thomas1142 Posted August 9, 2019 Report Posted August 9, 2019 I asked an avionics shop for an estimate to install a G3X and the GFC 500, they came back with the below requirements. can you all fill me in on all this so I’m not to clueless when I go speak to them. I read as much as I can, but still fuzzy about it all. Garmin GX3 10 inch portrait Display LRU Kit Install Kit GAD 29B GAD Install Kit GMU 507 GFC 500 Info Kit Servo Install Kit Garmin G5 AI (3) Servos Quote
donkaye Posted August 9, 2019 Report Posted August 9, 2019 2 hours ago, thomas1142 said: I asked an avionics shop for an estimate to install a G3X and the GFC 500, they came back with the below requirements. can you all fill me in on all this so I’m not to clueless when I go speak to them. I read as much as I can, but still fuzzy about it all. Garmin GX3 10 inch portrait Display LRU Kit Install Kit GAD 29B GAD Install Kit GMU 507 GFC 500 Info Kit Servo Install Kit Garmin G5 AI (3) Servos That looks right to me. The first 3 items are required for the G3X. The other items are required for the GFC 500 installation. I don't have the G3X, but I do have the GFC 500 and it required all the named parts, however, those could have been detailed even more than indicated. I've attached the interface of the GFC 500 and G500 TXi. Replace the TXI interface with the G3X and you have your setup. Quote
MIm20c Posted August 9, 2019 Report Posted August 9, 2019 You need the gad29 (b) to link the gtn/gns units to the g5/g3x. The 507 is the autopilot control installed in your panel. Quote
thomas1142 Posted August 9, 2019 Author Report Posted August 9, 2019 Since half the part are needed for the G3X and the other half for for the GFC 500, aren’t they part of each package? If so, should they be included in the price of the main item that requires them for the install, or is each one priced separately? Overall price for this was approx 37K, sound right? 1 Quote
MIm20c Posted August 9, 2019 Report Posted August 9, 2019 The stc dictates what parts are necessary on a certified install. Even the TXI that is normally advertised at a single 16k comes as two separate parts (display and LRU) when the dealer orders them. The 29(b) is not necessary needed but without it the g5 and g3x will be unable to interface with the Garmin gps/nav/com units. This is advantageous for installs upgrading from a g5/gad because no unnecessary parts are shipped. As for price I think Garmin has around a 25 ish percent spread between dealer cost and prices listed on line. Some shops split that with the customer some charge them full retail. Labor rates and predicted hours are all over the place so I can’t commit on that. Quote
thomas1142 Posted August 10, 2019 Author Report Posted August 10, 2019 I should clarify, the price includes installation on new EDM 900 plus new panels. Quote
NicoN Posted August 10, 2019 Report Posted August 10, 2019 Interesting offer. But, for the G3X, you need a AHRS-module, magnetometer and so on, isn't it? Quote
thomas1142 Posted September 22, 2019 Author Report Posted September 22, 2019 Did some more research and found that the LRU kit that is part of the system includes GSU 25D Air Data Computer, Aircraft Heading and Reference System (ADAHRS), GMU 11 Magnetometer, GTP 59 Temperature Probe, GPS Antenna. Quote
NicoN Posted September 23, 2019 Report Posted September 23, 2019 Thank you. Is a G5 still necessary on top even though the G3X controls the servos? My Century 21 only relies on ONE Attitude indicator. And ... where can I find the STC for a M20K? When it comes to certified installations all seems to be top-secret - no matter which manufactruer we are talkong about. Quote
thomas1142 Posted September 23, 2019 Author Report Posted September 23, 2019 G5, or other standby instrument, is required for IFR flight. An installation can be certified as VFR only and a standby instrument is not required. On the plus side, with a G5 you can still operate the GFC 500 even if the G3X fails. I found all the manuals on the Garmin web page. Not sure of the install manual, someone on this site said it was for Garmin installers only. Quote
Ragsf15e Posted September 24, 2019 Report Posted September 24, 2019 The 7” G3 display is also an option. It’s cheaper, saves space and looks good as a pfd. If you want to use an iPad for all the mfd type stuff, 7” pfd might be just fine. Quote
ArtVandelay Posted September 24, 2019 Report Posted September 24, 2019 The 7” G3 display is also an option. It’s cheaper, saves space and looks good as a pfd. If you want to use an iPad for all the mfd type stuff, 7” pfd might be just fine. You mean G3X, the G3 is a marine handheld navigator.Above is my plan, any technology improvements are with mfd functionality anyway, it will come to iPad years sooner than panel mounts.Tom 1 Quote
NicoN Posted September 24, 2019 Report Posted September 24, 2019 9 hours ago, thomas1142 said: G5, or other standby instrument, is required for IFR flight. An installation can be certified as VFR only and a standby instrument is not required. On the plus side, with a G5 you can still operate the GFC 500 even if the G3X fails. I found all the manuals on the Garmin web page. Not sure of the install manual, someone on this site said it was for Garmin installers only. Okay, so this implies that it not necessary Needs to be a G5 (which would make sense), but can also be an electric AI from the old avionics. All the Manuals I found on the Website are about the experimental Versions. Also the Hardware you can get over the Counter seems to be always experimental. I am interested in the exact STCs and to learn about the differences. From Aspen I learnt that in a certified Installation, the Feature to Switch on and off Speed tape and/or Alt-Tape is blocked and also the markings for different Speeds Need to be locked against changing by a user/Pilot. If this is the only difference then it is okay. Quote
thomas1142 Posted September 24, 2019 Author Report Posted September 24, 2019 https://support.garmin.com/en-US/?partNumber=G3X-TCERT-00&tab=manuals Try the link above for the manuals. Quote
