Okay- got your attention.  Mind out of the gutter.    I bought a pair of Orion 650 wingtip nav/strobes recently for a good price.    While cleaning them up this past weekend, I noticed that one of them is missing an internal mounting screw, which is a MS24693-C2 (see #6 below).  Of course Aircraft Spruce doesn't stock it.    Anybody know of a good source?
Thx.
15 minutes ago, bluehighwayflyer said:
You can buy them individually at Spruce for 4 or 5 cents depending on if you want cad plated or stainless if you are willing to cut/file 1/8” off.  3/8” is the shortest length they have available and you need 1/4”
https://www.aircraftspruce.com/catalog/hapages/ms24693.php
Jim
Yeah, I thought about that.   Maybe that is the way to go.  Buy 1/2" so I'll have plenty of room to clamp the non-head end in a vice and Dremel them down to length with a nut on to repair the thread.    <whinge>Just, UGH.  I'd rather not have to do that! </whinge>
That is too much work! But many of the cheap wire strippers have threads for small screws/bolts, including the 4-40 you need, which will enable you to trim them precisely with relative ease. Here is not such a cheap example from Spruce for $20, but you can probably get something similar from Home depot for half the cost. https://www.aircraftspruce.com/catalog/topages/crimptool.php?clickkey=174964
Edited by kortopates
25 minutes ago, RLCarter said:
Just go to the hardware store and be done with it
If I needed a football player, that could be found in Tuscaloosa, Alabama.   100-degree flat head stainless MS24693-C2 machine screws, rare as hens teeth.:P
Your friendly local A&P doesn't have any?
Nope.  Ace Hardware is about as good as it gets in T-Town.
I went ahead and ordered 5/8" long #4 SS screws from Aircraft Spruce.  I'll put a couple of nuts on then cut them to length with a Dremel.
Many people go to their maintainer for a good screwing.  In your case it lasted some time.
Looks like a screw used in securing computer daughter boards to the case...
I'm guessing a freebie from the local Best Buy?
The problem is the 100° countersink. Most non-aviation screws are 82°.
4-40 screws are skinny and very easy to cut with a common crimping tool. After that, you can use it as a crimper, to boot.
It seems like the easiest course of action would have been to buy the 100pcs from McMaster for $11 + shipping since they are the exact screw. I think the McMaster image posted shows the identical part number as well.
A fellow has to ask themselves how much their time is worth.
Edited by David_H
It’s at least 0.010 amu worth of humor...
Good luck with the cut and reorganizing the threads.
Whelen is in CT if you want to call them... to enact Plan Bravo... :)
If someone had offered one of the MS24693-C2 for $10 it would have been an easy fix. But what to do with the other 99 .. .lol?
I have an electrical wiring stripper/tool with an integral shear that will make short work of turning a 5/8" long #4 SS screw into a 1/4" long one, and fix the threads to boot after the cut is made.
How does it fix the threads?
You thread it into the sheer. After shearing the screw you unscrew it, fixing the threads.
Edited by N201MKTurbo
?? I didn't realize those cutters had integral threads?  How come I'm just finding out about this now?? :rolleyes:
Any day you learn something new is a good day!
Wire strippers in front, threaded bolt cutters at the back around the hinge pin.
