John Mininger Posted June 10, 2019 Report Posted June 10, 2019 Does anyone use the ForeFlight Logbook flight times as they automatically generate? I'd like to, but they always seem a bit high. Then again, I don't have a Hobbs. I've been logging flight time by tach time so I suppose any other method is going to seem high. Has anyone compared ForeFlight logbook time to Hobbs? I really don't want to get into using a stopwatch.
tigers2007 Posted June 10, 2019 Report Posted June 10, 2019 I was corrected here on MS to change how I log. I was incorrectly instructed on how to log for years. You log when the aircraft is operating under its own power. So count startup to shutdown. ForeFlight for me is 50/50 accurate. It’s usually a tad high. I use my stopwatch on my iPhone. Sent from my iPhone using Tapatalk
N201MKTurbo Posted June 10, 2019 Report Posted June 10, 2019 (edited) I've always logged tach time. I don't need more Mooney time. Foreflight does seem quite high. it wants to give me 1.0 on a 0.5 flight. I can't accept those times. I do accept them when flying a twin.... Edited June 10, 2019 by N201MKTurbo
gsxrpilot Posted June 10, 2019 Report Posted June 10, 2019 I use the flight time from my EDM900. Every so often, I download the data and upload it to my SavvyAnalysis account. That has a "duration" column that seems to be much closer to reality than ForeFlight. Then I update my ForeFlight log book. I'm certainly not about to pull out a stopwatch. But then logged flight time isn't all that important to me. 1
Oldguy Posted June 10, 2019 Report Posted June 10, 2019 5 minutes ago, gsxrpilot said: I use the flight time from my EDM900. Every so often, I download the data and upload it to my SavvyAnalysis account. That has a "duration" column that seems to be much closer to reality than ForeFlight. Then I update my ForeFlight log book. Had not thought of using the EDM flight time, but just checked the last four flights between the Savvy uploaded time and the ForeFlight times. They are the same in total, and vary by less than 5 minutes on each. I will use that as a cross check from now on. Thanks, Paul! 1
gsxrpilot Posted June 10, 2019 Report Posted June 10, 2019 The other reason I use the EDM900 is that I'm not always using ForeFlight. I use it pretty religiously on cross country flights, but not when just local. Regardless, the EDM is always logging for me.
steingar Posted June 10, 2019 Report Posted June 10, 2019 If I remembered to turn on the clock I could use it. But I'm happy to use the tach. My Forefligth subscription is so cheap I don't even have a logbook.
carusoam Posted June 10, 2019 Report Posted June 10, 2019 Back in the day... Flight time was considered from the time the plane started rolling the tires under its own power, to the time it stopped rolling the tires under its own power... So the flight instructors were interested in starting the engine, allowing the plane to move, then perform a brake test.... All the engine time after that was logged... A bunch of inaccuracy occurs when you have a long taxi time before T/O... any tach time is based on rpms of the engine... they are revolution counters. taxiing anywhere over idle speed leads to fast ground speeds... Mooneys with hour meters may have an oil pressure switch that starts the clock when the oil pressure comes up. Counting time while standing still... prior to motion... hour meters are nice, they don’t count engine revolutions... it is important to know what switches them on... an air pressure switch and an hour meter combination won’t capture the taxi time... Some flight schools used to connect the hour meter to the master switch... starting the clock a bit early... A fully integrated JPI has the opportunity to know a lot of detail... it knows movement when connected to a WAAS gps... it knows oil pressure for knowing the engine is running... it counts time in seconds... it even counts fuel needed to get to your destination... what it does with all this information, is log it in a file... My logging requirements are relatively simple... Aircraft maintenance Insurance wants to see the previous year’s experience Other sources of hour logging that are available... ClouAhoy an app that is great at logging flight maneuvers also logs the flight time in standard ways... using a WAAS source is best. WingX has some ability to log flights as well... remembering to be connected and turned on, can throw a wrench in the plan. Some incomplete thoughts of a PP... not a time traveler... Best regards, -a-
daytonabch04 Posted June 10, 2019 Report Posted June 10, 2019 I've had FF time be 0.5 hr higher than my tach on flights before. I have a JPI700 which doesn't log time, but I do have a hobbs/tach (not sure which one is installed) time in the back of my plane. I've been going with the hobbs/tach then realized the FF time is start/stop. I need more hours in my Bravo so sometimes I'll just use the average of the two.
jaylw314 Posted June 10, 2019 Report Posted June 10, 2019 I wonder when JPI monitors start logging. It doesn't seem to log when I have the motor off, but I do not have MP or RPM sensors, nor does it get GPS data, so I wonder if it waits for CHT's or EGT's to come up to a certain level before it starts recording
Davidv Posted June 10, 2019 Report Posted June 10, 2019 I find that my ForeFlight time is pretty close to the hobbs for me and checking my hobbs is such a pain based on where Mooney put it. For those not aware, the clock in the bravo (or maybe just my plane!) is in the left side of the passenger footwell. I literally need to get on my stomach from the wing walk and use a flashlight to get the reading!
