Hi All,
Anyone have issues with the over voltage light coming on more and more frequently?  It resets if I pull and reset the field breaker.    Thanks! Jim
  On 10/1/2018 at 10:48 PM, merrja said:
Hi All,
Verify it’s not an annunciation error first.
Expand
I'm not sure how your 68 F is electrically configured, but the over-voltage light on my '74 C came on a couple of times after engine start.  I reset it by turning the master off, then back on.  Because I was sure that my voltage regulator was going bad, I bought a voltage regulator and put in in my baggage compartment....just in case.  It's still there.  Apparently the new regulator scared the installed voltage regulator into behaving.  I wasn't able to determine any cause, or cure.
Good luck.  Electrical gremlins can be fickle.
I just had this problem.
I tried everything. Contacts on master, new brushes, inspected and tightened field wires. I was too cheap to buy a new regulator. Nothing fixed it until I bought a new regulator.
