steingar Posted August 22, 2017 Report Posted August 22, 2017 I might actually pony up for the extra bladders one of these days. Only time you can' have too much fuel is when you're on fire. Still jonesing to fly my mooney across the pond... 1
Cooperd0g Posted August 26, 2017 Report Posted August 26, 2017 If you have the 54 gallon system, what is the total usable fuel? If you have the 64 gallon system, what is the total usable fuel?
Mooneymite Posted August 26, 2017 Report Posted August 26, 2017 1 hour ago, Cooperd0g said: If you have the 54 gallon system, what is the total usable fuel? If you have the 64 gallon system, what is the total usable fuel? Each of my tanks are placarded: "27.4 gallons". As far as I know, it is all useable, but I have not yet verified it by running out of gas.
jetdriven Posted August 27, 2017 Report Posted August 27, 2017 I would verify at least by draining the gascolator and draining it all down until it won't drain anymore because mine holds just about 54 gallons and that's it. Verified of course. 1
Marauder Posted August 29, 2017 Report Posted August 29, 2017 30 minutes ago, nosky2high said: That is what my experience shows as well having ran both of my bladder type tanks dry (not at the same time) and filled them back up to 27.5 and 27.4 respectively. The 54.8 gallons is supposed to be the useable fuel. The total fuel should be around 57 gallons (around 1 gallon of unusable per side). And that works out about right. I drained my system for installation of the CiES senders and the JPI said I had around 5 gallons left per side and I have closer to 6 gallons per side in the gas cans.
jetdriven Posted August 29, 2017 Report Posted August 29, 2017 I ran all mine out then filled it up and it was about 54-55 gallons. That foam must have taken up some space in the wings because that's all it holds.
1964-M20E Posted August 29, 2017 Report Posted August 29, 2017 I plan on 54 gallons the other 0.8 gallon does not fit into easy math. Engineers always want easy math. 54 gallons 9GPH leaned out 6 hours of total engine running time, 145kts average GS, 870NM range no reserve, 725NM with 1 hour reserve. Backed up by fuel flow meter and flights that have proven it out. Typical flight 3.5 hours 507NM +/- and 2.5 hour reserve left in the tanks. JMHO 1
N6758N Posted September 5, 2017 Report Posted September 5, 2017 @Chris Murley Can you confirm what unusable fuel is for the 54.8 gallon system? I am installing new senders as part of my installation and want to make sure I put any unusable fuel into the tanks first before I start the sender calibration process to the EDM-900.
carusoam Posted September 5, 2017 Report Posted September 5, 2017 T, Expect the unusable fuel is all the fuel that is below the fuel pick-up line. This fuel line has to be under the surface or it starts inhaling air bubbles. While the plane is leveled, as it were in flight... In real life, nose up vs. nose down really effects this value. The pick-up is towards the back of the tank. Going nose down, fuel runs forwards and the engine stops running.... M20C experience... Draining a tank using the fuel pick-up system can be achieved by draining fuel from the selector valve/pull ring.... There is probably a definition of usable fuel from Mooney and the FAA. The tank design better allows for fuel to be available during the climb, not so much for the descent. guessing a gallon or two in each (standard sealed) tank is unusable? PP thoughts only, not a mechanic... Best regards, -a-
Marauder Posted September 6, 2017 Report Posted September 6, 2017 My guess is the unusable is around 3 gallons in both tanks. My calibrated JPI said I had 5 gallons of usable left and I took out about 1.5 more per side.Sent from my iPad using Tapatalk Pro 1
