Reid Posted September 22, 2018 Report Posted September 22, 2018 We have a M20C with the control shafts approaching the ad inspection timeframe. Does anyone know where I could find the required components to upgrade to the 201 yokes/shafts? Thanks! Quote
gsxrpilot Posted September 22, 2018 Report Posted September 22, 2018 You can get the shafts from Mooney. You'll need to go through an MSC to order them. You might also get the yokes from Mooney as well, but it's a lot cheaper if you can find them second hand somewhere. Be careful buying shafts. They are different between models. So if you find them used online somewhere, make sure they will fit your C. You might find an old set of yokes for a J or K and then have them covered in leather at AeroComfort in San Antonio. I can tell you from experience, it makes a really nice upgrade to your cockpit. 1 Quote
MrRodgers Posted September 22, 2018 Report Posted September 22, 2018 Great decision in wanting to do the upgrade. Upon purchase I had mine done with the assistance of Don Maxwell and I am really happy with the results. Here they are looking so good I ended up redoing my panel as well a few months later. Sent from my iPhone using Tapatalk 1 Quote
Mooney-Mark Posted September 23, 2018 Report Posted September 23, 2018 Great looking yokes and panel MrRodgers! 1 Quote
Danb Posted September 23, 2018 Report Posted September 23, 2018 MrR clean looking panel. It’s awesome how our Mscer’s restore our vintage aircraft 1 Quote
MBDiagMan Posted September 23, 2018 Report Posted September 23, 2018 I hated to give up the wrapped 201 yokes in my C. Quote
gsxrpilot Posted September 24, 2018 Report Posted September 24, 2018 2 hours ago, MBDiagMan said: I hated to give up the wrapped 201 yokes in my C. You swapped everything else out... why not the yokes as well? Quote
MrRodgers Posted September 24, 2018 Report Posted September 24, 2018 13 hours ago, Danb said: MrR clean looking panel. It’s awesome how our Mscer’s restore our vintage aircraft When buying the plane in December I knew she needed attention. Don Maxwell did a great job with the needed/requested upgrades including new flaps, new brakes, new pucks, new oil lines, new tires, new wheels, new visors, new yokes (leather wrapped). I’ve also recently had new flap seals, vernier prop controller, new voltage regulator and alternator installed as well. Since that photo above was taken I’ve also upgraded the panel with a Garmin set up. GTX 345 Transponder ADSB OUT/ IN GMA 350 C Audio Panel with Bluetooth and Connectivity Voice Commands. GTN 650 Nav/Com GPS GI 106 B Heading Indicator. EDM 700 Engine Monitor- Upgraded and New Display I’m done with the upgrades for a while. She’s ready to fly on with confidence. Now if only I could get my hours in her to match the dollars I spent getting her in shape. Love my plane! [ Sent from my iPhone using Tapatalk 2 Quote
MBDiagMan Posted September 24, 2018 Report Posted September 24, 2018 1 hour ago, gsxrpilot said: You swapped everything else out... why not the yokes as well? Great question! I never even thought about it. Quote
Aggie Aviator Posted September 27, 2018 Report Posted September 27, 2018 Guys, I am contemplating redoing the panel and possibly get new yokes for my 20F. I know it depends largely on the amount of changes to the panel, but how much should I budget to move some instruments around and possibly replacing the panel? How much is it to change out the shafts? Quote
MBDiagMan Posted September 27, 2018 Report Posted September 27, 2018 On 9/22/2018 at 10:13 AM, gsxrpilot said: You can get the shafts from Mooney. You'll need to go through an MSC to order them. You might also get the yokes from Mooney as well, but it's a lot cheaper if you can find them second hand somewhere. Be careful buying shafts. They are different between models. So if you find them used online somewhere, make sure they will fit your C. You might find an old set of yokes for a J or K and then have them covered in leather at AeroComfort in San Antonio. I can tell you from experience, it makes a really nice upgrade to your cockpit. Paul, are you saying that J or K yokes will fit on F shafts? Quote
gsxrpilot Posted September 27, 2018 Report Posted September 27, 2018 5 minutes ago, MBDiagMan said: Paul, are you saying that J or K yokes will fit on F shafts? I believe they will. But I would double check that with someone who would know for sure. I'd check with Don Maxwell. Quote
MBDiagMan Posted September 27, 2018 Report Posted September 27, 2018 I will ask this question at MooneyMax. Quote
Marauder Posted September 27, 2018 Report Posted September 27, 2018 I will ask this question at MooneyMax. This is on the drawings that Mooney provided me back in the 1990s when I upgraded. There were different package numbers for the various years. Sent from my iPad using Tapatalk Pro Quote
Marauder Posted September 27, 2018 Report Posted September 27, 2018 (edited) This is the rest of the pile of drawings for the retrofit. Even provided the colors of the paints used. Sent from my iPad using Tapatalk Pro Edited September 27, 2018 by Marauder Quote
bradp Posted September 29, 2018 Report Posted September 29, 2018 Are the material for the 201 yokes Aluminum or magnesium? Was thinking cover or powder coat or ceramic coat. Apparently there’s a cerakote that is compatible with magnesium alloys whereas most ceramic coatings are not. Quote
