kortopates Posted February 8, 2017 Report Posted February 8, 2017 I replaced one in 2013 when unfortunately I was a long ways from home and had to go with a overhaul exchange unit like John - for just a bit over $2K for the unit. Although mine is different part I am sure its nearly identical cost. Kelley owns all of them these days. If you can send your own unit in for overhaul you can typically cut the cost down by as much as half; depending. I think I paid 1K to overhaul my own wastegate. MainTurbo is the place to go. Quote
jlunseth Posted February 9, 2017 Report Posted February 9, 2017 There you go, Rule of 600's x 2 because its aviation. Meant to be humorous, well, mostly humorous. It is what it is. Quote
