Prior owner Posted July 20, 2018 Report Posted July 20, 2018 Hi guys, I’ve been searching through threads but cannot find an answer to my question, so hoping you can help: The main gear on my M20D/C has never been through the Lord disc retrofit, so we are gathering up everything to get it done during the annual. After a thorough review of the M20D service manual, the Mooney SB on retrofitting, and every other SB or SI regarding the gear, I cannot find find any reference or image that depicts the correct orientation of the later model shock link collar, part # 510049-000. My old collar is a simple cylinder and looks like it can be installed in any orientation, but the new collar from Mooney has a cut-out on one side.... which way does the cut-out face, and where would I find this information published? Thanks for any replies, Dave Quote
MARZ Posted July 20, 2018 Report Posted July 20, 2018 Curious as to why you’re replacing the collar? Quote
1964-M20E Posted July 20, 2018 Report Posted July 20, 2018 Not certain but I believe the cut goes to the front. It has been a few years since I have had them off. Quote
N201MKTurbo Posted July 20, 2018 Report Posted July 20, 2018 If I recall, it is obvious when you put it together. The bevel is there to clear a tube or weld. You could always go find another Mooney and crawl under and look at it. I bet there is a picture on this site somewhere of it. 1 Quote
Prior owner Posted July 20, 2018 Author Report Posted July 20, 2018 (edited) The service manual says to replace the collar and bolt at each annual insp.... But I am replacing them for piece of mind- new bolts and collars with the new style shock links. I just put a call into LASAR.. I’ll share the results here. Oddly, I could not find a pic of this collar installed on internet. No other Mooneys at my field. Edited July 20, 2018 by PilotCoyote Quote
N201MKTurbo Posted July 20, 2018 Report Posted July 20, 2018 You can see it faces forward and down to clear that tube. 1 Quote
Prior owner Posted July 20, 2018 Author Report Posted July 20, 2018 Thank you for the pic. I guess the later style gear required that particular collar design... probably unnecessary on my gear? We’ll take some pics during the retrofit. Quote
