October 23, 2019 Report Share Posted October 23, 2019 Actually, the older models are lighter and do not have the inner gear doors introduced on Js so they do fine on grass. IMO the prop strike risk is much greater when taxing away from the runway proper. Our short coupled wheel base can result in amplified nose bobbing if the surface is uneven. We trim full nose up and hold the yoke back while studying the path ahead of the nose wheel for any dips. Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 24, 2019 Report Share Posted October 24, 2019 Welcome aboard, Jberg. I hope you found your answer... There are many Mooneys living on grass fields... around the world. The lightness of the M20C makes it most ideal... Short runways and Mooneys... it really helps to have good training and practice... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
flyer338 Posted November 7, 2019 Report Share Posted November 7, 2019 Back in the mid-90s I flew out of a 2500’ gravel surfaced strip at Coalgate, Oklahoma with no problem in my ‘65 C. Quote Link to comment Share on other sites More sharing options...
markgrue Posted November 11, 2019 Report Share Posted November 11, 2019 my 63C lives on an 1800 ft grass strip. Hit your numbers on final and if you are not lined up right don't be afraid to go around. I use 70 mph on final and try to cross the threshold at 65. stops in plenty of time. If it is just me and half fuel I sometimes run out of nose up trim so have to hold an armload of up elevator but it is doable. Mark Quote Link to comment Share on other sites More sharing options...
