NotarPilot Posted February 26, 2017 Report Posted February 26, 2017 I've been using a BatteryMinder for almost fives years and use the wires with terminal rings and a fuse to attach it directly to the battery. I fished the wire through an existing whole into the baggage compartment. I never had an issue with this. My buddy bought one for his 182 and asked me how I have mine set up. He tells me the BatteryMinder company says the wires I use (which came with my BatteryMinder when I bought it) are not approved for FAA certified aircraft and the website says I need to buy the BatteryMinder interface kit. Is this true? Have I had my set up wrong this whole time? BatteryMinder airframe interface kit. Quote
Godfather Posted February 26, 2017 Report Posted February 26, 2017 When my IA installed the unit he used those exact connections (this was many years ago before the kit was available) and they have worked flawlessly. My connection is through the TKS door...I have two connectors, one on each side of the fill port, one for each battery. 1 Quote
LANCECASPER Posted February 26, 2017 Report Posted February 26, 2017 48 minutes ago, Godfather said: When my IA installed the unit he used those exact connections (this was many years ago before the kit was available) and they have worked flawlessly. My connection is through the TKS door...I have two connectors, one on each side of the fill port, one for each battery. I set mine up through the O2 door and in the avionics bay I put a batteryminder 210-AY to split to both batteries. One Batteryminder to charge and desulfate two batteries works well. Quote
NotarPilot Posted February 26, 2017 Author Report Posted February 26, 2017 34 minutes ago, LANCECASPER said: I set mine up through the O2 door and in the avionics bay I put a batteryminder 210-AY to split to both batteries. One Batteryminder to charge and desulfate two batteries works well. Are you using the interface kit or just the wires with the terminal loops? Quote
Marauder Posted February 26, 2017 Report Posted February 26, 2017 I've been using a BatteryMinder for almost fives years and use the wires with terminal rings and a fuse to attach it directly to the battery. I fished the wire through an existing whole into the baggage compartment. I never had an issue with this. My buddy bought one for his 182 and asked me how I have mine set up. He tells me the BatteryMinder company says the wires I use (which came with my BatteryMinder when I bought it) are not approved for FAA certified aircraft and the website says I need to buy the BatteryMinder interface kit. Is this true? Have I had my set up wrong this whole time?BatteryMinder airframe interface kit. The wires that come with the BatteryMinder are not FAA approved for permanent installation. The kit you referenced is the kit with FAA approved quick disconnects and attachment hardware for the battery. I bought one a few months ago, just haven't installed it yet. Sent from my iPhone using Tapatalk Pro 1 Quote
LANCECASPER Posted February 26, 2017 Report Posted February 26, 2017 8 hours ago, NotarPilot said: Are you using the interface kit or just the wires with the terminal loops? The terminal loops. The 210-AY has three 15 amp fuses for protection. 1 Quote
Guitarmaster Posted February 26, 2017 Report Posted February 26, 2017 I put a power port in the back bulkhead and I plug the minder in there. It Can be used for the kids to plug in their devices, and I can keep the battery topped off without a permanent installation.Sent from my iPad using Tapatalk Quote
carusoam Posted March 6, 2017 Report Posted March 6, 2017 (edited) BM has two interface kits... The low buck kit uses PVC coated wires perfect for experimentals. The high Buck kit uses more certified aviation friendly coatings... BMIK2... battery minder interface kit 2... yep, I called the company directly to get that answer... Its almost fun being me... Best regards, -a- Edited March 6, 2017 by carusoam 1 Quote