daytonabch04 Posted June 10, 2019 Report Posted June 10, 2019 3 minutes ago, Davidv said: I find that my ForeFlight time is pretty close to the hobbs for me and checking my hobbs is such a pain based on where Mooney put it. For those not aware, the clock in the bravo (or maybe just my plane!) is in the left side of the passenger footwell. I literally need to get on my stomach from the wing walk and use a flashlight to get the reading! Interesting...on my Bravo it's on the back wall in the luggage area...right below the upper storage compartment. 1
Davidv Posted June 10, 2019 Report Posted June 10, 2019 6 minutes ago, daytonabch04 said: 2001 That may have something to do with it. I was in a friends ovation on Saturday and it was in the same location in the back of the baggage compartment. 1
carusoam Posted June 10, 2019 Report Posted June 10, 2019 3 hours ago, jaylw314 said: I wonder when JPI monitors start logging. It doesn't seem to log when I have the motor off, but I do not have MP or RPM sensors, nor does it get GPS data, so I wonder if it waits for CHT's or EGT's to come up to a certain level before it starts recording Expect when the electricity is delivered to the device... JPI comes alive and runs through its start-up sequence... I believe, mine comes on with the avionics master... Glass panel planes typically start logging data with the master switch... The JPI is built robust enough to handle start-up surges of electricity... PP thoughts only as usual... Best regards, -a- 1
jaylw314 Posted June 10, 2019 Report Posted June 10, 2019 Mine's wired to the avionics bus, but even then I've noticed some of my logs seem to start right before the runup, or it seems like the taxi goes on for just a bit too little time.
PT20J Posted June 10, 2019 Report Posted June 10, 2019 According 14 CFR Part 1.1, Flight time means: Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing. So, taxi time counts if you go flying. 1
RLCarter Posted June 11, 2019 Report Posted June 11, 2019 I use my wrist watch, I also use a log sheet that has start & stop times for real time, tach time and hobbs time, takes less than a minute to enter all 6 times
DXB Posted June 11, 2019 Report Posted June 11, 2019 23 hours ago, jaylw314 said: 19 hours ago, carusoam said: Expect when the electricity is delivered to the device... JPI comes alive and runs through its start-up sequence... I believe, mine comes on with the avionics master... Glass panel planes typically start logging data with the master switch... The JPI is built robust enough to handle start-up surges of electricity... PP thoughts only as usual... Best regards, -a- I wonder when JPI monitors start logging. It doesn't seem to log when I have the motor off, but I do not have MP or RPM sensors, nor does it get GPS data, so I wonder if it waits for CHT's or EGT's to come up to a certain level before it starts recording At least on my JPI EDM900, all the recordings begin and end with EGTs in the 1000-1100 range and rpms in a wider 600-1100 range. I suspect it is using evidence of sustained combustion based on EGT >1000 as the basis for starting and stopping data logging. 2
ArtVandelay Posted June 11, 2019 Report Posted June 11, 2019 At least on my JPI EDM900, all the recordings begin and end with EGTs in the 1000-1100 range and rpms in a wider 600-1100 range. I suspect it is using evidence of sustained combustion based on EGT >1000 as the basis for starting and stopping data logging. Not on my 900: Maybe 500° for EGT, but I would hope RPM would be used? Tom 1
DXB Posted June 11, 2019 Report Posted June 11, 2019 (edited) 30 minutes ago, ArtVandelay said: Not on my 900: Maybe 500° for EGT, but I would hope RPM would be used? Tom Huh, clearly a difference on yours. I checked multiple flights. Maybe different firmware? I have mine set to max sampling rate, so its not that. Edited June 11, 2019 by DXB 1
kortopates Posted June 11, 2019 Report Posted June 11, 2019 (edited) 35 minutes ago, ArtVandelay said: Not on my 900: Maybe 500° for EGT, but I would hope RPM would be used? Tom I believe RPM is correct on the Primary units, although not necessarily the Non-primary units. Although I am not 100% certain, I know on the certified Primary units, TACH time begins when RPM goes from 0 to 1000 rpm (factory default setting) to activate it and I believe Hobbs time is also activated at the same time. But Non-primary units, which are wired into the Avionics buss I assume are activated when powered up which 99% of the time is after engine start. By then EGTs will be higher. For purposes of logging flight time, any Garmin (and I assume Avidyne) GPS makes this trivial. Just set the one of the timers to activate at "power on" and note the time just before shutdown. That's going to be within a minute of the traditional Hobbs meter that vast majority of us used for both logging and paying for aircraft rental time which was activated by oil pressure in most rental aircraft. Using tach time, or the equivalent Mooney hour meter, intended for maintenance tracking, is robbing yourself of total time. By about an average of 0.2 for each flight in my a/c. Edited June 11, 2019 by kortopates 3
jaylw314 Posted June 11, 2019 Report Posted June 11, 2019 20 hours ago, PT20J said: According 14 CFR Part 1.1, Flight time means: Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing. So, taxi time counts if you go flying. "comes to rest after landing." I wonder how that is interpreted. I landed at PDX once and it took ground about 30 minutes to taxi us around to the GA terminal. I wonder if I should have subtracted that time from my flight time?
Davidv Posted June 11, 2019 Report Posted June 11, 2019 I think it all counts towards total time in the way that I interpret the regulation. If anything, every flight school is overestimating time by using the Hobbs alone since it’s activated in a lot of planes by the rise of oil pressure (when the aircraft turns on and off). The time that is spent in warm up, receiving clearances, ect before the aircraft moves is being counted towards total logbook time. This is why I think an accurate ForeFlight/CloudAhoy log (or a stopwatch if you like) most closely mirrors the regulation because it should theoretically start when the plane begins to move and stop when the plane ultimately comes to rest. I’ve looked at several of my detailed tracks in the app and it very closely (down to what looks like a few feet) seems to capture where the plane started moving to where it ultimately stopped. You just need to be careful that the GPS source is a good one and in the plane when recording starts. I’ve had it accidentally also record from my iPhone and it shows my walk from the car to the plane.
