Flew through some rain showers for the first time  the other day. Tying the plane down I noticed the cowling was streaking with some sort of substance as you can see in the pics below. Anyone experienced this before?  Exhaust soot? Cowling vibration / chaffing between where the fiberglass cowling and aluminum meet?
Thanks
Hank
This is basically metal dust washing out of the fasteners.  Also, the cowl will chaff the aluminum edge to which it is fastened.  Usually there is anti friction tape to guard against that - but is can be difficult to eliminate all of it.   Easier to clean off before it dries completely.    Rain is hard on paint, too.
No corrosion X and I removed the cowling 35 hours ago...clean cowling and not a lot of leaking oil. I have only owned the aircraft since late December. Headed to maintenance this weekend for tire change and new tailpipe. I will show pics to maintenance and ask about friction tape.
+1 for fine metal dust that gets oxidized and loves to show up later... aluminum on aluminum rubbing is a dust factory...
For a finer more annoying example... look up smoking rivets.
+1 for CorrosionX being able to adsorb the same fine dust and bring it to the surface.... CX makes the rivets appear like smoking rivets... smoking rivets are more of a real problem... they are in the initial stages of becoming loose rivets...
The fine dust is pretty close to the molecular scale...
Finding a way to eliminate the rubbing is a good idea... chafe tape?
  • 2 weeks later...
George,
Listen to GEE-BEE. I had the exact problem. It is caused by aluminum rubbing together producing the black dust. The silicone seal will fix your problem.
Edited by BillC
On 2/17/2019 at 12:13 PM, GEE-BEE said:
I have silicone seal
.032 thickness
1” wide and 1-1/2 wide
This will act as a bumper and remove chafing
Advise your required length
i will include clear cement
GB
Not sure what your solution looks like . Silicon seal in the cowl overlap ?
.032 thickness
GB
Photos, website, prices, how to order?
use the high bond stuff on bare metal, such as the boot cowl. Use the other stuff for gear doors, upper flap skin, tail gap closeout panel, etc.
