I broke 2 grease zerks on main landing gear on 1962 m20c. Anyone have any ideas on how to replace and the thread size of  Zerk? Looks like a very small ez out is needed.
On my 62C they are threaded. I recently replaced them with the following:
https://www.amazon.com/Alemite-Special-Thread-Fitting-Straight/dp/B00KNXO4R4/ref=sr_1_1?ie=UTF8&qid=1527808907&sr=8-1&keywords=Alemite+3018+Special+Thread+Fitting%2C+Straight%2C+%236+UNF-2A
To remove the old remnants, I used a 1.5mm hex and applied very slight side pressure. Both came right out but of course you have to be very careful not to break the hex/Allen wrench off inside. Both came out with zero resistance, simply unscrewed.
Suggest a LockNLube so you don't break the new ones.
